PCA2129 RTC interupt not occuring
1,105 次查看
wecunningham
I am using a PCA2129 with a Microchip SAMV71 controller as a master clock for other devices. I am prototyping with a SAMV71 Xplained board and have connected the following pins between the two devices:
SAMV71 EXT1-11 (I2C data) to SDA
SAMV71 EXT1-12 (I2C clock) to SCLK
SAMV71 EXT1-7 (GPIO) to /INT (configured as input with a falling edge interrupt and internal pull-up resistor)
My setup procedure for the PCA2129 is as follows:
  • Send the following data via I2C to configure the RTC chip to enable the 24-hour clock and 1 second interrupt.
    • [I2C address = 0x51, write bit = 0, register = 0x00, data = 0x01, 0x00, 0x00, 15 seconds in BCD, 30 minutes in BCD, 1 hour in BCD]
  • Send the following data via I2C to start the 24-hour clock with 1 second interrupt.
    • [I2C address = 0x51, write bit = 0, register = 0x00, data = 0x01]
  • Send the following data via I2C to set the interrupt to pulse mode instead of requiring manual clearing.
    • [I2C address = 0x51, write bit = 0, register = 0x10, data = 0x20]
  • Perform a test read from the RTC.
    • [I2C address = 0x51, write bit = 0, register = 0x03]
    • [I2C address = 0x51, read bit = 1] and read three bytes
The attached file shows a trace from when I do the above.  The yellow trace is I2C clock the green trace the data and the blue oscilloscope shows the /INT line.  It appears to show a valid read back from the chip.  However, I do not observe any activity on the /INT line—it remains high.
Can you help me understand why the /INT line is not pulsing as expected, or suggest what I might be missing in my setup?
标记 (2)
1,058 次查看
ErikaC
The Control_1 register (0x00) should have the SI (Second Interrupt) bit set if you want a 1-second interrupt. You wrote:
This sets only the STOP bit to 0, but may not enable the SI bit. You might need to write:
[I2C address = 0x51, write bit = 0, register = 0x00, data = 0x21]
If this does not work, please confirm how Control_1 register is configured.
%3CLINGO-SUB%20id%3D%22lingo-sub-2174441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPCA2129%20RTC%20%E4%B8%AD%E6%96%AD%E6%9C%AA%E5%8F%91%E7%94%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20Microchip%20SAMV71%20%E6%8E%A7%E5%88%B6%E5%99%A8%E7%9A%84%20PCA2129%20%E4%BD%9C%E4%B8%BA%E5%85%B6%E4%BB%96%E8%AE%BE%E5%A4%87%E7%9A%84%E4%B8%BB%E6%97%B6%E9%92%9F%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20SAMV71%20Xplained%20%E6%9D%BF%E8%BF%9B%E8%A1%8C%E5%8E%9F%E5%9E%8B%E8%AE%BE%E8%AE%A1%EF%BC%8C%E5%B9%B6%E5%9C%A8%E4%B8%A4%E4%B8%AA%E8%AE%BE%E5%A4%87%E4%B9%8B%E9%97%B4%E8%BF%9E%E6%8E%A5%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%BC%95%E8%84%9