Problem while loading code to flash(Failed to enter into background mode)
mohammedshibin
Hai,
I am using PXS3020 for my project. I was testing the peripherals' functionality. I am using PE Micro multilink universal for debugging.
Everything was fine until today morning. Now I am not able to load the executable file into flash memory. I did not change anything in code from yesterday.  The screenshot of the error message is attached.
The peripheral that I enabled last is FlexPWM (Enabled Auxillary clock 0 - 16 MHz Internal RC Oscillator), and with PWM it was working until yesterday night.
Does auxiliary clock 0 create any problem? Kindly help me to solve the issue.
Thanks & Regards,
Mohammed Shibin
lukaszadrapa
Just to close this thread - we were informed by customer that the problem was caused by FPGA which was holding the the reset pin low.
Lukas
