LS1028ARDB netopeer2-server
1,700件の閲覧回数
hupei
There are many errors when I init the netopeer2-server in LS1028ARDB.
root@ls1028ardb:~# netopeer2-server -d -v 2
[INF]: Sysrepo daemon has been started.
[INF]: Netopeer2 connected to sysrepod.
[INF]: Plugin "/usr/lib/libyang/extensions/metadata.so" successfully loaded.
[INF]: Plugin "/usr/lib/libyang/extensions/nacm.so" successfully loaded.
[INF]: Plugin "/usr/lib/libyang/extensions/yangdata.so" successfully loaded.
[INF]: Plugin "/usr/lib/libyang/user_types/user_inet_types.so" successfully loaded.
[INF]: Plugin "/usr/lib/libyang/user_types/user_yang_types.so" successfully loaded.
[INF]: Reading module "ietf-yang-metadata".
[INF]: Module "ietf-yang-metadata@2016-08-05" successfully parsed as implemented.
[INF]: Reading module "yang".
[INF]: Resolving "yang" unresolved schema nodes and their constraints...
[INF]: All "yang" schema nodes and constraints resolved.
[INF]: Module "yang@2017-02-20" successfully parsed as implemented.
[INF]: Reading module "ietf-inet-types".
[INF]: Resolving derived type "union" failed, it will be attempted later.
[INF]: Resolving "ietf-inet-types" unresolved schema nodes and their constraints...
[INF]: All "ietf-inet-types" schema nodes and constraints resolved.
[INF]: Module "ietf-inet-types@2013-07-15" successfully parsed as implemented.
[INF]: Reading module "ietf-yang-types".
[INF]: Module "ietf-yang-types@2013-07-15" successfully parsed as implemented.
[INF]: Reading module "ietf-datastores".
[INF]: Module "ietf-datastores@2017-08-17" successfully parsed as implemented.
[INF]: Reading module "ietf-yang-library".
[INF]: Searching for "ietf-yang-types" in /home/root.
[INF]: Searching for "ietf-inet-types" in /home/root.
[INF]: Searching for "ietf-datastores" in /home/root.
[INF]: Module "ietf-yang-library@2019-01-04" successfully parsed as implemented.
[INF]: Loading schema "ietf-netconf-notifications@2012-02-06" from sysrepo.
[ERR]: Sysrepo server disconnected.
[ERR]: Unable to receive the message with response (session id=750397727, operation=get-schema).
[ERR]: Error by processing of the request.
[ERR]: Error by sending of the message: .
[ERR]: Unable to send the message with request (session id=750397727, operation=session-check).
[ERR]: Unable to send the message with request (session id=750397727, operation=unsubscribe).
[ERR]: Error by closing of the subscription: The peer disconnected.
[INF]: Client Subscription Manager successfully destroyed.
[ERR]: Unable to receive the message with response (session id=750397727, operation=subscribe).
[ERR]: Failed to connect to sysrepod, it will be retried on the next communication with sysrepo.
[WRN]: Getting ietf-netconf-notifications@2012-02-06 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-netconf@2011-06-01" from sysrepo.
[WRN]: Getting ietf-netconf@2011-06-01 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-netconf-acm@2018-02-14" from sysrepo.
[WRN]: Getting ietf-netconf-acm@2018-02-14 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "sysrepo-module-dependencies@2017-04-21" from sysrepo.
[WRN]: Getting sysrepo-module-dependencies@2017-04-21 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "sysrepo-notification-store@2016-11-22" from sysrepo.
[WRN]: Getting sysrepo-notification-store@2016-11-22 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "sysrepo-persistent-data@2016-03-30" from sysrepo.
[WRN]: Getting sysrepo-persistent-data@2016-03-30 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "nc-notifications@2008-07-14" from sysrepo.
[INF]: Connected to daemon Sysrepo Engine at socket=/tmp/sysrepod.sock
[ERR]: Error by receiving of the message: .
[ERR]: Unable to receive the message with response (operation=version-verify).
[WRN]: Getting nc-notifications@2008-07-14 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "notifications@2008-07-14" from sysrepo.
[ERR]: Unable to receive the message with response (session id=1535076162, operation=subscribe).
[ERR]: Unable to send the message with request (session id=1535076162, operation=unsubscribe).
[WRN]: Getting notifications@2008-07-14 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-x509-cert-to-name@2014-12-10" from sysrepo.
[WRN]: Getting ietf-x509-cert-to-name@2014-12-10 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-keystore@2016-10-31" from sysrepo.
