MC33774 Daisy Chain Dual Loop Connection
758 次查看
Embedded_novice
HI.
我当前使用MC33665A+MC33774的AFE采样系统组成双链回环的结构,配置MC33665A的PORT0和PORT1分别为MADD0和MADD1,当前发送所有指令均由MADD0发送。当我只连接PORT0到DC1之间的菊花链时,我的通讯都是正常的,但是当我把PORT1和DC2之间的菊花链也连接后,我再去请求33774发现33774无法回复响应帧,这是为什么?我回读确认过33665的PORT端口配置没有错误,并且将33774中的SYS_TPL_CFG.RESPCFG设置为00 SAME模式。
I am currently using an AFE sampling system consisting of the MC33665A + MC33774 in a dual-ring loop configuration. I have configured PORT0 and PORT1 of the MC33665A as MADD0 and MADD1, respectively, and all commands are currently sent through MADD0.
When I connect only the daisy chain between PORT0 and DC1, communication works correctly. However, after I also connect the daisy chain between PORT1 and DC2, the MC33774 no longer responds when I send requests to it.
Why does this happen?
I have read back and verified that the MC33665 PORT configuration is correct, and I have configured SYS_TPL_CFG.RESPCFG = 00 (SAME mode) in the MC33774.
642 次查看
ErikaC
According to AN13910 TPL Loopback Recommendation, the DADD assignment should be reversed from the MADD=1 side in a loopback topology.
In addition, your current configuration has RX=1 and ALLCHAINS=1 on both ports. For a loopback connection, we recommend disabling RX and ALLCHAINS on one of the ports to avoid duplicate routing and communication conflicts.
Could you please try configuring one port with RX=0 and ALLCHAINS=0 (for example, PORT1) and verify whether the MC33774 starts returning response frames?
719 次查看
ErikaC
According to the AN13910 TPL Loopback Recommendation, when two MC33665A TPL ports are connected as a loopback ring, there are several configuration requirements that may cause the behavior you are seeing.
For a loopback configuration:
  • We recommend assigning device addresses (DADD) in ascending order from one side of the ring and in reverse order from the loopback side (I do not see this in your image).
  • If two ports are connected as loopback, one of the ports should have SYS_PORTx_CFG[RX] = 0 to avoid duplicate data entering the MC33665 buffer.
  • In addition, one of the ports should have SYS_PORTx_CFG[ALLCHAINS] = 0. If both loopback ports accept ALLCHAINS commands, document states that this can cause signal conflicts and communication errors.
Could you please share the values of SYS_PORT0_CFG and SYS_PORT1_CFG (especially EN, RX, ALLCHAINS, MADD, and CADD)? That would help determine whether the loopback ports are configured according to the AN13910 recommendations.
693 次查看
Embedded_novice
HI.
1.我想知道从MADD=1的位置反向分配DADD是必须的吗?
