PCF85063TP Reset problem on boot
1,714件の閲覧回数
amond
Hello I have a problem on boot for the pcf85063tp.
Problem is that "OS Flag" is set and time is wrong on boot.
I don't know why?
The bellows is a our schematic.
1,598件の閲覧回数
darioarias
Do you still have this issue? If so, do you think you can share your configuration and/or code to try to find what is causing the part misbehavior or if you are no longer have the problem, could you tell use how you solve it?
Darío
