Infrared Camera Connection - IMX8m Plus EVK
1,173 次查看
NITIN26
Hello all,
Can an Infrared (IR) Camera be connected to IMX8M Plus EVK? If yes, can you please let me know which IR camera can be connected and how? What are all the packages/libraries that needs to be installed or is there an inbuilt library available to use.
Please guide me through this issue it is required for my use case.
Thanks and Regards
Nitin B S
1,126 次查看
AldoG
Yes, it is possible, I have not tested one personally but it is indeed possible.
We do not have/provide a guide for this but for i.MX8MPlus, you may take a look to one of our partner such as Basler.
https://www.nxp.com/webapp/connect/displayPartnerProfile.sp?partnerId=14000
Best regards/Saludos,
Aldo.
