MPC560P CodeCode program running away
1,657件の閲覧回数
xudb
Hi everybody:
    My product is experiencing a problem: My code has a struct,like "typedef struct {
INT32U canid;
INT8U rxCode;
INT8U IDE; //
INT8U RTR; //
INT8U DLC; //
INT8U Data[8]; //
//INT8U res; //
}CAN_MSG_T; And I have define a can rx buf and tx buf to recv / trans the data from can int, when THIS struct has "INT8U res" ,the code run OK, but, when NOT, it will RUN AWAY, I dont know why ,does anybody Encounter similar problems?? How CAN I DEBUG IT to fix it? I USED codewarrior is too old to debug any question, I JUST only PRINT LOG TO UART to watch current mcu stat.
1,635件の閲覧回数
PetrS
hard to suggest anything, you need to debug your application and find a place where code goes away.
You can find some example within https://www.nxp.com/docs/en/application-note/AN2865.pdf or e.g. https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/Example-TRK-MPC5604P-Initialization-of-SBC-chip-...
BR, Petr
1,636件の閲覧回数
PetrS
BR, Petr
1,617件の閲覧回数
xudb
Hi PetrS:
     Thanks for your Help, My problem has been solved, it was caused by the MB headers start address  in the flexray cfg hw struct val, is in internal_ram range which is in lcf file , I change the lcf and the addr, and it dont appear again. Finally ,thanks very much again!
%3CLINGO-SUB%20id%3D%22lingo-sub-1876859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPC560P%20CodeCode%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8C%E9%80%83%E3%81%92%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1876859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%A7%81%E3%81%AE%E8%A3%BD%E5%93%81%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20%E7%A7%81%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%20%22typedef%20struct%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EINT32U%20canid%3B%26nbsp%3B%3C%2FP%3E%3CP%3EINT8U%20rxCode%3B%3CBR%20%2F%3EINT8U%20IDE%3B%20%2F%2F%3CBR%20%2F%3EINT8U%20RTR%3B%20%2F%2F%3CBR%20%2F%3EINT8U%20DLC%3B%20%2F%2F%26nbsp%3B%3C%2FP%3E%3CP%3EINT8U%20Data%5B8%5D%3B%20%2F%2F%3CBR%20%2F%3E%2F%2FINT8U%20res%3B%20%2F%2F%3C%2FP%3E%3CP%3E%7DCAN_MSG_T%3B%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E7%A7%81%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E6%A7%8B%E9%80%A0%E4%BD%93%E3%81%8C%20%22INT8U%20res%22%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AFOK%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E9%80%83%E3%81%92%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%AF%E3%81%AA%E3%81%9C%E7%9F%A5%E3%82%89%E3%81%AA%E3%81%84%E3%80%81%E8%AA%B0%E3%81%8B%E3%81%8C%3CSPAN%3E%E5%90%8C%E6%A7%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AFcodewarrior%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E8%B3%AA%E5%95%8F%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E5%8F%A4%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AEMCU%E7%B5%B1%E8%A8%88%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABUART%E3%81%AB%E3%83%AD%E3%82%B0%E3%82%92%E5%8D%B0%E5%88%B7%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1880180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMPC560P%20CodeCode%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8C%E6%9A%B4%E8%B5%B0%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1880180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20PetrS%3A%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%8A%A9%E3%81%91%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%20%3CSPAN%3E%E7%A7%81%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AFflexray%20cfg%20hw%20struct%20val%E3%81%AEMB%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E9%96%8B%E5%A7%8B%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81lcf%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%82%E3%82%8Binternal_ram%E7%AF%84%E5%9B%B2%E5%86%85%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%AFlcf%E3%81%A8addr%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E5%86%8D%E3%81%B3%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%81%E6%94%B9%E3%82%81%E3%81%A6%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F!%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1878949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMPC560P%20CodeCode%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8C%E6%9A%B4%E8%B5%B0%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1878949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E4%BD%95%E3%81%8B%E3%82%92%E6%8F%90%E6%A1%88%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E9%9B%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%A6%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E6%B6%88%E3%81%88%E3%82%8B%E5%A0%B4%E6%89%80%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2865.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%20https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2865.pdf%3C%2FA%3E%20%E5%86%85%E3%81%BE%E3%81%9F%E3%81%AF%E4%BE%8B%E3%81%88%E3%81%B0%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E4%BE%8B%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMPC5xxx-Knowledge-Base%2FExample-TRK-MPC5604P-Initialization-of-SBC-chip-MC33905-and%2Fta-p%2F1100198%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMPC5xxx-Knowledge-Base%2FExample-TRK-MPC5604P-Initialization-of-SBC-chip-MC33905-and%2Fta-p%2F1100198%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E
