OpenIL build failure
6,377件の閲覧回数
SH8Lee
Hello! I am currently using NXP LS1021ATSN switch.
And I am trying to build the image of OpenIL 1.11.
As I followed the instructions and execute the build, the following error keeps occuring, and the build fails.
So, can you please help me with this issue?
The OS for host PC is ubuntu 18.04.
Thank, you in advance!
Traceback (most recent call last):
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/mesonmain.py", line 129, in run
return options.run_func(options)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/msetup.py", line 245, in run
app.generate()
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/msetup.py", line 159, in generate
self._generate(env)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/msetup.py", line 192, in _generate
intr.run()
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreter.py", line 4165, in run
super().run()
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 412, in run
self.evaluate_codeblock(self.ast, start=1)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 436, in evaluate_codeblock
raise e
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 430, in evaluate_codeblock
self.evaluate_statement(cur)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 441, in evaluate_statement
return self.function_call(cur)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 788, in function_call
return func(node, posargs, kwargs)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 285, in wrapped
return f(*wrapped_args, **wrapped_kwargs)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 174, in wrapped
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreter.py", line 3687, in func_subdir
self.evaluate_codeblock(codeblock)
raise e
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 443, in evaluate_statement
return self.assignment(cur)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 1064, in assignment
value = self.evaluate_statement(node.value)
[Previous line repeated 2 more times]
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreterbase.py", line 155, in wrapped
ret = f(*wrapped_args, **wrapped_kwargs)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreter.py", line 3234, in func_dependency
d = self.dependency_impl(name, display_name, kwargs)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/interpreter.py", line 3281, in dependency_impl
dep = dependencies.find_external_dependency(name, self.environment, kwargs)
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/dependencies/base.py", line 2236, in find_external_dependency
d = c()
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/dependencies/base.py", line 1110, in __init__
CMakeDependency.class_cmakeinfo[self.for_machine] = self._get_cmake_info()
File "/home/shwan2lee/openil/output/host/lib/python3.8/site-packages/mesonbuild/dependencies/base.py", line 1203, in _get_cmake_info
'cmake_root': temp_parser.get_cmake_var('MESON_CMAKE_ROOT')[0],
IndexError: list index out of range
package/pkg-generic.mk:254: recipe for target '/home/shwan2lee/openil/output/build/host-libglib2-2.62.4/.stamp_configured' failed
make: *** [/home/shwan2lee/openil/output/build/host-libglib2-2.62.4/.stamp_configured] Error 2
6,254件の閲覧回数
yipingwang
5 返答(返信)
6,334件の閲覧回数
yipingwang
OpenIL release is out of date.
Is it possible for you to use Real-Time Edge Software 2.4 for LS1021ATSN?
It could be downloaded from https://www.nxp.com/design/design-center/software/development-software/real-time-edge-software:REALT...
6,328件の閲覧回数
SH8Lee
Thank you for your reply.
By the way, for the LS1021ATSN board, if I use the Real Time Edge Software, the TSN standards such as qbv, qav, etc, except for the 802.1AS can't be used according the user guide.
Am I right? Please reply me back again. Thank you!
6,326件の閲覧回数
yipingwang
Please refer to the following table for LS1021ATSN support features in Software.
6,260件の閲覧回数
SH8Lee
I installed the Real-time Edge Software 2.4 for an iMX8MP evk, and a LS1021ATSN switch, but there are some problems.
First, the switch doesn't have the systemd package, and I can't install it, because when I try to install it through a command "apt install systemd", it says it failed to locate the package systemd.
And without it, I can't follow the demo for time synchronization in the Real-time Edge Software user manual, because it says that a user should use the systemctl command.
Second, when I check the network interfaces through the "ifconfig" command, at first, there is no interface at all, except for the lo interface. As far as I know, the switch has 6 interfaces and 1 br0 interface. However, until I use manual command through "ifconfig ethx up", no interface exists at all, and it is very strange.
Can you help me with it? Attached are the screenshots of the terminal for my switch.
Thanks.
