Push-Poll or OpenDrain
Kuti
The MCU I use is  MKE04Z8VTG4.
I haven't seen an option to set the output as open drain or push pull.
I only saw that PTA2 and PTA3 are true open-drain pins when operated as output.
Does that mean other pins are push pull? (I want to know about Pin PTB5)
Kuti