2.我当前的SYS_PORT0_CFG配置为TIMEOUT=0,CADD=1,MADD=0,PROTOCOL=1,ALLCHAINS=1,TERM=1,RX=1,EN=1
SYS_PORT1_CFG配置为TIMEOUT=0,CADD=1,MADD=1,PROTOCOL=1,ALLCHAINS=1,TERM=1,RX=1,EN=1
643 次查看
ErikaC
%3CLINGO-SUB%20id%3D%22lingo-sub-2387695%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EMC33774%20Daisy%20Chain%20Dual%20Loop%20Connection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2387695%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHI.%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BD%93%E5%89%8D%E4%BD%BF%E7%94%A8MC33665A%2BMC33774%E7%9A%84AFE%E9%87%87%E6%A0%B7%E7%B3%BB%E7%BB%9F%E7%BB%84%E6%88%90%E5%8F%8C%E9%93%BE%E5%9B%9E%E7%8E%AF%E7%9A%84%E7%BB%93%E6%9E%84%EF%BC%8C%E9%85%8D%E7%BD%AEMC33665A%E7%9A%84PORT0%E5%92%8CPORT1%E5%88%86%E5%88%AB%E4%B8%BAMADD0%E5%92%8CMADD1%EF%BC%8C%E5%BD%93%E5%89%8D%E5%8F%91%E9%80%81%E6%89%80%E6%9C%89%E6%8C%87%E4%BB%A4%E5%9D%87%E7%94%B1MADD0%E5%8F%91%E9%80%81%E3%80%82%E5%BD%93%E6%88%91%E5%8F%AA%E8%BF%9E%E6%8E%A5PORT0%E5%88%B0DC1%E4%B9%8B%E9%97%B4%E7%9A%84%E8%8F%8A%E8%8A%B1%E9%93%BE%E6%97%B6%EF%BC%8C%E6%88%91%E7%9A%84%E9%80%9A%E8%AE%AF%E9%83%BD%E6%98%AF%E6%AD%A3%E5%B8%B8%E7%9A%84%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E6%8A%8APORT1%E5%92%8CDC2%E4%B9%8B%E9%97%B4%E7%9A%84%E8%8F%8A%E8%8A%B1%E9%93%BE%E4%B9%9F%E8%BF%9E%E6%8E%A5%E5%90%8E%EF%BC%8C%E6%88%91%E5%86%8D%E5%8E%BB%E8%AF%B7%E6%B1%8233774%E5%8F%91%E7%8E%B033774%E6%97%A0%E6%B3%95%E5%9B%9E%E5%A4%8D%E5%93%8D%E5%BA%94%E5%B8%A7%EF%BC%8C%E8%BF%99%E6%98%AF%E4%B8%BA%E4%BB%80%E4%B9%88%EF%BC%9F%E6%88%91%E5%9B%9E%E8%AF%BB%E7%A1%AE%E8%AE%A4%E8%BF%8733665%E7%9A%84PORT%E7%AB%AF%E5%8F%A3%E9%85%8D%E7%BD%AE%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%B0%8633774%E4%B8%AD%E7%9A%84SYS_TPL_CFG.RESPCFG%E8%AE%BE%E7%BD%AE%E4%B8%BA00%20SAME%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%3E%0A%3CP%3EI%20am%20currently%20using%20an%20AFE%20sampling%20system%20consisting%20of%20the%20MC33665A%20%2B%20MC33774%20in%20a%20dual-ring%20loop%20configuration.%20I%20have%20configured%20PORT0%20and%20PORT1%20of%20the%20MC33665A%20as%20MADD0%20and%20MADD1%2C%20respectively%2C%20and%20all%20commands%20are%20currently%20sent%20through%20MADD0.%3C%2FP%3E%0A%3CP%3EWhen%20I%20connect%20only%20the%20daisy%20chain%20between%20PORT0%20and%20DC1%2C%20communication%20works%20correctly.%20However%2C%20after%20I%20also%20connect%20the%20daisy%20chain%20between%20PORT1%20and%20DC2%2C%20the%20MC33774%20no%20longer%20responds%20when%20I%20send%20requests%20to%20it.%3C%2FP%3E%0A%3CP%3EWhy%20does%20this%20happen%3F%3C%2FP%3E%0A%3CP%3EI%20have%20read%20back%20and%20verified%20that%20the%20MC33665%20PORT%20configuration%20is%20correct%2C%20and%20I%20have%20configured%20SYS_TPL_CFG.RESPCFG%20%3D%2000%20(SAME%20mode)%20in%20the%20MC33774.