MAPBGA 121 Package Support PCB Mounting and Routing
carlthomson
Hi. I'm designing a PCB with the MAPBGA 121 package. The package has 0.25mm - 0.35mm diameter balls on 0.65mm spacing. Even with a 0.25mm solder pad on the PCB, this ball pitch is too small to allow room for through-vias. I'm not finding any supporting documentation on land pattern recommendations, or routing strategies. Anyone have any experience with this package?
Wlodek_D_
Senior Contributor II
Hello Carl,
What is your Freescale device you working with? Would you provide Part Number?
Having this it will be easier to find info you asking for.
Wlodek_D.
carlthomson
Wlodek,
Thank you for contacting me. The part in the design is the MK20DN512VMC10, which comes in the MAPBGA 121 package.
Thank you,
Carl
Date: Mon, 17 Mar 2014 07:53:03 -0700
To: [email protected]
Subject: Re: - MAPBGA 121 Package Support PCB Mounting and Routing
reply from Wlodek_D. in Other Freescale Solutions - View the full discussion
Hello Carl,
Wlodek_D.
Reply to this message by replying to this email, or go to the message on Freescale Community
Start a new discussion in Other Freescale Solutions by email or at Freescale Community
Following MAPBGA 121 Package Support PCB Mounting and Routing in these streams:
Inbox
