PCF1545 PWM Dimming Behavior Analysis on Embedded Boards
413 次查看
jeremiranner
I have been testing PWM dimming behavior with the PCF1545 on a small embedded LED control board and noticed some interesting behavior at lower brightness levels.
The setup currently uses:
  • MCU: Cortex-M based controller
  • Communication: I2C
  • LED load: multi-segment indicator array
  • Supply voltage: 3.3V
At higher PWM duty cycles, brightness transitions appear smooth and stable. However, when reducing brightness below roughly 15–20%, slight flickering becomes visible depending on the LED type and refresh timing.
A few observations so far:
  • Increasing the PWM refresh frequency reduced visible flicker.
  • Different LED colors behaved differently, especially blue LEDs.
  • Timing jitter from other RTOS tasks slightly affected consistency.
  • Power rail noise also influenced low-brightness stability.
I am currently experimenting with:
  • adjusting scan/update intervals
  • optimizing I2C transaction timing
  • using separate power filtering for the LED section
  • synchronizing PWM updates with the main refresh loop
Has anyone else analyzed PWM dimming characteristics on the PCF1545 in embedded applications?
I would be interested in:
  • recommended PWM frequency ranges
  • best practices for low-brightness stability
  • techniques to reduce flicker during dynamic updates
  • observations when using RTOS environments vs bare-metal systems
Any practical insights or scope captures would be greatly appreciated.
0 回复数
%3CLINGO-SUB%20id%3D%22lingo-sub-2365729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPCF1545%20%E5%B5%8C%E5%85%A5%E5%BC%8F%E4%B8%BB%E6%9D%BF%E4%B8%8A%E7%9A%84%20PWM%20%E8%B0%83%E5%85%89%E8%A1%8C%E4%B8%BA%E5%88%86%E6%9E%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2365729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%E6%88%91%E4%B8%80%E7%9B%B4%E5%9C%A8%E5%B0%8F%E5%9E%8B%E5%B5%8C%E5%85%A5%E5%BC%8F%20LED%20%E6%8E%A7%E5%88%B6%E6%9D%BF%E4%B8%8A%E4%BD%BF%E7%94%A8%20PCF1545%20%E6%B5%8B%E8%AF%95%20PWM%20%E8%B0%83%E5%85%89%E8%A1%8C%E4%B8%BA%EF%BC%8C%E5%B9%B6%E6%B3%A8%E6%84%8F%E5%88%B0%E5%9C%A8%E8%BE%83%E4%BD%8E%E4%BA%AE%E5%BA%A6%E6%B0%B4%E5%B9%B3%E4%B8%8B%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%B8%80%E4%BA%9B%E6%9C%89%E8%B6%A3%E7%9A%84%E8%A1%8C%E4%B8%BA%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%A5%E8%AE%BE%E7%BD%AE%E7%9B%AE%E5%89%8D%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CUL%3E%3CLI%3EMCU%EF%BC%9A%20%E5%9F%BA%E4%BA%8E%20Cortex-M%20%E7%9A%84%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FLI%3E%3CLI%3E%E9%80%9A%E4%BF%A1I2C%3C%2FLI%3E%3CLI%3ELED%20%E8%B4%9F%E8%BD%BD%EF%BC%9A%E5%A4%9A%E6%AE%B5%E6%8C%87%E7%A4%BA%E7%81%AF%E9%98%B5%E5%88%97%3C%2FLI%3E%3CLI%3E%E7%94%B5%E6%BA%90%E7%94%B5%E5%8E%8B%EF%BC%9A%203.3V%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E5%9C%A8%E6%9B%B4%E9%AB%98%E7%9A%84%20PWM%20%E5%8D%A0%E7%A9%BA%E6%AF%94%E4%B8%8B%EF%BC%8C%E4%BA%AE%E5%BA%A6%E8%BF%87%E6%B8%A1%