PCF1545 PWM Dimming Behavior Analysis on Embedded Boards
433件の閲覧回数
jeremiranner
I have been testing PWM dimming behavior with the PCF1545 on a small embedded LED control board and noticed some interesting behavior at lower brightness levels.
The setup currently uses:
  • MCU: Cortex-M based controller
  • Communication: I2C
  • LED load: multi-segment indicator array
  • Supply voltage: 3.3V
At higher PWM duty cycles, brightness transitions appear smooth and stable. However, when reducing brightness below roughly 15–20%, slight flickering becomes visible depending on the LED type and refresh timing.
A few observations so far:
  • Increasing the PWM refresh frequency reduced visible flicker.
  • Different LED colors behaved differently, especially blue LEDs.
  • Timing jitter from other RTOS tasks slightly affected consistency.
  • Power rail noise also influenced low-brightness stability.
I am currently experimenting with:
  • adjusting scan/update intervals
  • optimizing I2C transaction timing
  • using separate power filtering for the LED section
  • synchronizing PWM updates with the main refresh loop
Has anyone else analyzed PWM dimming characteristics on the PCF1545 in embedded applications?
I would be interested in:
  • recommended PWM frequency ranges
  • best practices for low-brightness stability
  • techniques to reduce flicker during dynamic updates
  • observations when using RTOS environments vs bare-metal systems
Any practical insights or scope captures would be greatly appreciated.
0 返答(返信)
%3CLINGO-SUB%20id%3D%22lingo-sub-2365729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BPCF1545%20PWM%E8%AA%BF%E5%85%89%E5%8B%95%E4%BD%9C%E8%A7%A3%E6%9E%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2365729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%E5%B0%8F%E5%9E%8B%E3%81%AE%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E5%9E%8BLED%E5%88%B6%E5%BE%A1%E5%9F%BA%E6%9D%BF%E4%B8%8A%E3%81%A7PCF1545%E3%82%92%E7%94%A8%E3%81%84%E3%81%9FPWM%E8%AA%BF%E5%85%89%E3%81%AE%E5%8B%95%E4%BD%9C%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E4%BD%8E%E8%BC%9D%E5%BA%A6%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E6%8C%99%E5%8B%95%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3EMCU%EF%BC%9ACortex-M%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FLI%3E%3CLI%3E%E9%80%9A%E4%BF%A1%3A%20I2C%3C%2FLI%3E%3CLI%3ELED%E8%B2%A0%E8%8D%B7%EF%BC%9A%E3%83%9E%E3%83%AB%E3%83%81%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%82%A4%E3%83%B3%E3%82%B8%E3%82%B1%E3%83%BC%E3%82%BF%E3%82%A2%E3%83%AC%E3%82%A4%3C%2FLI%3E%3CLI%3E%E4%BE%9B%E7%B5%A6%E9%9B%BB%E5%9C%A7%EF%BC%9A3.3V%3C%2FLI%3E%3C%2FUL%3E%3CP%3EPWM%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%8C%E9%AB%98%E3%81%84%E3%81%BB%E3%81%A9%E3%80%81%E8%BC%9D%E5%BA%A6%E5%A4%89%E5%8C%96%E3%81%AF%E6%BB%91%E3%82%89%E3%81%8B%E3%81%A7%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%A6%E8%A6%8B%E3%81%88%E3%82%8B%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E6%98%8E%E3%82%8B%E3%81%95%E3%82%92%E7%B4%8415%EF%BD%9E20%EF%BC%85%E4%BB%A5%E4%B8%8B%E3%81%AB%E4%B8%8B%E3%81%92%E3%82%8B%E3%81%A8%E3%80%81LED%E3%81%AE%E7%A8%AE%E9%A1%9E%E3%82%84%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%AF%E3%80%81%E3%82%8F%E3%81%9A%E3