KW36
KW36
2,151 次查看
caiguanyun
Hello, everyone, how many times the flash of the KW36 bluetooth chip can be erased and written at most. The specification does not explain, I hope someone will answer.
3 回复数
2,131 次查看
Alexis_A
Hello @caiguanyun,
This information can be found in the datasheet, in the section 6.5.4.1.2:
Alexis Andalon
2,104 次查看
Alexis_A
Hello @caiguanyun,
You would find the same information in the datasheet for the automotive parts on 6.5.4.1.2 Reliability specifications. You can download the datasheet from here.
Alexis Andalon
