Need Help for Linux Kernel support - SC16IS762 - provide any documentation to do this
mohanmts
am trying to use SC16IS762 with high transfer speed spi - is there any way to make it work
diazmarin09
Hello Mohanasundaram,
Therefore, based on your last response, you are within the SPI dynamic parameters. The SC16IS762 device supports SPI clock speeds up to 15 Mbit/s.
In this case, could you please share a detailed description of your issue? Are you able to interface with the device?
You may find a SC16IS750_Linux driver attached. I do recommend to use it as a reference for your design.
David
mohanmts
Yes these are well within the range. Am using 3.3v params.
diazmarin09
I hope all is great with you.
What is the SPI data rate used in your application? Are you within the parameters mentioned below?
David
