MPX5700GP Pressure Sensor
982 次查看
Anlo
MPX5700GP  Series 700 kpa 5.25 V 2.5 % Analog Output, Is there any higher accuracy,i want to find 1%accuracy
979 次查看
TomasVaverka
Hi Jorgen,
There is no other pressure sensor in our portfolio with the same pressure range and higher accuracy. However, the offset error can be reduced using an auto-zero technique as described in the AN1636.
Tomas
