Hi all,
I am working with MREF6VP6300H. I am running into some problems. I could not find a touchstone file with noise parameter. Where can I find it?
Also, is there a way to find the non linear model file for simulation.
I use AWR. Does AWR resource file is sufficient for the questions above (instead of using the s2p file)?
Thanks in advance!
Solved! Go to Solution.
I am afraid we do not have S-parameters with noise. We apologize for any inconvenience this may cause you.
You can find the AWR model in the following link: https://www.nxp.com/products/radio-frequency/rf-high-power-models/models-for-cadence-awr-microwave-o...
And the ADS model in the following link: https://www.nxp.com/products/radio-frequency/rf-high-power-models/models-for-ads-keysight-advanced-d...
Hope this helps.
Thanks for the reply! I will use the AWR model for non-linear simulation then.
Hope this helps.
