MIMXRT1176 ADP – SEGGER J-Link debugging issue
HasanIqbalKhan
Hi everyone,
I am currently working with the MIMXRT1176 / i.MX RT1170 platform. I initially used the MIMXRT1170-EVKB for development, but have now shifted to the MIMXRT1176-ADP for interfacing a parallel RGB panel.
I am facing an issue with SEGGER J-Link debugging on the ADP board.
Environment:
  • Board: MIMXRT1176-ADP
  • Board revision: 700-51950 REV A1
  • Schematic revision: SCH-51950 REV B1
  • MCUXpresso IDE: v25.6.136
  • MCUXpresso SDK: v25.09.00
  • SEGGER J-Link: latest version
On the EVKB, both J-Link and LinkServer worked without any issues. However, on the ADP:
  • Firmware flashes successfully.
  • Debugger reaches the first line of main().
  • If I Step Over once, it stops at:
Break at address "0xdeadbeee" with no debug information available, or outside of program code.
  • Breakpoints at other locations work and are hit correctly.
  • However, Resume/Continue from a breakpoint again results in 0xDEADBEEE.
Could someone please confirm whether J-Link is fully supported with MCUXpresso IDE on the MIMXRT1176-ADP, and whether there is any specific J-Link script, reset/debug configuration, or ADP-specific initialization required?
Could this be related to the memory configuration, external flash/SDRAM, or startup code on the ADP?
Any guidance or working J-Link configuration for the ADP would be greatly appreciated.
Thanks!
Gavin_Jia
Hi @HasanIqbalKhan ,
Thanks for your questions!
As far as I know, when using JLink with the RT1170-ADP in MCUXpresso IDE, only "attach" is supported while direct debugging is not supported. This is likely a support issue with the JLink flashloader. In IAR, this issue has been resolved. We apologize for any inconvenience this may cause.
Gavin
HasanIqbalKhan
Is it possible to use debug via USB (J33) ?
HasanIqbalKhan
One more thing I tried, I connected an external MCU-Link and then tried debugging via the LinkServer in MCUXpresso IDE.
The Execution reached main, I am able to step through from there, but when I try to resume execution it gives "Break at address "0x0" with no debug information available, or outside of program code.", and sometimes when I try to restart execution, it gives "Break at address "0x2230c8" with no debug information available, or outside of program code."
For reference I am trying to run the "MIMXRT1176_dashboard_bt_ble_multiprofile" project, SW1 on the board is set to 01 and SW5 on the board is set to 000000000000.
I tried to test with MCU-Link because the EVKB board uses the same and works fine.
Also I do not think we can use Jlink, as it is clearly mentioned on their website that there is no support for octal flash, which the ADP board uses.
Thanks.
Gavin_Jia
1. J33 is USB-OTG1 and cannot be used for debugging.
2. It’s not that JLink doesn’t support Octal Flash; it’s just that by default, it only recognizes the flash found on the EVK/EVKB. As for IAR, this is because a corresponding download algorithm is provided. If you’re interested in this topic, you can refer to the RT-UFL project.
3. For information on current debugger/IDE support, please refer to: AN14387: https://docs.nxp.com/bundle/AN14378/page/topics/download_images_to_ADP_board.html
Gavin
%3CLINGO-SUB%20id%3D%22lingo-sub-2414987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMIMXRT1176%20ADP%20%E2%80%93%20SEGGER%20J-Link%20debugging%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2414987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EHi%20everyone%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EI%20am%20currently%20working%20with%20the%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3EMIMXRT1176%20%2F%20i.MX%20RT1170%20platform%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E.%20I%20initially%20used%20the%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3EMIMXRT1170-EVKB%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%20for%20development%2C%20but%20have%20now%20shifted%20to%20the%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3EMIMXRT1176-ADP%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%20for%20interfacing%20a%20parallel%20RGB%20panel.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EI%20am%20facing%20an%20issue%20with%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3ESEGGER%20J-Link%20debugging%20on%20the%20ADP%20board%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%3EEnvironment%3A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%3EBoard%3A%20MIMXRT1176-ADP%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EBoard%20revision%3A%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3E700-51950%20REV%20A1%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3ESchematic%20revision%3A%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3ESCH-51950%20REV%20B1%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EMCUXpresso%20IDE%3A%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3Ev25.6.136%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EMCUXpresso%20SDK%3A%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3Ev25.09.00%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3ESEGGER%20J-Link%3A%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3Elatest%20version%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EOn%20the%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3EEVKB%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%2C%20both%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3EJ-Link%20and%20LinkServer%20worked%20without%20any%20issues%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E.%20However%2C%20on%20the%20ADP%3A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%3EFirmware%20flashes%20successfully.