LS1046A RDB mbed serial drive not connecting
balaka
while setup my LS1046A RDB board frist time and followed the Getting Started Guide:
Downloaded and installed the mbed serial port driver and installed Tera Term,
When connecting the USB cable between console port and PC, Windows shows an USB drive/folder for a short period, and then disappears. This continues on and on. The green LED D8 periodically blinks (like the CMSIS-DAP controller is rebooting).
Host machine is having the windows 11.
balaka
This step :
This is the workaround we have confirmed to fix the mbed issue on Win10 PC's:
- Go to the "Start" option on the PC and type the command "Services"
- Than you should see the following "Services" window open
- Select the "Storage Services" and on the left-hand side of the window click the "Stop the service"
I tried before posting the issue here.
Now I try to follow the steps in https://os.mbed.com/blog/entry/DAPLink-bootloader-update/
but i am not allowed to copy the file k22fx512_if_mbed.bin to the BOOTLOADER Drive.
Oswalag
Please refer to the attached document and MBED firmware image (in the ZIP package).
There is a known issue with MBED operation under Win10(Could be the same for Win11):
balaka
Following the steps given in
DAPLink bootloader update | Mbed
But to od the step 3 it is not allowing the BOOTLOADER drive to copy the image inside.\
Could you please suggest?
Oswalag
Please try in a Win10 Machine and share your result.
balaka
I tried with the windows10 also. when we drag and drop the k22fx512_if_mbed.bin file.
Geeting the error
"You need permission to perform this action"
Oswalag
Please send images of the process you followed and the permission error.
balaka
this is issue due to write permissions not available in USB.
balaka
This step :
%3CLINGO-SUB%20id%3D%22lingo-sub-1942392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1046A%20RDB%20%20mbed%20serial%20drive%20not%20connecting%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1942392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ewhile%20setup%20my%20LS1046A%20RDB%20board%20frist%20time%20and%20followed%20the%20Getting%20Started%20Guide%3A%3C%2FP%3E%3CP%3EDownloaded%20and%20installed%20the%20mbed%20serial%20port%20driver%20and%20installed%20Tera%20Term%2C%3C%2FP%3E%3CP%3EWhen%20connecting%20the%20USB%20cable%20between%20console%20port%20and%20PC%2C%20Windows%20shows%20an%20USB%20drive%2Ffolder%20for%20a%20short%20period%2C%20and%20then%20disappears.%20This%20continues%20on%20and%20on.%20The%20green%20LED%20D8%20periodically%20blinks%20(like%20the%20CMSIS-DAP%20controller%20is%20rebooting).%3C%2FP%3E%3CP%3EHost%20machine%20is%20having%20the%20windows%2011.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1954875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046A%20RDB%20%20mbed%20serial%20drive%20not%20connecting%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1954875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ethis%20is%20issue%20due%20to%20write%20permissions%20not%20available%20in%20USB.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1952744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046A%20RDB%20%20mbed%20serial%20drive%20not%20connecting%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1952744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20send%20images%20of%20the%20process%20you%20followed%20and%20the%20permission%20error.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1950049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046A%20RDB%20%20mbed%20serial%20drive%20not%20connecting%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1950049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EI%20tried%20with%20the%20windows10%20also.%20when%20we%20drag%20and%20drop%20the%20k22fx512_if_mbed.bin%20file.%3CBR%20%2F%3EGeeting%20the%20error%3CBR%20%2F%3E%22You%20need%20permission%20to%20perform%20this%20action%22%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1947569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046A%20RDB%20%20mbed%20serial%20drive%20not%20connecting%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1947569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20try%20in%20a%20Win10%20Machine%20and%20share%20your%20result.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1945943%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046A%20RDB%20%20mbed%20serial%20drive%20not%20connecting%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1945943%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFollowing%20the%20steps%20given%20in%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fos.mbed.com%2Fblog%2Fentry%2FDAPLink-bootloader-update%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EDAPLink%20bootloader%20update%20%7C%20Mbed%3C%2FA%3E%3C%2FP%3E%3CP%3EBut%20to%20od%20the%20step%203%20it%20is%20not%20allowing%20the%20BOOTLOADER%20drive%20to%20copy%20the%20image%20inside.%5C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECould%20you%20please%20suggest%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1945404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046A%20RDB%20%20mbed%20serial%20drive%20not%20connecting%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1945404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20step%20%3A%3C%2FP%3E%3CP%3E%3CSPAN%3EThis%20is%20the%20workaround%20we%20have%20confirmed%20to%20fix%20the%20mbed%20issue%20on%20Win10%20PC's%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E-%20Go%20to%20the%20%22Start%22%20option%20on%20the%20PC%20and%20type%20the%20command%20%22Services%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E-%20Than%20you%20should%20see%20the%20following%20%22Services%22%20window%20open%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E-%20Select%20the%20%22Storage%20Services%22%20and%20on%20the%20left-hand%20side%20of%20the%20window%20click%20the%20%22Stop%20the%20service%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20tried%20before%20posting%20the%20issue%20here.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ENow%20I%20try%20to%20follow%20the%20steps%20in%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fos.mbed.com%2Fblog%2Fentry%2FDAPLink-bootloader-update%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fos.mbed.com%2Fblog%2Fentry%2FDAPLink-bootloader-update%2F%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ebut%20i%20am%20not%20allowed%20to%20copy%20the%20file%20k22fx512_if_mbed.bin%20to%20the%20BOOTLOADER%20Drive.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1943837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046A%20RDB%20%20mbed%20serial%20drive%20not%20connecting%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1943837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EPlease%20refer%20to%20the%20attached%20document%20and%20MBED%20firmware%20image%20(in%20the%20ZIP%20package).%3C%2FP%3E%0A%3CP%3EThere%20is%20a%20known%20issue%20with%20MBED%20operation%20under%20Win10(Could%20be%20the%20same%20for%20Win11)%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fos.mbed.com%2Fblog%2Fentry%2FDAPLink-bootloader-update%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fos.mbed.com%2Fblog%2Fentry%2FDAPLink-bootloader-update%2F%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EThis%20is%20the%20workaround%20we%20have%20confirmed%20to%20fix%20the%20mbed%20issue%20on%20Win10%20PC's%3A%3CBR%20%2F%3E-%20Go%20to%20the%20%22Start%22%20option%20on%20the%20PC%20and%20type%20the%20command%20%22Services%22%3CBR%20%2F%3E-%20Than%20you%20should%20see%20the%20following%20%22Services%22%20window%20open%3CBR%20%2F%3E-%20Select%20the%20%22Storage%20Services%22%20and%20on%20the%20left-hand%20side%20of%20the%20window%20click%20the%20%22Stop%20the%20service%22%3C%2FP%3E%3C%2FLINGO-BODY%3E