A%EF%BC%9A%3C%2FP%3E%3CP%3ESAMV71%20EXT1-11%EF%BC%88I2C%20%E6%95%B0%E6%8D%AE%EF%BC%89%E8%87%B3%20SDA%3CBR%20%2F%3ESAMV71%20EXT1-12%EF%BC%88I2C%20%E6%97%B6%E9%92%9F%EF%BC%89%E8%87%B3%20SCLK%3CBR%20%2F%3ESAMV71%20EXT1-7%EF%BC%88GPIO%EF%BC%89%E8%87%B3%20%2FINT%EF%BC%88%E9%85%8D%E7%BD%AE%E4%B8%BA%E8%BE%93%E5%85%A5%EF%BC%8C%E5%85%B7%E6%9C%89%E4%B8%8B%E9%99%8D%E6%B2%BF%E4%B8%AD%E6%96%AD%E5%92%8C%E5%86%85%E9%83%A8%E4%B8%8A%E6%8B%89%E7%94%B5%E9%98%BB%EF%BC%89%3CBR%20%2F%3E%E6%88%91%E5%AF%B9%20PCA2129%20%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%AD%A5%E9%AA%A4%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E9%80%9A%E8%BF%87%20I2C%20%E5%8F%91%E9%80%81%E4%BB%A5%E4%B8%8B%E6%95%B0%E6%8D%AE%EF%BC%8C%E9%85%8D%E7%BD%AE%20RTC%20%E8%8A%AF%E7%89%87%EF%BC%8C%E5%90%AF%E7%94%A8%2024%20%E5%B0%8F%E6%97%B6%E6%97%B6%E9%92%9F%E5%92%8C%201%20%E7%A7%92%E4%B8%AD%E6%96%AD%E3%80%82%3CUL%3E%3CLI%3E%5BI2C%20%E5%9C%B0%E5%9D%80%20%3D%200x51%EF%BC%8C%E5%86%99%E5%85%A5%E4%BD%8D%20%3D%200%EF%BC%8C%E5%AF%84%E5%AD%98%E5%99%A8%20%3D%200x00%EF%BC%8C%E6%95%B0%E6%8D%AE%20%3D%200x01%E3%80%810x00%E3%80%810x00%E3%80%810x00%EF%BC%8C%E5%9C%A8%20BCD%20%E4%B8%AD%E4%B8%BA%2015%20%E7%A7%92%EF%BC%8C%E5%9C%A8%20BCD%20%E4%B8%AD%E4%B8%BA%2030%20%E5%88%86%E9%92%9F%EF%BC%8C%E5%9C%A8%20BCD%20%E4%B8%AD%E4%B8%BA%201%20%E5%B0%8F%E6%97%B6%5D%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%E9%80%9A%E8%BF%87%20I2C%20%E5%8F%91%E9%80%81%E4%BB%A5%E4%B8%8B%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%BB%A5%201%20%E7%A7%92%E9%92%9F%E4%B8%AD%E6%96%AD%E5%90%AF%E5%8A%A8%2024%20%E5%B0%8F%E6%97%B6%E6%97%B6%E9%92%9F%E3%80%82%3CUL%3E%3CLI%3E%5BI2C%20%E5%9C%B0%E5%9D%80%20%3D%200x51%EF%BC%8C%E5%86%99%E5%85%A5%E4%BD%8D%20%3D%200%EF%BC%8C%E5%AF%84%E5%AD%98%E5%99%A8%20%3D%200x00%EF%BC%8C%E6%95%B0%E6%8D%AE%20%3D%200x01%EF%BC%BD%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%E9%80%9A%E8%BF%87%20I2C%20%E5%8F%91%E9%80%81%E4%BB%A5%E4%B8%8B%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%B0%86%E4%B8%AD%E6%96%AD%E8%AE%BE%E7%BD%AE%E4%B8%BA%E8%84%89%E5%86%B2%E6%A8%A1%E5%BC%8F%EF%BC%8C%E6%97%A0%E9%9C%80%E6%89%8B%E5%8A%A8%E6%B8%85%E9%99%A4%E3%80%82%3CUL%3E%3CLI%3E%5BI2C%20%E5%9C%B0%E5%9D%80%20%3D%200x51%EF%BC%8C%E5%86%99%E5%85%A5%E4%BD%8D%20%3D%200%EF%BC%8C%E5%AF%84%E5%AD%98%E5%99%A8%20%3D%200x10%EF%BC%8C%E6%95%B0%E6%8D%AE%20%3D%200x20%EF%BC%BD%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%E4%BB%8E%20RTC%20%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E8%AF%BB%E5%8F%96%E3%80%82%3CUL%3E%3CLI%3E%5BI2C%20%E5%9C%B0%E5%9D%80%20%3D%200x51%EF%BC%8C%E5%86%99%E5%85%A5%E4%BD%8D%20%3D%200%EF%BC%8C%E5%AF%84%E5%AD%98%E5%99%A8%20%3D%200x03%EF%BC%BD%3C%2FLI%3E%3CLI%3E%5BI2C%20%E5%9C%B0%E5%9D%80%20%