%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EDebugger%20reaches%20the%20first%20line%20of%20%3C%2FSPAN%3E%3CSPAN%3Emain()%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EIf%20I%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3EStep%20Over%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%20once%2C%20it%20stops%20at%3A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EBreak%20at%20address%20%220xdeadbeee%22%20with%20no%20debug%20information%20available%2C%20or%20outside%20of%20program%20code.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CUL%3E%3CLI%3E%3CSPAN%3EBreakpoints%20at%20other%20locations%20work%20and%20are%20hit%20correctly.%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EHowever%2C%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3EResume%2FContinue%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%20from%20a%20breakpoint%20again%20results%20in%20%3C%2FSPAN%3E%3CSPAN%3E0xDEADBEEE%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ECould%20someone%20please%20confirm%20whether%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3EJ-Link%20is%20fully%20supported%20with%20MCUXpresso%20IDE%20on%20the%20MIMXRT1176-ADP%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%2C%20and%20whether%20there%20is%20any%20specific%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3EJ-Link%20script%2C%20reset%2Fdebug%20configuration%2C%20or%20ADP-specific%20initialization%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%20required%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ECould%20this%20be%20related%20to%20the%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3Ememory%20configuration%2C%20external%20flash%2FSDRAM%2C%20or%20startup%20code%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%20on%20the%20ADP%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EAny%20guidance%20or%20working%20J-Link%20configuration%20for%20the%20ADP%20would%20be%20greatly%20appreciated.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EThanks!%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1176%20ADP%20%E2%80%93%20SEGGER%20J-Link%20debugging%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263926%22%20target%3D%22_blank%22%3E%40HasanIqbalKhan%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20questions!%3C%2FP%3E%0A%3CP%3EAs%20far%20as%20I%20know%2C%20when%20using%20JLink%20with%20the%20RT1170-ADP%20in%20MCUXpresso%20IDE%2C%20only%20%22attach%22%20is%20supported%20while%20direct%20debugging%20is%20not%20supported.%20This%20is%20likely%20a%20support%20issue%20with%20the%20JLink%20flashloader.%20In%20IAR%2C%20this%20issue%20has%20been%20resolved.%20We%20apologize%20for%20any%20inconvenience%20this%20may%20cause.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EGavin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1176%20ADP%20%E2%80%93%20SEGGER%20J-Link%20debugging%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOne%20more%20thing%20I%20tried%2C%20I%20connected%20an%20external%20MCU-Link%20and%20then%20tried%20debugging%20via%20the%20LinkServer%20in%20MCUXpresso%20IDE.%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20Execution%20reached%20main%2C%20I%20am%20able%20to%20step%20through%20from%20there%2C%20but%20when%20I%20try%20to%20resume%20execution%20it%20gives%20%22Break%20at%20address%20%220x0%22%20with%20no%20debug%20information%20available%2C%20or%20outside%20of%20program%20code.%22%2C%20and%20sometimes%20when%20I%20try%20to%20restart%20execution%2C%20it%20gives%20%22Break%20at%20address%20%220x2230c8%22%20with%20no%20debug%20information%20available%2C%20or%20outside%20of%20program%20code.%22%3CBR%20%2F%3E%3CBR%20%2F%3EFor%20reference%20I%20am%20trying%20to%20run%20the%20%22MIMXRT1176_dashboard_bt_ble_multiprofile%22%20project%2C%20SW1%20on%20the%20board%20is%20set%20to%2001%20and%20SW5%20on%20the%20board%20is%20set%20to%20000000000000.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20tried%20to%20test%20with%20MCU-Link%20because%20the%20EVKB%20board%20uses%20the%20same%20and%20works%20fine.%3CBR%20%2F%3E%3CBR%20%2F%3EAlso%20I%20do%20not%20think%20we%20can%20use%20Jlink%2C%20as%20it%20is%20clearly%20mentioned%20on%20their%20website%20that%20there%20is%20no%20support%20for%20octal%20flash%2C%20which%20the%20ADP%20board%20uses.%3CBR%20%2F%3E%3CBR%20%2F%3EThanks.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415281%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1176%20ADP%20%E2%80%93%20SEGGER%20J-Link%20debugging%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415281%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIs%20it%20possible%20to%20use%20debug%20via%20USB%20(J33)%20%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1176%20ADP%20%E2%80%93%20SEGGER%20J-Link%20debugging%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263926%22%20target%3D%22_blank%22%3E%40HasanIqbalKhan%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3E1.%20J33%20is%20USB-OTG1%20and%20cannot%20be%20used%20for%20debugging.%26nbsp%3B%3C%2FP%3E%0A%3CP%3E2.%20It%E2%80%99s%20not%20that%20JLink%20doesn%E2%80%99t%20support%20Octal%20Flash%3B%20it%E2%80%99s%20just%20that%20by%20default%2C%20it%20only%20recognizes%20the%20flash%20found%20on%20the%20EVK%2FEVKB.%20As%20for%20IAR%2C%20this%20is%20because%20a%20corresponding%20download%20algorithm%20is%20provided.%20If%20you%E2%80%99re%20interested%20in%20this%20topic%2C%20you%20can%20refer%20to%20the%20RT-UFL%20project.%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E3.%20For%20information%20on%20current%20debugger%2FIDE%20support%2C%20please%20refer%20to%3A%20AN14387%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20style%3D%22font-family%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%22%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14378%2Fpage%2Ftopics%2Fdownload_images_to_ADP_board.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14378%2Fpage%2Ftopics%2Fdownload_images_to_ADP_board.html%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EGavin%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