%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Embedded_novice_0-1782728020846.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Embedded_novice_0-1782728020846.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Embedded_novice_0-1782728020846.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F390576i164ED2A8580F30E1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Embedded_novice_0-1782728020846.png%22%20alt%3D%22Embedded_novice_0-1782728020846.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EEmbedded_novice_0-1782728020846.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388005%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MC33774%20Daisy%20Chain%20Dual%20Loop%20Connection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388005%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHI.%3C%2FP%3E%3CP%3E1.%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E4%BB%8EMADD%3D1%E7%9A%84%E4%BD%8D%E7%BD%AE%E5%8F%8D%E5%90%91%E5%88%86%E9%85%8DDADD%E6%98%AF%E5%BF%85%E9%A1%BB%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E2.%E6%88%91%E5%BD%93%E5%89%8D%E7%9A%84SYS_PORT0_CFG%E9%85%8D%E7%BD%AE%E4%B8%BATIMEOUT%3D0%2CCADD%3D1%2CMADD%3D0%2CPROTOCOL%3D1%2CALLCHAINS%3D1%2CTERM%3D1%2CRX%3D1%2CEN%3D1%3C%2FP%3E%3CP%3ESYS_PORT1_CFG%E9%85%8D%E7%BD%AE%E4%B8%BATIMEOUT%3D0%2CCADD%3D1%2CMADD%3D1%2CPROTOCOL%3D1%2CALLCHAINS%3D1%2CTERM%3D1%2CRX%3D1%2CEN%3D1%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2387884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MC33774%20Daisy%20Chain%20Dual%20Loop%20Connection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2387884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%20AN13910%20TPL%20%E7%8E%AF%E5%9B%9E%E5%BB%BA%E8%AE%AE%EF%BC%8C%E5%BD%93%E4%B8%A4%E4%B8%AA%20MC33665A%20TPL%20%E7%AB%AF%E5%8F%A3%E8%BF%9E%E6%8E%A5%E6%88%90%E7%8E%AF%E5%9B%9E%E7%8E%AF%E6%97%B6%EF%BC%8C%E5%AD%98%E5%9C%A8%E4%B8%80%E4%BA%9B%E9%85%8D%E7%BD%AE%E8%A6%81%E6%B1%82%EF%BC%8C%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%82%A8%E7%9C%8B%E5%88%B0%E7%9A%84%E8%A1%8C%E4%B8%BA%E3%80%82%3CBR%20%2F%3E%E5%AF%B9%E4%BA%8E%E7%8E%AF%E5%9B%9E%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E6%88%91%E4%BB%AC%E5%BB%BA%E8%AE%AE%E4%BB%8E%E7%8E%AF%E7%9A%84%E4%B8%80%E4%BE%A7%E6%8C%89%E5%8D%87%E5%BA%8F%E5%88%86%E9%85%8D%E8%AE%BE%E5%A4%87%E5%9C%B0%E5%9D%80%20(DADD)%EF%BC%8C%E4%BB%8E%E7%8E%AF%E5%9B%9E%E4%BE%A7%E6%8C%89%E7%9B%B8%E5%8F%8D%E7%9A%84%E9%A1%BA%E5%BA%8F%E5%88%86%E9%85%8D%E8%AE%BE%E5%A4%87%E5%9C%B0%E5%9D%80%20(DADD)%EF%BC%88%E6%88%91%E5%9C%A8%E4%BD%A0%E7%9A%84%E5%9B%BE%E7%89%87%E4%B8%AD%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%89%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E5%A6%82%E6%9E%9C%E4%B8%A4%E4%B8%AA%E7%AB%AF%E5%8F%A3%E8%BF%9E%E6%8E%A5%E4%B8%BA%E7%8E%AF%E5%9B%9E%EF%BC%8C%E5%