6,255件の閲覧回数
yipingwang
%3CLINGO-SUB%20id%3D%22lingo-sub-1892037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOpenIL%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%A4%B1%E6%95%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1892037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%E7%8F%BE%E5%9C%A8%E3%80%81NXP%20LS1021ATSN%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81OpenIL%201.11%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%83%9B%E3%82%B9%E3%83%88PC%E3%81%AEOS%E3%81%AFubuntu%2018.04%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF(%E6%9C%80%E5%BE%8C%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97)%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Fmesonmain.py%E3%80%8D129%E5%8F%B7%E7%B7%9A%E3%80%81%E5%AE%9F%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3E%E3%83%AA%E3%82%BF%E3%83%BC%E3%83%B3options.run_func(%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Fmsetup.py%E3%80%8D245%E5%8F%B7%E7%B7%9A%E3%80%81%E5%AE%9F%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3Eapp.generate()%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Fmsetup.py%E3%80%8D159%E8%A1%8C%E7%9B%AE%E3%80%81%E7%94%9F%E6%88%90%3CBR%20%2F%3Eself._generate(%E7%92%B0%E5%A2%83)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Fmsetup.py%E3%80%8D192%E8%A1%8C%E7%9B%AE%E3%80%81_generate%E5%B9%B4%3CBR%20%2F%3Eintr.run()%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreter.py%E3%80%8D4165%E8%A1%8C%E7%9B%AE%E3%80%81%E5%AE%9F%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3Esuper().run()%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D412%E5%8F%B7%E7%B7%9A%E3%80%81%E5%AE%9F%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3Eself.evaluate_codeblock(self.ast%2C%20start%3D1)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D436%E8%A1%8C%E7%9B%AE%E3%80%81evaluate_codeblock%3CBR%20%2F%3E%E3%83%AC%E3%82%A4%E3%82%BA%20E%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D430%E8%A1%8C%E7%9B%AE%E3%80%81evaluate_codeblock%3CBR%20%2F%3Eself.evaluate_statement(cur)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D441%E8%A1%8C%E7%9B%AE%E3%80%81evaluate_statement%E5%B9%B4%3CBR%20%2F%3E%E3%83%AA%E3%82%BF%E3%83%BC%E3%83%B3self.function_call(cur)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D788%E5%8F%B7%E7%B7%9A%E3%80%81function_call%E5%B9%B4%3CBR%20%2F%3Ereturn%20func(%E3%83%8E%E3%83%BC%E3%83%89%2C%20posargs%2C%20kwargs)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D285%E8%A1%8C%E7%9B%AE%E3%80%81%E6%8A%98%E3%82%8A%E8%BF%94%E3%81%97%3CBR%20%2F%3E%E6%88%BB%E3%82%8A%E5%80%A4%20f(*wrapped_args%2C%20**wrapped_kwargs)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D174%E8%A1%8C%E7%9B%AE%E3%80%81%E6%8A%98%E3%82%8A%E8%BF%94%E3%81%97%3CBR%20%2F%3E%E6%88%BB%E3%82%8A%E5%80%A4%20f(*wrapped_args%2C%20**wrapped_kwargs)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreter.py%E3%80%8D3687%E8%A1%8C%E7%9B%AE%E3%80%81func_subdir%E5%B9%B4%3CBR%20%2F%3Eself.evaluate_codeblock(%E3%82%B3%E3%83%BC%E3%83%89%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D436%E8%A1%8C%E7%9B%AE%E3%80%81evaluate_codeblock%3CBR%20%2F%3E%E3%83%AC%E3%82%A4%E3%82%BA%20E%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D430%E8%A1%8C%E7%9B%AE%E3%80%81evaluate_codeblock%3CBR%20%2F%3Eself.evaluate_statement(cur)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D443%E8%A1%8C%E7%9B%AE%E3%80%81evaluate_statement%E5%B9%B4%3CBR%20%2F%3Eself.assignment(cur)%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D1064%E8%A1%8C%E7%9B%AE%E3%80%81%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E4%B8%AD%3CBR%20%2F%3E%E5%80%A4%20%3D%20self.evaluate_statement(node.value)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D441%E8%A1%8C%E7%9B%AE%E3%80%81evaluate_statement%E5%B9%B4%3CBR%20%2F%3E%E3%83%AA%E3%82%BF%E3%83%BC%E3%83%B3self.function_call(cur)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D788%E5%8F%B7%E7%B7%9A%E3%80%81function_call%E5%B9%B4%3CBR%20%2F%3Ereturn%20func(%E3%83%8E%E3%83%BC%E3%83%89%2C%20posargs%2C%20kwargs)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D285%E8%A1%8C%E7%9B%AE%E3%80%81%E6%8A%98%E3%82%8A%E8%BF%94%E3%81%97%3CBR%20%2F%3E%E6%88%BB%E3%82%8A%E5%80%A4%20f(*wrapped_args%2C%20**wrapped_kwargs)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D285%E8%A1%8C%E7%9B%AE%E3%80%81%E6%8A%98%E3%82%8A%E8%BF%94%E3%81%97%3CBR%20%2F%3E%E6%88%BB%E3%82%8A%E5%80%A4%20f(*wrapped_args%2C%20**wrapped_kwargs)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D285%E8%A1%8C%E7%9B%AE%E3%80%81%E6%8A%98%E3%82%8A%E8%BF%94%E3%81%97%3CBR%20%2F%3E%E6%88%BB%E3%82%8A%E5%80%A4%20f(*wrapped_args%2C%20**wrapped_kwargs)%3CBR%20%2F%3E%5B%E5%89%8D%E3%81%AE%E8%A1%8C%E3%81%8C%E3%81%95%E3%82%89%E3%81%AB2%E5%9B%9E%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%95%E3%82%8C%E3%82%8B%5D%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D155%E8%A1%8C%E7%9B%AE%E3%80%81%E6%8A%98%E3%82%8A%E8%BF%94%E3%81%97%3CBR%20%2F%3Eret%20%3D%20f(*wrapped_args%2C%20**wrapped_kwargs)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreterbase.py%E3%80%8D174%E8%A1%8C%E7%9B%AE%E3%80%81%E6%8A%98%E3%82%8A%E8%BF%94%E3%81%97%3CBR%20%2F%3E%E6%88%BB%E3%82%8A%E5%80%A4%20f(*wrapped_args%2C%20**wrapped_kwargs)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreter.py%E3%80%8D3234%E8%A1%8C%E7%9B%AE%E3%80%81func_dependency%3CBR%20%2F%3Ed%20%3D%20self.dependency_impl(%E5%90%8D%E5%89%8D%2Cdisplay_name%E3%80%81kwargs)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Finterpreter.py%E3%80%8D3281%E8%A1%8C%E7%9B%AE%E3%80%81dependency_impl%E5%B9%B4%3CBR%20%2F%3Edep%20%3D%20dependencies.find_external_dependency(%E5%90%8D%E5%89%8D%2Cself.environment%E3%80%81kwargs)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Fdependencies%2Fbase.py%E3%80%8D2236%E8%A1%8C%E7%9B%AE%E3%80%81find_external_dependency%E5%B9%B4%3CBR%20%2F%3Ed%20%3D%20c()%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Fdependencies%2Fbase.py%E3%80%8D1110%E8%A1%8C%E7%9B%AE%E3%80%81__init__%E5%B9%B4%3CBR%20%2F%3ECMakeDependency.class_cmakeinfo%5Bself.for_machine%5D%3D%20self._get_cmake_info()%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fhost%2Flib%2Fpython3.8%2Fsite-packages%2Fmesonbuild%2Fdependencies%2Fbase.py%E3%80%8D1203%E8%A1%8C%E7%9B%AE%E3%80%81_get_cmake_info%E5%B9%B4%3CBR%20%2F%3E'cmake_root'%3A%20temp_parser.get_cmake_var('MESON_CMAKE_ROOT')%5B0%5D%2C%3CBR%20%2F%3EIndexError%3A%20%E3%83%AA%E3%82%B9%E3%83%88%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%81%8C%E7%AF%84%E5%9B%B2%E5%A4%96%E3%81%A7%E3%81%99%3CBR%20%2F%3Epackage%2Fpkg-generic.mk%3A254%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20'%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fbuild%2Fhost-libglib2-2.62.4%2F.stamp_configured'%20%E3%81%AE%E3%83%AC%E3%82%B7%E3%83%94%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E4%BD%9C%E3%82%8B%3A%20***%20%5B%2Fhome%2Fshwan2lee%2Fopenil%2Foutput%2Fbuild%2Fhost-libglib2-2.62.4%2F.stamp_configured%5D%E3%82%A8%E3%83%A9%E3%83%BC%202%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1897342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenIL%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%A4%B1%E6%95%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%A7%E8%AD%B0%E8%AB%96%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FProblem-of-Real-time-Edge-Software-for-LS1021ATSN%2Fm-p%2F1897321%23M23361%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FProblem-of-Real-time-Edge-Software-for-LS1021ATSN%2Fm-p%2F1897321%23M23361%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1897317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenIL%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%A4%B1%E6%95%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EiMX8MP%20evk%E7%94%A8%E3%81%AEReal-time%20Edge%20Software%202.4%E3%81%A8LS1021ATSN%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AB%E3%81%AFsystemd%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%81%E3%80%8Capt%20install%20systemd%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8systemd%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81Real-time%20Edge%20Software%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%82%E3%82%8B%E6%99%82%E9%96%93%E5%90%8C%E6%9C%9F%E3%81%AE%E3%83%87%E3%83%A2%E3%81%AB%E5%BE%93%E3%81%86%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%AA%E3%81%9C%E3%81%AA%E3%82%89%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AFsystemctl%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%80%8Cifconfig%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AFlo%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%82%92%E9%99%A4%E3%81%84%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%8C%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AE%E7%9F%A5%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AB%E3%81%AF6%E3%81%A4%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%A81%E3%81%A4%E3%81%AEbr0%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%22ifconfig%20ethx%20up%22%E3%81%A7%E6%89%8B%E5%8B%95%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E3%81%86%E3%81%BE%E3%81%A7%E3%81%AF%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%8C%E5%85%A8%E3%81%8F%E5%AD%98%E5%9C%A8%E3%81%9B%E3%81%9A%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%A5%87%E5%A6%99%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E7%AB%AF%E6%9C%AB%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%8C%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1894786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenIL%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%A4%B1%E6%95%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1894786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81LS1021ATSN%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81Real%20Time%20Edge%20Software%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81802.1AS%E4%BB%A5%E5%A4%96%E3%81%AEqbv%E3%80%81qav%E3%81%AA%E3%81%A9%E3%81%AETSN%E8%A6%8F%E6%A0%BC%E3%81%AF%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%86%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E8%BF%94%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1894277%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenIL%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%A4%B1%E6%95%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1894277%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOpenIL%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%8C%E5%8F%A4%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EReal-Time%20Edge%20Software%202.4%20for%20LS1021ATSN%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Freal-time-edge-software%3AREALTIME-EDGE-SOFTWARE%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Freal-time-edge-software%3AREALTIME-EDGE-SOFTWARE%3C%2FA%3E%20%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
