LE Audio Hardware
LE Audio Hardware
3,010 次查看
chen_jackcw
Hi Sir,
We are searching LE audio solution, but we have some confuses about the different chip. Some bluetooth chip can support BLE 5.x and others can support BLE 5.x and LE Audio.
I would like to know what the difference between chip with LE Audio and without it, firmware difference or hardware difference, if only firmware difference, whether NXP will plan new firmware to let BLE 5.x chip with LE audio support
Jack
2,974 次查看
Christine_Li
Hi, @chen_jackcw
Thanks for your feedback.
Yes, you are right, on 88Q9098, we don't support BLE audio. And the reason not supported is due to lack of support in ASIC, it means HW limitations. If the antennas is not your limitation, and prefer to use on Automotive, you can think about 1*1 Wi-Fi 6+Bluetooth 5.2 Automotive solution chip:AW611.
Christine.
2,983 次查看
chen_jackcw
Hi Christine,
Now we are researching the Blutooth chip  88Q9098,
The spec. described that it support bluetooth 5.3, but I can't find any description about LE audio.
So I want to know if this is the hardware limitation or firmware limitation, if it related to firmware, if NXP will upgrade firmware to support LE audio later.
Jack
2,975 次查看
Christine_Li
Hi, @chen_jackcw
Christine.
3,003 次查看
Christine_Li
Hi, @chen_jackcw
I am not sure which product you are considering. But for LE audio products, we have specific webpage to introduce our LE audio products. I suggest you consider our NXP products in the below link:
Bluetooth® LE Audio
And we can say that there is only firmware differences between different products which support or not support BLE audio. For sure, some products which support BLE audio also have hardware differences.
But if you have detailed product name, I can check internally for you whether we have near future plan to support BLE Audio.
Christine.
