PCA9541 10-bit address problem
2,286 次查看
yaotienhuang
From PCA9541 spec, the device address can be 0x78 to 0x7C.
However 0x78 to 0x7C are reserved for 10-bit addressing.
So the device address will expand to 0b11110xx 0b1111xxx .
Am I correct?
Thanks.
标记 (1)
3 回复数
2,182 次查看
guoweisun
From PCA9541 spec, the device address can be 0x70 to 0x7F,but from 0x78 to 0x7F is as Reserved I2C-bus addresses must be used with caution.
2,182 次查看
yaotienhuang
Hi G.w,
If my device address is 0x78, does the address will expand to two byte address? Or still one byte address?
i2c-tools only support to 0x77.
Thanks.
2,182 次查看
guoweisun
I don't know why your IIC tool only support 0x77 maximum,but this should be still one byte address.
