OpenIL build failure
6,374 次查看
SH8Lee
Hello! I am currently using NXP LS1021ATSN switch.
And I am trying to build the image of OpenIL 1.11.
As I followed the instructions and execute the build, the following error keeps occuring, and the build fails.
So, can you please help me with this issue?
The OS for host PC is ubuntu 18.04.
Thank, you in advance!
Traceback (most recent call last):
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/mesonmain.py", line 129, in run
return options.run_func(options)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/msetup.py", line 245, in run
app.generate()
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/msetup.py", line 159, in generate
self._generate(env)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/msetup.py", line 192, in _generate
intr.run()
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreter.py", line 4165, in run
super().run()
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 412, in run
self.evaluate_codeblock(self.ast, start=1)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 436, in evaluate_codeblock
raise e
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 430, in evaluate_codeblock
self.evaluate_statement(cur)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 441, in evaluate_statement
return self.function_call(cur)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 788, in function_call
return func(node, posargs, kwargs)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 285, in wrapped
return f(*wrapped_args, **wrapped_kwargs)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 174, in wrapped
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreter.py", line 3687, in func_subdir
self.evaluate_codeblock(codeblock)
raise e
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 443, in evaluate_statement
return self.assignment(cur)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 1064, in assignment
value = self.evaluate_statement(node.value)
[Previous line repeated 2 more times]
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 155, in wrapped
ret = f(*wrapped_args, **wrapped_kwargs)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreter.py", line 3234, in func_dependency
d = self.dependency_impl(name, display_name, kwargs)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreter.py", line 3281, in dependency_impl
dep = dependencies.find_external_dependency(name, self.environment, kwargs)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/dependencies/base.py", line 2236, in find_external_dependency
d = c()
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/dependencies/base.py", line 1110, in __init__
CMakeDependency.class_cmakeinfo[self.for_machine] = self._get_cmake_info()
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/dependencies/base.py", line 1203, in _get_cmake_info
'cmake_root': temp_parser.get_cmake_var('MESON_CMAKE_ROOT')[0],
IndexError: list index out of range
package/pkg-generic.mk:254: recipe for target '/home/shwan2lee/openil/output/build/host-libglib2-2.62.4/.stamp_configured' failed
make: *** [/home/shwan2lee/openil/output/build/host-libglib2-2.62.4/.stamp_configured] Error 2
6,251 次查看
yipingwang
5 回复数
6,331 次查看
yipingwang
OpenIL release is out of date.
Is it possible for you to use Real-Time Edge Software 2.4 for LS1021ATSN?
It could be downloaded from https://www.nxp.com/design/design-center/software/development-software/real-time-edge-software:REALT...
6,325 次查看
SH8Lee
Thank you for your reply.
By the way, for the LS1021ATSN board, if I use the Real Time Edge Software, the TSN standards such as qbv, qav, etc, except for the 802.1AS can't be used according the user guide.
Am I right? Please reply me back again. Thank you!
6,323 次查看
yipingwang
Please refer to the following table for LS1021ATSN support features in Software.
6,257 次查看
SH8Lee
I installed the Real-time Edge Software 2.4 for an iMX8MP evk, and a LS1021ATSN switch, but there are some problems.
First, the switch doesn't have the systemd package, and I can't install it, because when I try to install it through a command "apt install systemd", it says it failed to locate the package systemd.
And without it, I can't follow the demo for time synchronization in the Real-time Edge Software user manual, because it says that a user should use the systemctl command.
Second, when I check the network interfaces through the "ifconfig" command, at first, there is no interface at all, except for the lo interface. As far as I know, the switch has 6 interfaces and 1 br0 interface. However, until I use manual command through "ifconfig ethx up", no interface exists at all, and it is very strange.
Can you help me with it? Attached are the screenshots of the terminal for my switch.
Thanks.
