MRFE6VP6300H Noise Parameters, Non linear model, and AWR resource
676件の閲覧回数
RF_noob
Hi all,
I am working with MREF6VP6300H. I am running into some problems. I could not find a touchstone file with noise parameter. Where can I find it?
Also, is there a way to find the non linear model file for simulation.
I use AWR. Does AWR resource file is sufficient for the questions above (instead of using the s2p file)?
Thanks in advance!
  • RF
647件の閲覧回数
ErikaC
I am afraid we do not have S-parameters with noise. We apologize for any inconvenience this may cause you.
You can find the AWR model in the following link: https://www.nxp.com/products/radio-frequency/rf-high-power-models/models-for-cadence-awr-microwave-o...
And the ADS model in the following link: https://www.nxp.com/products/radio-frequency/rf-high-power-models/models-for-ads-keysight-advanced-d...
Hope this helps.
2 返答(返信)
630件の閲覧回数
RF_noob
Thanks for the reply! I will use the AWR model for non-linear simulation then.
648件の閲覧回数
ErikaC
Hope this helps.
