NXP RADAR Toolbox License Error
3,980 次查看
robert10
I followed the quick start guide for the "NXP Radar Toolbox for S32R" and created a license according to my volume serial number. I copied it into the correct folder. But when I push the button "Verify RADAR Toolbox License", the message "No valid license file has been found".
Any ideas?
标记 (2)
6 回复数
3,208 次查看
Vamsi_Sirigina
any solution for above question , i have been facing same challenge  in verifying license
3,620 次查看
wennerbai
hello robert
I am faced  the same question as you. How did you finally solve it? can you help me?
3,942 次查看
robert10
Btw, if I execute "switch_spt", I get the error "Error code is -5, and error message is: No such feature exists."
3,947 次查看
petervlna
I can see that license generation on our server was correct.
But radar toolbox for some reason is not verifying your correct license. Your license is for S32 SPT 2.x 1.5.0.
Do you have correct version installed?
There is a separate forum for Model based design toolbox, where they will be able to tell you more about your issue:
https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/bd-p/mbdt
Peter
3,947 次查看
petervlna
Peter
3,943 次查看
robert10
Thank you for this answer!
I have installed the version 1.5.1, since I've read that the license should work for all versions(?), and I use Matlab 2021a.
Robert