6,252 次查看
yipingwang
%3CLINGO-SUB%20id%3D%22lingo-sub-1892037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOpenIL%20%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1892037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%81%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20NXP%20LS1021ATSN%20%E5%BC%80%E5%85%B3%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E6%9E%84%E5%BB%BA%20OpenIL%201.11%20%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E6%8C%89%E7%85%A7%E8%AF%B4%E6%98%8E%E6%89%A7%E8%A1%8C%E6%9E%84%E5%BB%BA%E6%97%B6%EF%BC%8C%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E4%B8%8D%E6%96%AD%E5%87%BA%E7%8E%B0%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B9%88%EF%BC%8C%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%9C%BAPC%E7%9A%84%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E6%98%AFubuntu%2018.04%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%88%E6%84%9F%E8%B0%A2%E6%82%A8%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9B%9E%E6%BA%AF%EF%BC%88%E6%9C%80%E8%BF%91%E4%B8%80%E6%AC%A1%E8%B0%83%E7%94%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Fmesonmain.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20129%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%E8%BF%90%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3E%E8%BF%94%E5%9B%9E%E9%80%89%E9%A1%B9.run_func%EF%BC%88%E9%80%89%E9%A1%B9%EF%BC%89%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Fmsetup.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20245%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%E8%BF%90%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F.%E7%94%9F%E6%88%90%EF%BC%88%EF%BC%89%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Fmsetup.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20159%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20generate%3CBR%20%2F%3E%E8%87%AA%E6%88%91%E7%94%9F%E6%88%90%EF%BC%88%E7%8E%AF%E5%A2%83%EF%BC%89%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Fmsetup.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20192%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20_generate%20%E4%B8%AD%3CBR%20%2F%3E%E8%BF%90%E8%A1%8C()%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreter.py%E2%80%9D%EF%BC%8C%E7%AC%AC%204165%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%E8%BF%90%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3E%E8%B6%85%E7%BA%A7().%E8%BF%90%E8%A1%8C()%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20412%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%E8%BF%90%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3Eself.evaluate_codeblock%EF%BC%88self.ast%EF%BC%8Cstart%3D1%EF%BC%89%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20436%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20evaluate_codeblock%20%E4%B8%AD%3CBR%20%2F%3E%E6%8F%90%E9%AB%98%20e%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20430%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20evaluate_codeblock%20%E4%B8%AD%3CBR%20%2F%3E%E8%87%AA%E6%88%91%E8%AF%84%E4%BC%B0%E8%AF%AD%E5%8F%A5%EF%BC%88cur%EF%BC%89%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20441%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20evaluate_statement%20%E4%B8%AD%3CBR%20%2F%3E%E8%BF%94%E5%9B%9E%20self.function_call(cur)%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20788%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20function_call%20%E4%B8%AD%3CBR%20%2F%3E%E8%BF%94%E5%9B%9E%E5%87%BD%E6%95%B0%EF%BC%88%E8%8A%82%E7%82%B9%E3%80%81posargs%E3%80%81kwargs%EF%BC%89%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20285%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20wrapping%3CBR%20%2F%3E%E8%BF%94%E5%9B%9E%20f(*wrapped_args%EF%BC%8C**wrapped_kwargs)%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20174%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20wrapping%3CBR%20%2F%3E%E8%BF%94%E5%9B%9E%20f(*wrapped_args%EF%BC%8C**wrapped_kwargs)%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreter.py%E2%80%9D%EF%BC%8C%E7%AC%AC%203687%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20func_subdir%20%E4%B8%AD%3CBR%20%2F%3Eself.evaluate_codeblock%EF%BC%88%E4%BB%A3%E7%A0%81%E5%9D%97%EF%BC%89%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20436%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20evaluate_codeblock%20%E4%