MPC8313eRDB REVA4
MPC8313eRDB REVA4
2,377 次查看
admin
Specialist II
Dear all,
Now I use  MPC8313eRDB REVA4 board.I tried to use MPC8313E_RDB_K26_20080613 BSP on my board.The problem took place that the Marvell's PHY could not work.I would like to known if the MPC8313E_RDB_K26_20080613 BSP can beed used on MPC8313eRDB REVA4 board?if not,I would like to know why?
Thanks.
3 回复数
1,577 次查看
admin
Specialist II
You need the REVB RDB board to use that BSP.
-joe
1,576 次查看
Veiga
I think i have the same problem. Marvell's PHY can't work on linux (uboot is ok). I am trying to use MPC8313E_RDB_K26_20081226 on my MPC8313eRDB REVA3 board... and I thought it was back-compatible. Is it not?
Where can i found a BSP compatible with my board revision?
Thanks for any help.
-veiga
1,577 次查看
Veiga
It works with MPC8313E_RDB_K26_20070831.
I think MPC8313E_RDB_K26_20081226 is not compatible with REVA boards!
-veiga
