Is it possible to take an image from the ISP, send it directly to the GPU for post-processing, and then return the result to the CPU to be used in a regular application?
-->Yes, you can get image buffer from V4L2 with DMABUF, and then import it to GLES/Vulkan or OpenCL to post-process. For GPU demo , please refer here: https://github.com/nxp-imx/gtec-demo-framework/tree/master/DemoApps
I noticed that the NPU on the i.MX8MP supports OpenVX. Does this mean I can program it and use it as a sort of secondary GPU?
--> This is not possible. The OpenVX is used for machine learning, not generic GPU.
Zhiming