B8%AD%3CBR%20%2F%3E%E6%8F%90%E9%AB%98%20e%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20430%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20evaluate_codeblock%20%E4%B8%AD%3CBR%20%2F%3E%E8%87%AA%E6%88%91%E8%AF%84%E4%BC%B0%E8%AF%AD%E5%8F%A5%EF%BC%88cur%EF%BC%89%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20443%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20evaluate_statement%20%E4%B8%AD%3CBR%20%2F%3E%E8%BF%94%E5%9B%9E%20self.assignment(cur)%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%201064%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%E4%BD%9C%E4%B8%9A%E4%B8%AD%3CBR%20%2F%3E%E5%80%BC%20%3D%20%E8%87%AA%E8%BA%AB.evaluate_statement(%E8%8A%82%E7%82%B9.%E5%80%BC)%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20441%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20evaluate_statement%20%E4%B8%AD%3CBR%20%2F%3E%E8%BF%94%E5%9B%9E%20self.function_call(cur)%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20788%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20function_call%20%E4%B8%AD%3CBR%20%2F%3E%E8%BF%94%E5%9B%9E%E5%87%BD%E6%95%B0%EF%BC%88%E8%8A%82%E7%82%B9%E3%80%81posargs%E3%80%81kwargs%EF%BC%89%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20285%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20wrapping%3CBR%20%2F%3E%E8%BF%94%E5%9B%9E%20f(*wrapped_args%EF%BC%8C**wrapped_kwargs)%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20285%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20wrapping%3CBR%20%2F%3E%E8%BF%94%E5%9B%9E%20f(*wrapped_args%EF%BC%8C**wrapped_kwargs)%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20285%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20wrapping%3CBR%20%2F%3E%E8%BF%94%E5%9B%9E%20f(*wrapped_args%EF%BC%8C**wrapped_kwargs)%3CBR%20%2F%3E%20%5B%E4%B8%8A%E4%B8%80%E8%A1%8C%E9%87%8D%E5%A4%8D%E4%B8%A4%E6%AC%A1%5D%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20155%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20wrapping%3CBR%20%2F%3E%20ret%20%3D%20f%EF%BC%88*wrapped_args%EF%BC%8C**wrapped_kwargs%EF%BC%89%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%20174%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20wrapping%3CBR%20%2F%3E%E8%BF%94%E5%9B%9E%20f(*wrapped_args%EF%BC%8C**wrapped_kwargs)%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreter.py%E2%80%9D%EF%BC%8C%E7%AC%AC%203234%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20func_dependency%20%E4%B8%AD%3CBR%20%2F%3Ed%20%3D%20self.dependency_impl(%E5%90%8D%E7%A7%B0%EF%BC%8C%E6%98%BE%E7%A4%BA%E5%90%8D%E7%A7%B0%EF%BC%8Ckwargs%EF%BC%89%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreter.py%E2%80%9D%EF%BC%8Cdependency_impl%20%E4%B8%AD%E7%9A%84%E7%AC%AC%203281%20%E8%A1%8C%3CBR%20%2F%3Edep%20%3D%20%E4%BE%9D%E8%B5%96%E9%A1%B9.find_external_dependency%EF%BC%88%E5%90%8D%E7%A7%B0%EF%BC%8C%E8%87%AA%E6%88%91.%E7%8E%AF%E5%A2%83%2C%E5%A4%B8%E6%A0%BC%E6%96%AF%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Fdependencies%2Fbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%202236%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20find_external_dependency%20%E4%B8%AD%3CBR%20%2F%3Ed%20%3D%20c()%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Fdependencies%2Fbase.py%E2%80%9D%EF%BC%8C%E7%AC%AC%201110%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E__init__%3CBR%20%2F%3E%20CMakeDependency.class_cmakeinfo%5Bself.for_machine%5D%3D%20%E8%87%AA%E6%88%91._get_cmake_info()%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Fdependencies%2Fbase.py%E2%80%9D%EF%BC%8C_get_cmake_info%20%E4%B8%AD%E7%9A%84%E7%AC%AC%201203%20%E8%A1%8C%3CBR%20%2F%3E'cmake_root'%EF%BC%9Atemp_parser.get_cmake_var%EF%BC%88'MESON_CMAKE_ROOT'%EF%BC%89%5B0%5D%EF%BC%8C%3CBR%20%2F%3EIndexError%EF%BC%9A%E5%88%97%E8%A1%A8%E7%B4%A2%E5%BC%95%E8%B6%85%E5%87%BA%E8%8C%83%E5%9B%B4%3CBR%20%2F%3Epackage%2Fpkg-generic.mk%3A254%3A%20%E7%9B%AE%E6%A0%87%E2%80%98%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fbuild%2Fhost-libglib2-2.62.4%2F.stamp_configured%E2%80%99%E7%9A%84%E9%85%8D%E6%96%B9%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3E%E5%88%B6%E4%BD%9C%EF%BC%9A***%20%5B%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fbuild%2Fhost-libglib2-2.62.4%2F.stamp_configured%5D%E9%94%99%E8%AF%AF%202%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1897342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