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%B9%B3%E6%BB%91%E8%80%8C%E7%A8%B3%E5%AE%9A%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E5%BD%93%E4%BA%AE%E5%BA%A6%E9%99%8D%E4%BD%8E%E5%88%B0%E5%A4%A7%E7%BA%A6%2015-20%25%20%E4%BB%A5%E4%B8%8B%E6%97%B6%EF%BC%8C%E6%A0%B9%E6%8D%AE%20LED%20%E7%B1%BB%E5%9E%8B%E5%92%8C%E5%88%B7%E6%96%B0%E6%97%B6%E9%97%B4%E7%9A%84%E4%B8%8D%E5%90%8C%EF%BC%8C%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BD%BB%E5%BE%AE%E7%9A%84%E9%97%AA%E7%83%81%E3%80%82%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%E7%9A%84%E5%87%A0%E7%82%B9%E7%9C%8B%E6%B3%95%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%8F%90%E9%AB%98%20PWM%20%E5%88%B7%E6%96%B0%E9%A2%91%E7%8E%87%E5%8F%AF%E5%87%8F%E5%B0%91%E5%8F%AF%E8%A7%81%E9%97%AA%E7%83%81%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%B8%8D%E5%90%8C%E9%A2%9C%E8%89%B2%E7%9A%84%20LED%20%E8%A1%A8%E7%8E%B0%E4%B8%8D%E5%90%8C%EF%BC%8C%E5%B0%A4%E5%85%B6%E6%98%AF%E8%93%9D%E8%89%B2%20LED%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%85%B6%E4%BB%96%20RTOS%20%E4%BB%BB%E5%8A%A1%E4%BA%A7%E7%94%9F%E7%9A%84%E5%AE%9A%E6%97%B6%E6%8A%96%E5%8A%A8%E5%AF%B9%E4%B8%80%E8%87%B4%E6%80%A7%E7%95%A5%E6%9C%89%E5%BD%B1%E5%93%8D%E3%80%82%3C%2FLI%3E%3CLI%3E%E7%94%B5%E6%BA%90%E8%BD%A8%E5%99%AA%E5%A3%B0%E4%B9%9F%E4%BC%9A%E5%BD%B1%E5%93%8D%E4%BD%8E%E4%BA%AE%E5%BA%A6%E7%A8%B3%E5%AE%9A%E6%80%A7%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E8%BF%9B%E8%A1%8C%E8%AF%95%E9%AA%8C%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E8%B0%83%E6%95%B4%E6%89%AB%E6%8F%8F%2F%E6%9B%B4%E6%96%B0%E6%97%B6%E9%97%B4%E9%97%B4%E9%9A%94%3C%2FLI%3E%3CLI%3E%E4%BC%98%E5%8C%96%20I2C%20%E4%BA%A4%E6%98%93%E6%97%B6%E5%BA%8F%3C%2FLI%3E%3CLI%3E%E4%B8%BA%20LED%20%E9%83%A8%E5%88%86%E4%BD%BF%E7%94%A8%E5%8D%95%E7%8B%AC%E7%9A%84%E7%94%B5%E6%BA%90%E6%BB%A4%E6%B3%A2%E5%99%A8%3C%2FLI%3E%3CLI%3E%E4%BD%BF%20PWM%20%E6%9B%B4%E6%96%B0%E4%B8%8E%E4%B8%BB%E5%88%B7%E6%96%B0%E5%BE%AA%E7%8E%AF%E5%90%8C%E6%AD%A5%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E4%BA%BA%E5%88%86%E6%9E%90%E8%BF%87%20PCF1545%20%E5%9C%A8%E5%B5%8C%E5%85%A5%E5%BC%8F%E5%BA%94%E7%94%A8%E4%B8%AD%E7%9A%84%20PWM%20%E8%B0%83%E5%85%89%E7%89%B9%E6%80%A7%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E6%84%9F%E5%85%B4%E8%B6%A3%E7%9A%84%E6%98%AF%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%8E%A8%E8%8D%90%E7%9A%84%20PWM%20%E9%A2%91%E7%8E%87%E8%8C%83%E5%9B%B4%3C%2FLI%3E%3CLI%3E%E4%BD%8E%E4%BA%AE%E5%BA%A6%E7%A8%B3%E5%AE%9A%E6%80%A7%E7%9A%84%E6%9C%80%E4%BD%B3%E5%AE%9E%E8%B7%B5%3C%2FLI%3E%3CLI%3E%E5%8A%A8%E6%80%81%E6%9B%B4%E6%96%B0%E6%97%B6%E5%87%8F%E5%B0%91%E9%97%AA%E7%83%81%E7%9A%84%E6%8A%80%E6%9C%AF%3C%2FLI%3E%3CLI%3E%E4%BD%BF%E7%94%A8%20RTOS%20%E7%8E%AF%E5%A2%83%E4%B8%8E%E8%A3%B8%E6%9C%BA%E7%B3%BB%E7%BB%9F%E6%97%B6%E7%9A%84%E8%A7%82%E5%AF%9F%E7%BB%93%E6%9E%9C%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E4%BB%BB%E4%BD%95%E5%AE%9E%E9%99%85%E8%A7%81%E8%A7%A3%E6%88%96%E8%8C%83%E5%9B%B4%E6%8D%95%E6%8D%89%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
