Question, SC16IS752/SC16IS762 crystal
2,149件の閲覧回数
SLICE
Dear team,
Let me ask about crystal of SC16IS752 and SC16IS762.
According to its datasheet, it says that one should use 1. 8432MHz or 3.072MHz crystal for the chip.
Is it possible to use other frequency crystal for the chips?
Of course, one should consider the UART boud-rate should be changed according to the frequency of crystal, i think.
Miyamoto
1,688件の閲覧回数
guoweisun
Yes,you are correct,you can use other parameters crystal.
Thanks!