%81%8B%E3%81%AA%E3%81%A1%E3%82%89%E3%81%A4%E3%81%8D%E3%81%8C%E8%A6%8B%E3%82%89%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E6%B0%97%E3%81%A5%E3%81%84%E3%81%9F%E7%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3EPWM%E3%81%AE%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E4%B8%8A%E3%81%92%E3%82%8B%E3%81%A8%E3%80%81%E7%9B%AE%E3%81%AB%E8%A6%8B%E3%81%88%E3%82%8B%E3%81%A1%E3%82%89%E3%81%A4%E3%81%8D%E3%81%8C%E8%BB%BD%E6%B8%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%80%82%3C%2FLI%3E%3CLI%3ELED%E3%81%AE%E8%89%B2%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%8C%99%E5%8B%95%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8A%E3%80%81%E7%89%B9%E3%81%AB%E9%9D%92%E8%89%B2LED%E3%81%A7%E9%A1%95%E8%91%97%E3%81%A0%E3%81%A3%E3%81%9F%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%BB%96%E3%81%AERTOS%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8B%E3%82%89%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%B8%E3%83%83%E3%82%BF%E3%83%BC%E3%81%8C%E3%80%81%E4%B8%80%E8%B2%AB%E6%80%A7%E3%81%AB%E3%82%8F%E3%81%9A%E3%81%8B%E3%81%AA%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%81%9F%E3%80%82%3C%2FLI%3E%3CLI%3E%E9%9B%BB%E6%BA%90%E3%83%AC%E3%83%BC%E3%83%AB%E3%83%8E%E3%82%A4%E3%82%BA%E3%82%82%E4%BD%8E%E8%BC%9D%E5%BA%A6%E6%99%82%E3%81%AE%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%81%9F%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%2F%E6%9B%B4%E6%96%B0%E9%96%93%E9%9A%94%E3%81%AE%E8%AA%BF%E6%95%B4%3C%2FLI%3E%3CLI%3EI2C%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%99%E3%82%8B%3C%2FLI%3E%3CLI%3ELED%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AF%E5%80%8B%E5%88%A5%E3%81%AE%E9%9B%BB%E6%BA%90%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLI%3E%3CLI%3EPWM%E3%81%AE%E6%9B%B4%E6%96%B0%E3%82%92%E3%83%A1%E3%82%A4%E3%83%B3%E3%81%AE%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AB%E3%83%BC%E3%83%97%E3%81%A8%E5%90%8C%E6%9C%9F%E3%81%95%E3%81%9B%E3%82%8B%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BPCF1545%E3%81%AEPWM%E8%AA%BF%E5%85%89%E7%89%B9%E6%80%A7%E3%82%92%E5%88%86%E6%9E%90%E3%81%97%E3%81%9F%E4%BA%BA%E3%81%AF%E4%BB%96%E3%81%AB%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%93%E3%81%A8%E3%81%AB%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8BPWM%E5%91%A8%E6%B3%A2%E6%95%B0%E7%AF%84%E5%9B%B2%3C%2FLI%3E%3CLI%3E%E4%BD%8E%E8%BC%9D%E5%BA%A6%E6%99%82%E3%81%AE%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%99%E3%82%B9%E3%83%88%E3%83%97%E3%83%A9%E3%82%AF%E3%83%86%E3%82%A3%E3%82%B9%3C%2FLI%3E%3CLI%3E%E5%8B%95%E7%9A%84%E6%9B%B4%E6%96%B0%E6%99%82%E3%81%AE%E3%81%A1%E3%82%89%E3%81%A4%E3%81%8D%E3%82%92%E8%BB%BD%E6%B8%9B%E3%81%99%E3%82%8B%E6%8A%80%E8%A1%93%3C%2FLI%3E%3CLI%3ERTOS%E7%92%B0%E5%A2%83%E3%81%A8%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AE%E8%A6%B3%E5%AF%9F%E7%B5%90%E6%9E%9C%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E5%AE%9F%E5%8B%99%E7%9A%84%E3%81%AA%E7%9F%A5%E8%A6%8B%E3%82%84%E3%80%81%E6%A5%AD%E5%8B%99%E7%AF%84%E5%9B%B2%E3%81%AE%E6%8A%8A%E6%8F%A1%E3%81%AA%E3%81%A9%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%83%85%E5%A0%B1%E3%81%A7%E3%82%82%E5%A4%A7%E5%A4%89%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%8F%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
