Need Help for Linux Kernel support - SC16IS762 - provide any documentation to do this
1,717 次查看
mohanmts
am trying to use SC16IS762 with high transfer speed spi - is there any way to make it work
3 回复数
1,695 次查看
diazmarin09
Hello Mohanasundaram,
Therefore, based on your last response, you are within the SPI dynamic parameters. The SC16IS762 device supports SPI clock speeds up to 15 Mbit/s.
In this case, could you please share a detailed description of your issue? Are you able to interface with the device?
You may find a SC16IS750_Linux driver attached. I do recommend to use it as a reference for your design.
David
1,709 次查看
mohanmts
Yes these are well within the range. Am using 3.3v params.
1,712 次查看
diazmarin09
I hope all is great with you.
What is the SPI data rate used in your application? Are you within the parameters mentioned below?
David
