PTN3355 RGB Rise and fall time failed
3,227件の閲覧回数
jackylu
I've use PTN3355, measure output RGB,  rise and fall time failed,
If remove pi filter, issue still have.
Any comment about this?
タグ(1)
3,193件の閲覧回数
guoweisun
The terminal matching network will affect the RISE and DOWN time of the signal.
Pleases test the signal before passing through the terminal matching network is normal or not.