3D%200x51%EF%BC%8C%E8%AF%BB%E5%8F%96%E4%BD%8D%20%3D%201%5D%20%E5%B9%B6%E8%AF%BB%E5%8F%96%E4%B8%89%E4%B8%AA%E5%AD%97%E8%8A%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%89%80%E9%99%84%E6%96%87%E4%BB%B6%E6%98%BE%E7%A4%BA%E4%BA%86%E6%88%91%E8%BF%9B%E8%A1%8C%E4%B8%8A%E8%BF%B0%E6%93%8D%E4%BD%9C%E6%97%B6%E7%9A%84%E8%B7%9F%E8%B8%AA%E3%80%82%20%E9%BB%84%E8%89%B2%E8%BD%A8%E8%BF%B9%E6%98%AF%20I2C%20%E6%97%B6%E9%92%9F%EF%BC%8C%E7%BB%BF%E8%89%B2%E8%BD%A8%E8%BF%B9%E6%98%AF%E6%95%B0%E6%8D%AE%EF%BC%8C%E8%93%9D%E8%89%B2%E7%A4%BA%E6%B3%A2%E5%99%A8%E6%98%BE%E7%A4%BA%20%2FINT%20%E7%BA%BF%E3%80%82%20%E5%AE%83%E4%BC%BC%E4%B9%8E%E6%98%BE%E7%A4%BA%E4%BA%86%E8%8A%AF%E7%89%87%E7%9A%84%E6%9C%89%E6%95%88%E5%9B%9E%E8%AF%BB%E3%80%82%20%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E8%A7%82%E5%AF%9F%E5%88%B0%20%2FINT%20%E7%BA%BF%E8%B7%AF%E6%9C%89%E4%BB%BB%E4%BD%95%E6%B4%BB%E5%8A%A8%EF%BC%8C%E5%AE%83%E4%BB%8D%E7%84%B6%E5%A4%84%E4%BA%8E%E9%AB%98%E4%BD%8D%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%B8%AE%E6%88%91%E7%90%86%E8%A7%A3%E4%B8%BA%E4%BB%80%E4%B9%88%20%2FINT%20%E7%BA%BF%E8%B7%AF%E6%B2%A1%E6%9C%89%E6%8C%89%E9%A2%84%E6%9C%9F%E8%84%89%E5%86%B2%EF%BC%8C%E6%88%96%E8%80%85%E5%BB%BA%E8%AE%AE%E6%88%91%E5%9C%A8%E8%AE%BE%E7%BD%AE%E4%B8%AD%E5%8F%AF%E8%83%BD%E7%BC%BA%E5%B0%91%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PCA2129%20RTC%20interupt%20not%20occuring%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%201%20%E7%A7%92%E4%B8%AD%E6%96%AD%EF%BC%8C%E5%88%99%E5%BA%94%E8%AE%BE%E7%BD%AE%20Control_1%20%E5%AF%84%E5%AD%98%E5%99%A8%20(0x00)%20%E7%9A%84%20SI%EF%BC%88%E7%AC%AC%E4%BA%8C%E6%AC%A1%E4%B8%AD%E6%96%AD%EF%BC%89%E4%BD%8D%E3%80%82%E4%BD%A0%E5%86%99%E9%81%93%3C%2FP%3E%0A%3CP%3E%5BI2C%20%E5%9C%B0%E5%9D%80%20%3D%200x51%EF%BC%8C%E5%86%99%E5%85%A5%E4%BD%8D%20%3D%200%EF%BC%8C%E5%AF%84%E5%AD%98%E5%99%A8%20%3D%200x00%EF%BC%8C%E6%95%B0%E6%8D%AE%20%3D%200x01%EF%BC%BD%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E5%8F%AA%E8%83%BD%E5%B0%86%20STOP%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%200%EF%BC%8C%E4%BD%86%E5%8F%AF%E8%83%BD%E6%97%A0%E6%B3%95%E5%90%AF%E7%94%A8%20SI%20%E4%BD%8D%E3%80%82%E4%BD%A0%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E5%86%99%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%5BI2C%E5%9C%B0%E5%9D%80%20%3D%200x51%EF%BC%8C%E5%86%99%E5%85%A5%E4%BD%8D%20%3D%200%EF%BC%8C%E5%AF%84%E5%AD%98%E5%99%A8%20%3D%200x00%EF%BC%8C%E6%95%B0%E6%8D%AE%20%3D%200x21%5D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E8%AF%B7%E7%A1%AE%E8%AE%A4%20Control_1%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%AF%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%E7%9A%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