88%99%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%E7%AB%AF%E5%8F%A3%E5%BA%94%E8%AE%BE%E7%BD%AE%20SYS_PORTx_CFG%5BRX%5D%20%3D%200%EF%BC%8C%E4%BB%A5%E9%81%BF%E5%85%8D%E9%87%8D%E5%A4%8D%E6%95%B0%E6%8D%AE%E8%BF%9B%E5%85%A5%20MC33665%20%E7%BC%93%E5%86%B2%E5%8C%BA%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%E7%AB%AF%E5%8F%A3%E7%9A%84%20SYS_PORTx_CFG%5BALLCHAINS%5D%20%E5%BA%94%E4%B8%BA%200%E3%80%82%E6%96%87%E6%A1%A3%E6%8C%87%E5%87%BA%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%A4%E4%B8%AA%E7%8E%AF%E5%9B%9E%E7%AB%AF%E5%8F%A3%E9%83%BD%E6%8E%A5%E5%8F%97%20ALLCHAINS%20%E5%91%BD%E4%BB%A4%EF%BC%8C%E5%88%99%E5%8F%AF%E8%83%BD%E5%AF%BC%E8%87%B4%E4%BF%A1%E5%8F%B7%E5%86%B2%E7%AA%81%E5%92%8C%E9%80%9A%E4%BF%A1%E9%94%99%E8%AF%AF%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E8%AF%B7%E9%97%AE%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%20SYS_PORT0_CFG%20%E5%92%8C%20SYS_PORT1_CFG%20%E7%9A%84%E5%80%BC%EF%BC%88%E7%89%B9%E5%88%AB%E6%98%AF%20EN%E3%80%81RX%E3%80%81ALLCHAINS%E3%80%81MADD%20%E5%92%8C%20CADD%EF%BC%89%EF%BC%9F%E8%BF%99%E5%B0%86%E6%9C%89%E5%8A%A9%E4%BA%8E%E7%A1%AE%E5%AE%9A%E7%8E%AF%E5%9B%9E%E7%AB%AF%E5%8F%A3%E6%98%AF%E5%90%A6%E6%8C%89%E7%85%A7%20AN13910%20%E5%BB%BA%E8%AE%AE%E8%BF%9B%E8%A1%8C%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388581%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MC33774%20Daisy%20Chain%20Dual%20Loop%20Connection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388581%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%20AN13910%20TPL%20%E7%8E%AF%E5%9B%9E%E5%BB%BA%E8%AE%AE%EF%BC%8C%E5%9C%A8%E7%8E%AF%E5%9B%9E%E6%8B%93%E6%89%91%E4%B8%AD%EF%BC%8CDADD%20%E5%88%86%E9%85%8D%E5%BA%94%E4%B8%8E%20MADD%3D1%20%E4%BE%A7%E7%9B%B8%E5%8F%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%82%A8%E5%BD%93%E5%89%8D%E7%9A%84%E9%85%8D%E7%BD%AE%E5%9C%A8%E4%B8%A4%E4%B8%AA%E7%AB%AF%E5%8F%A3%E4%B8%8A%E9%83%BD%E8%AE%BE%E7%BD%AE%E4%BA%86%20RX%3D1%20%E5%92%8C%20ALLCHAINS%3D1%E3%80%82%E5%AF%B9%E4%BA%8E%E7%8E%AF%E5%9B%9E%E8%BF%9E%E6%8E%A5%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BB%BA%E8%AE%AE%E7%A6%81%E7%94%A8%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%E7%AB%AF%E5%8F%A3%E4%B8%8A%E7%9A%84%20RX%20%E5%92%8C%20ALLCHAINS%EF%BC%8C%E4%BB%A5%E9%81%BF%E5%85%8D%E9%87%8D%E5%A4%8D%E8%B7%AF%E7%94%B1%E5%92%8C%E9%80%9A%E4%BF%A1%E5%86%B2%E7%AA%81%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%B0%86%E4%B8%80%E4%B8%AA%E7%AB%AF%E5%8F%A3%E7%9A%84%20RX%3D0%20%E5%92%8C%20ALLCHAINS%3D0%20%E9%85%8D%E7%BD%AE%E4%B8%BA%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8CPORT1%EF%BC%89%EF%BC%8C%E5%B9%B6%E9%AA%8C%E8%AF%81%20MC33774%20%E6%98%AF%E5%90%A6%E5%BC%80%E5%A7%8B%E8%BF%94%E5%9B%9E%E5%93%8D%E5%BA%94%E5%B8%A7%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
