PCA9541: give bus control?
michelebertoni
On PCA9541 I can select which master takes control of bus, every master can take control of I2C bus.
I need slightly different thing: I'm using PCA9541/03 and I need Master1 to take control of I2C bus, write data into I2C device, then give control to Master0.
I can't program/modify Master0 code, that's why I need to give Master0 control of bus accessing PCA9541 only from Master1.
Is this possible?
Thanks.
Tags (2)
guoweisun
Hi ,
I don't think your opinion can work well about Master take over control.
Each master can only set its related register to take over control the slave bus.
