NXP RTC PCF8563 Technical issue
2,381 次查看
chenhuang
When commissioning PCF8563T, the customer found that VL bit of VL_seconds register of some chips was read as 0 when it was powered on for the first time. Theoretically, it should be 1.
The hardware side of the customer has done the timing test, and confirmed that there is no problem with the IIC timing. The hardware iic is used for communication. Not all chips are like this, and some chips have this phenomenon. Please help
Take a look at how to locate the problem and solve the customer's problem, and give some suggestions or doubts, thank you!
2,374 次查看
guoweisun
尝试让客户power on以后等600ms再去通信。
2,373 次查看
chenhuang
好的,我这边让客户去尝试验证下,谢谢