[WRN]: Getting ietf-keystore@2016-10-31 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-netconf-with-defaults@2011-06-01" from sysrepo.
[WRN]: Getting ietf-netconf-with-defaults@2011-06-01 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-netconf-monitoring@2010-10-04" from sysrepo.
[WRN]: Getting ietf-netconf-monitoring@2010-10-04 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-yang-library@2018-01-17" from sysrepo.
[WRN]: Getting ietf-yang-library@2018-01-17 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-datastores@2017-08-17" from sysrepo.
[INF]: Module ietf-datastores@2017-08-17 already present in context.
[INF]: Loading schema "ietf-netconf-server@2016-11-02" from sysrepo.
[WRN]: Getting ietf-netconf-server@2016-11-02 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-ssh-server@2016-11-02" from sysrepo.
[WRN]: Getting ietf-ssh-server@2016-11-02 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-tls-server@2016-11-02" from sysrepo.
[WRN]: Getting ietf-tls-server@2016-11-02 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-system@2014-08-06" from sysrepo.
[WRN]: Getting ietf-system@2014-08-06 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "iana-crypt-hash@2014-08-06" from sysrepo.
[WRN]: Getting iana-crypt-hash@2014-08-06 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-interfaces@2014-05-08" from sysrepo.
[WRN]: Getting ietf-interfaces@2014-05-08 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-yang-types@2013-07-15" from sysrepo.
[INF]: Module ietf-yang-types@2013-07-15 already present in context.
[INF]: Module "ietf-yang-types@2013-07-15" now implemented.
[INF]: Loading schema "ieee802-dot1q-types@2018-03-07" from sysrepo.
[WRN]: Getting ieee802-dot1q-types@2018-03-07 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ieee802-dot1q-preemption@2018-09-10" from sysrepo.
[WRN]: Getting ieee802-dot1q-preemption@2018-09-10 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ieee802-dot1q-sched@2018-09-10" from sysrepo.
[WRN]: Getting ieee802-dot1q-sched@2018-09-10 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "iana-if-type@2017-01-19" from sysrepo.
[WRN]: Getting iana-if-type@2017-01-19 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ieee802-dot1q-bridge@2018-03-07" from sysrepo.
[WRN]: Getting ieee802-dot1q-bridge@2018-03-07 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ieee802-types@2018-03-07" from sysrepo.
[ERR]: Unable to receive the message with response (session id=1210414111, operation=subscribe).
[ERR]: Unable to send the message with request (session id=1210414111, operation=unsubscribe).
[WRN]: Getting ieee802-types@2018-03-07 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-inet-types@2013-07-15" from sysrepo.
[INF]: Module ietf-inet-types@2013-07-15 already present in context.
[INF]: Module "ietf-inet-types@2013-07-15" now implemented.
[INF]: Loading schema "ieee802-dot1q-stream-filters-gates@2017-12-20" from sysrepo.
[WRN]: Getting ieee802-dot1q-stream-filters-gates@2017-12-20 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ieee802-dot1q-psfp@2018-09-10" from sysrepo.
[WRN]: Getting ieee802-dot1q-psfp@2018-09-10 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ieee802-dot1q-cb-stream-identification@2019-05-20" from sysrepo.
[WRN]: Getting ieee802-dot1q-cb-stream-identification@2019-05-20 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ieee802-dot1q-qci-augment@2019-05-20" from sysrepo.
[WRN]: Getting ieee802-dot1q-qci-augment@2019-05-20 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ietf-ip@2014-06-16" from sysrepo.
[WRN]: Getting ietf-ip@2014-06-16 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "nxp-bridge-vlan-tc-flower@2020-04-02" from sysrepo.
[WRN]: Getting nxp-bridge-vlan-tc-flower@2020-04-02 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ieee802-dot1cb-stream-identification-types@2020-11-27" from sysrepo.
[WRN]: Getting ieee802-dot1cb-stream-identification-types@2020-11-27 schema from sysrepo failed, data from this module won't be available.
[INF]: Loading schema "ieee802-dot1cb-frer@2020-11-27" from sysrepo.
[WRN]: Getting ieee802-dot1cb-frer@2020-11-27 schema from sysrepo failed, data from this module won't be available.
[ERR]: Module "ietf-netconf" not implemented in sysrepo.
[ERR]: Server init failed.
[ERR]: nc_ps_session_count: invalid argument (ps).
タグ(1)
1,670件の閲覧回数
yipingwang
Please refer to section "5.4.2 Netopeer2" in the attached document.
