PCA2129 RTC interupt not occuring
1,101件の閲覧回数
wecunningham
I am using a PCA2129 with a Microchip SAMV71 controller as a master clock for other devices. I am prototyping with a SAMV71 Xplained board and have connected the following pins between the two devices:
SAMV71 EXT1-11 (I2C data) to SDA
SAMV71 EXT1-12 (I2C clock) to SCLK
SAMV71 EXT1-7 (GPIO) to /INT (configured as input with a falling edge interrupt and internal pull-up resistor)
My setup procedure for the PCA2129 is as follows:
  • Send the following data via I2C to configure the RTC chip to enable the 24-hour clock and 1 second interrupt.
    • [I2C address = 0x51, write bit = 0, register = 0x00, data = 0x01, 0x00, 0x00, 15 seconds in BCD, 30 minutes in BCD, 1 hour in BCD]
  • Send the following data via I2C to start the 24-hour clock with 1 second interrupt.
    • [I2C address = 0x51, write bit = 0, register = 0x00, data = 0x01]
  • Send the following data via I2C to set the interrupt to pulse mode instead of requiring manual clearing.
    • [I2C address = 0x51, write bit = 0, register = 0x10, data = 0x20]
  • Perform a test read from the RTC.
    • [I2C address = 0x51, write bit = 0, register = 0x03]
    • [I2C address = 0x51, read bit = 1] and read three bytes
The attached file shows a trace from when I do the above.  The yellow trace is I2C clock the green trace the data and the blue oscilloscope shows the /INT line.  It appears to show a valid read back from the chip.  However, I do not observe any activity on the /INT line—it remains high.
Can you help me understand why the /INT line is not pulsing as expected, or suggest what I might be missing in my setup?
タグ(2)
1,054件の閲覧回数
ErikaC
The Control_1 register (0x00) should have the SI (Second Interrupt) bit set if you want a 1-second interrupt. You wrote:
This sets only the STOP bit to 0, but may not enable the SI bit. You might need to write:
[I2C address = 0x51, write bit = 0, register = 0x00, data = 0x21]
If this does not work, please confirm how Control_1 register is configured.
%3CLINGO-SUB%20id%3D%22lingo-sub-2174441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPCA2129%20RTC%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81%E4%BB%96%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81Microchip%20SAMV71%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%20PCA2129%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%20SAMV71%20Xplained%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%97%E3%83%AD%E3%83%88%E3%82%BF%E3%82%A4%E3%83%97%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%812%20%E3%81%A4%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E9%96%93%E3%81%A7%E6%AC%A1%E3%81%AE%E3%83%94%E3%83%B3%E3%82%92%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESAMV71%20EXT1-11%EF%BC%88I2C%E3%83%87%E3%83%BC%E3%82%BF%EF%BC%89%E3%81%8B%E3%82%89SDA%3CBR%20%2F%3E%20SAMV71%20EXT1-12%20(I2C%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF)%20%E3%81%8B%E3%82%89%20SCLK%3CBR%20%2F%3E%20SAMV71%20EXT1-7%20(GPIO)%20%E3%81%8B%E3%82%89%20%2FINT%20(%E7%AB%8B%E3%81%A1%E4%B8%8B%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%A8%E5%86%85%E9%83%A8%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E6%8A%B5%E6%8A%97%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E5%85%A5%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90)%3CBR%20%2F%3E%20PCA2129%20%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E6%89%8B%E9%A0%86%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%AC%A1%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%20I2C%20%E7%B5%8C%E7%94%B1%E3%81%A7%E9%80%81%E4%BF%A1%E3%81%97%E3%80%81RTC%20%E3%83%81%E3%83%83%E3%83%97%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%A6%2024%20%E6%99%82%E9%96%93%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%201%20%E7%A7%92%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CUL%3E%3CLI%3E%5BI2C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%3D%200x51%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%93%E3%83%83%E3%83%88%20%3D%200%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%200x00%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%3D%200x01%E3%80%810x00%E3%80%810x00%E3%80%81BCD%E3%81%A715%E7%A7%92%E3%80%81BCD%E3%81%A730%E5%88%86%E3%80%81BCD%E3%81%A71%E6%99%82%E9%96%93%5D%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E1%20%E7%A7%92%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%A7%2024%20%E6%99%82%E9%96%93%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%20I2C%20%E7%B5%8C%E7%94%B1%E3%81%A7%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CUL%3E%3CLI%3E%5BI2C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%3D%200x51%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%93%E3%83%83%E3%83%88%20%3D%200%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%200x00%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%3D%200x01%5D%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E3%83%91%E3%83%AB%E3%82%B9%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%20I2C%20%E7%B5%8C%E7%94%B1%E3%81%A7%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CUL%3E%3CLI%3E%5BI2C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%3D%200x51%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%93%E3%83%83%E3%83%88%20%3D%200%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%200x10%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%3D%200x20%5D%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3ERTC%20%E3%81%8B%E3%82%89%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CUL%3E%3CLI%3E%5BI2C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%3D%200x51%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%93%E3%83%83%E3%83%88%20%3D%200%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%200x03%5D%3C%2FLI%3E%3CLI%3E%5BI2C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%3D%200x51%E3%80%81%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%93%E3%83%83%E3%83%88%20%3D%201%5D%E3%81%A73%E3%83%90%E3%82%A4%E3%83%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E9%BB%84%E8%89%B2%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%81%AF%20I2C%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%80%81%E7%B7%91%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%80%81%E9%9D%92%E3%81%AE%E3%82%AA%E3%82%B7%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%AF%20%2FINT%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%81%E3%83%83%E3%83%97%E3%81%8B%E3%82%89%E3%81%AE%E6%9C%89%E5%8A%B9%E3%81%AA%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E7%B5%90%E6%9E%9C%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%2FINT%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%AF%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%81%8C%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%9A%E3%80%81%E9%AB%98%E3%81%84%E3%81%BE%E3%81%BE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%2FINT%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E3%83%91%E3%83%AB%E3%82%B9%E3%81%97%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8F%E3%81%8B%E3%80%81%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E4%BD%95%E3%81%8C%E6%AC%A0%E3%81%91%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E6%8F%90%E6%A1%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PCA2129%20RTC%20interupt%20not%20occuring%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E1%20%E7%A7%92%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81Control_1%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20(0x00)%20%E3%81%AB%20SI%20(%E7%A7%92%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF)%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%93%E3%81%86%E6%9B%B8%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%0A%3CP%3E%5BI2C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%3D%200x51%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%93%E3%83%83%E3%83%88%20%3D%200%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%200x00%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%3D%200x01%5D%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81STOP%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%81%BF%E3%81%8C%200%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81SI%20%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%98%E8%BF%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3A%3C%2FP%3E%0A%3CP%3E%5BI2C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%3D%200x51%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%93%E3%83%83%E3%83%88%20%3D%200%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%200x00%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%3D%200x21%5D%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81Control_1%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