AOpenIL%20%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%B0%86%E5%9C%A8%E6%82%A8%E7%9A%84%E6%96%B0%E5%B8%96%E5%AD%90%E4%B8%AD%E8%AE%A8%E8%AE%BA%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FProblem-of-Real-time-Edge-Software-for-LS1021ATSN%2Fm-p%2F1897321%23M23361%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FProblem-of-Real-time-Edge-Software-for-LS1021ATSN%2Fmp%2F1897321%23M23361%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1897317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AOpenIL%20%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%BA%20iMX8MP%20evk%20%E5%92%8C%20LS1021ATSN%20%E4%BA%A4%E6%8D%A2%E6%9C%BA%E5%AE%89%E8%A3%85%E4%BA%86%20Real-time%20Edge%20Software%202.4%EF%BC%8C%E4%BD%86%E5%AD%98%E5%9C%A8%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E4%BA%A4%E6%8D%A2%E6%9C%BA%E6%B2%A1%E6%9C%89%20systemd%20%E5%8C%85%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%AE%89%E8%A3%85%E5%AE%83%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E9%80%9A%E8%BF%87%E5%91%BD%E4%BB%A4%E2%80%9Capt%20install%20systemd%E2%80%9D%E5%AE%89%E8%A3%85%E5%AE%83%E6%97%B6%EF%BC%8C%E5%AE%83%E8%AF%B4%E6%89%BE%E4%B8%8D%E5%88%B0%E5%8C%85%20systemd%E3%80%82%3C%2FP%3E%3CP%3E%E6%B2%A1%E6%9C%89%E5%AE%83%EF%BC%8C%E6%88%91%E5%B0%B1%E6%97%A0%E6%B3%95%E6%8C%89%E7%85%A7%E5%AE%9E%E6%97%B6%E8%BE%B9%E7%BC%98%E8%BD%AF%E4%BB%B6%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%E4%B8%AD%E7%9A%84%E6%97%B6%E9%97%B4%E5%90%8C%E6%AD%A5%E6%BC%94%E7%A4%BA%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E8%AF%B4%E7%94%A8%E6%88%B7%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20systemctl%20%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B6%E6%AC%A1%EF%BC%8C%E5%BD%93%E6%88%91%E9%80%9A%E8%BF%87%E2%80%9Cifconfig%E2%80%9D%E5%91%BD%E4%BB%A4%E6%A3%80%E6%9F%A5%E7%BD%91%E7%BB%9C%E6%8E%A5%E5%8F%A3%E6%97%B6%EF%BC%8C%E4%B8%80%E5%BC%80%E5%A7%8B%EF%BC%8C%E9%99%A4%E4%BA%86lo%E6%8E%A5%E5%8F%A3%E4%B9%8B%E5%A4%96%EF%BC%8C%E6%A0%B9%E6%9C%AC%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E6%8E%A5%E5%8F%A3%E3%80%82%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E8%AF%A5%E4%BA%A4%E6%8D%A2%E6%9C%BA%E6%9C%896%E4%B8%AA%E6%8E%A5%E5%8F%A3%E5%92%8C1%E4%B8%AAbr0%E6%8E%A5%E5%8F%A3%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E7%9B%B4%E5%88%B0%E6%88%91%E9%80%9A%E8%BF%87%E2%80%9Cifconfig%20ethx%20up%E2%80%9D%E4%BD%BF%E7%94%A8%E6%89%8B%E5%8A%A8%E5%91%BD%E4%BB%A4%E6%97%B6%EF%BC%8C%E6%A0%B9%E6%9C%AC%E4%B8%8D%E5%AD%98%E5%9C%A8%E4%BB%BB%E4%BD%95%E6%8E%A5%E5%8F%A3%EF%BC%8C%E8%BF%99%E5%BE%88%E5%A5%87%E6%80%AA%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%B9%AB%E6%88%91%E5%97%8E%EF%BC%9F%E9%99%84%E4%BB%B6%E6%98%AF%E6%88%91%E7%9A%84%E4%BA%A4%E6%8D%A2%E6%9C%BA%E7%BB%88%E7%AB%AF%E7%9A%84%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1894786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AOpenIL%20%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1894786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E5%8F%A5%EF%BC%8C%E5%AF%B9%E4%BA%8E%20LS1021ATSN%20%E6%9D%BF%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E4%BD%BF%E7%94%A8%E5%AE%9E%E6%97%B6%E8%BE%B9%E7%BC%98%E8%BD%AF%E4%BB%B6%EF%BC%8C%E5%88%99%E6%A0%B9%E6%8D%AE%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%EF%BC%8C%E9%99%A4%20802.1AS%20%E4%B9%8B%E5%A4%96%E7%9A%84%20qbv%E3%80%81qav%20%E7%AD%89%20TSN%20%E6%A0%87%E5%87%86%E9%83%BD%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%AF%B4%E5%BE%97%E5%AF%B9%E5%90%97%EF%BC%9F%E8%AF%B7%E5%86%8D%E6%AC%A1%E5%9B%9E%E5%A4%8D%E6%88%91%E3%80%82%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1894277%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AOpenIL%20%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1894277%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOpenIL%20%E7%89%88%E6%9C%AC%E5%B7%B2%E8%BF%87%E6%97%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%86%3CSPAN%3EReal-Time%20Edge%20Software%202.4%20%E7%94%A8%E4%BA%8E%20LS1021ATSN%20%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%8F%AF%E4%BB%A5%E4%BB%8E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Freal-time-edge-software%3AREALTIME-EDGE-SOFTWARE%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Freal-time-edge-software%3AREALTIME-EDGE-SOFTWARE%3C%2FA%3E%E4%B8%8B%E8%BD%BD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
