I need help in this domain I am out for decades now. I have a Keil MCB2370 board (along with ULIN2 JTAG) I would like to put to an educative use. However, after 4 weeks of intensive communication with Keil Support we have concluded that it is not possible to activate Keil's MDK in its LICensing context:
* for the original MDK 3 it is no longer possible to obtain LICense
* current versions 5.xx do not provide backwrds support for the legacy boards
* use of older ARM Compiler 5 is prohibited within the available MDK versions
So I am looking for ARM7 IDE and toolchain that can compile and download code for LPC2378 based evaluation board (MCB2300). I have the followinf questions:
* will LPCXpresso ver 8.2.2 work with my MCB2370 board? - if not, which one?
* what does "debug download limit of 256KB" mean for the compiled code size?
* will ULINK2 work with this IDE?
Anything specific I should be aware of?
Thank you in advance,
