Platform: NXP IMX6DL + IW611
OS: Linux kernel 5.10.72
insmod mlan.ko
[ 50.313625] mlan: loading out-of-tree module taints kernel.
root@imx6qsabresd:/lib/modules/5.10.72# insmod moal.ko mod_para=nxp/wifi_mod_par a.conf
[ 56.075314] wlan: Loading MWLAN driver
[ 56.079417] wlan: Register to Bus Driver...
[ 56.089609] vendor=0x0471 device=0x0205 class=0 function=1
[ 56.095465] Attach moal handle ops, card interface type: 0x109
[ 56.101334] rps set to 0 from module param
[ 56.112206] SDIW612: init module param from usr cfg
[ 56.117139] card_type: SDIW612, config block: 0
[ 56.121683] cfg80211_wext=0xf
[ 56.124671] max_vir_bss=1
[ 56.127299] cal_data_cfg=none
[ 56.130272] wfd_name=wfd
[ 56.132809] drv_mode = 7
[ 56.135400] ps_mode = 2
[ 56.137862] auto_ds = 2
[ 56.140312] fw_name=nxp/sd_w61x_v1.bin.se
[ 56.144386] SDIO: max_segs=128 max_seg_size=65535
[ 56.149093] rx_work=1 cpu_num=2
[ 56.152238] Enable moal_recv_amsdu_packet
[ 56.156341] Attach mlan adapter operations.card_type is 0x109.
[ 56.168428] wlan: Enable TX SG mode
[ 56.171925] wlan: Enable RX SG mode
[ 56.184487] Request firmware: nxp/sd_w61x_v1.bin.se
[ 56.401389] random: crng init done
[ 56.404809] random: 2 urandom warning(s) missed due to ratelimiting
[ 56.426047] Wlan: FW download over, firmwarelen=665336 downloaded 553136
[ 56.824587] WLAN FW is active
[ 56.827580] on_time is 56823365339
[ 56.854987] VDLL image: len=112200
[ 56.859219] fw_cap_info=0x487cff03, dev_cap_mask=0xffffffff
[ 56.864917] uuid: fc3e90f2b894523c925a8d1200d70370
[ 56.869728] max_p2p_conn = 8, max_sta_conn = 16
[ 56.971501] Register NXP 802.11 Adapter mlan0
[ 56.976273] wlan: uap%d set max_mtu 2000
[ 56.985462] Register NXP 802.11 Adapter uap0
[ 57.042373] Register NXP 802.11 Adapter wfd0
[ 57.048806] wlan: version = SDIW612---18.99.3.p21.10-MM6X18505.p4-GPL-(FP92)
[ 57.059323] Set REG 0x90002328: 0x13d57 slew_rate=3
[ 57.071217] wlan: Register to Bus Driver Done
[ 57.076444] wlan: Driver loaded successfully
wpa_cli v2.5
Copyright (c) 2004-2015, Jouni Malinen <j@w1.fi> and contributors
This software may be distributed under the terms of the BSD license.
See README for more details.
Selected interface 'wfd0'
Interactive mode
> p2p_find 10
OK
> [ 98.000929] wlan: wfd0 START SCAN
<3>CTRL-EVENT-SCAN-STARTED
[ 101.653006] wlan: SCAN COMPLETED: scanned AP count=1
[ 101.897302] wlan: wfd0 START SCAN
[ 102.045817] wlan: SCAN COMPLETED: scanned AP count=1
[ 102.391409] Cancel Remain on Channel before scan request
[ 102.399535] wlan: wfd0 START SCAN
[ 102.547847] wlan: SCAN COMPLETED: scanned AP count=2
<3>P2P-DEVICE-FOUND a8:10:87:6e:2d:1f p2p_dev_addr=a8:10:87:6e:2d:1f pri_dev_typ e=10-0050F204-5 name='cc3200-p2p-go' config_methods=0x188 dev_capab=0x21 group_c apab=0x0 new=1
[ 102.789856] Cancel Remain on Channel before scan request
p2p_connect a8:10:87:6e:2d:1f pbc persistent go_intent=1
[ 125.839661] Add virtual interface p2p-wfd0-0
[ 125.908314] Can not set data rate in disconnected state
OK
> [ 125.914980] wlan: TX P2P Group Owner Negotiation Req Frame, channel=11
[ 125.933575] wlan: RX P2P Group Owner Negotiation Rsp Frame, channel=11
[ 127.984161] wlan: RX P2P Group Owner Negotiation Req Frame, channel=1
[ 127.991542] wlan: TX P2P Group Owner Negotiation Rsp Frame, channel=1
[ 128.009820] wlan: RX P2P Group Owner Negotiation Confirm Frame, channel=1
<3>P2P-GO-NEG-SUCCESS role=client freq=2437 ht40=0 peer_dev=a8:[ 128.043809] Ca n not set data rate in disconnected state
10:87:6e:2d:1f peer_iface=a8:10:87:6e:2d:1f wps_method=PBC
[ 128.097846] wlan: p2p-wfd0-0 START SCAN
[ 128.149337] wlan: SCAN COMPLETED: scanned AP count=1
<3>CTRL-EVENT-SCAN-RESULTS
[ 128.407007] wlan: p2p-wfd0-0 START SCAN
[ 128.458666] wlan: SCAN COMPLETED: scanned AP count=1
[ 128.685888] wlan: HostMlme p2p-wfd0-0 send auth to bssid a8:XX:XX:XX:2d:1f
[ 128.772322] p2p-wfd0-0:
[ 128.772343] wlan: HostMlme Auth received from a8:XX:XX:XX:2d:1f
[ 128.875716] wlan: HostMlme p2p-wfd0-0 Connected to bssid a8:XX:XX:XX:2d:1f su ccessfully
[ 128.885914] p2p-wfd0-0:
[ 128.885935] wlan: Send EAPOL pkt to a8:XX:XX:XX:2d:1f
[ 129.119201] p2p-wfd0-0:
[ 129.119211] wlan: Send EAPOL pkt to a8:XX:XX:XX:2d:1f
[ 129.430664] p2p-wfd0-0:
[ 129.430674] wlan: Send EAPOL pkt to a8:XX:XX:XX:2d:1f
[ 129.488285] p2p-wfd0-0:
[ 129.488307] wlan: Send EAPOL pkt to a8:XX:XX:XX:2d:1f
[ 129.588705] p2p-wfd0-0:
[ 129.588725] wlan: Send EAPOL pkt to a8:XX:XX:XX:2d:1f
<3>P2P-GROUP-FORMATION-SUCCES[ 129.693434] p2p-wfd0-0:
S
[ 129.693445] wlan: Send EAPOL pkt to a8:XX:XX:XX:2d:1f
[ 129.794388] wlan: Received disassociation request on p2p-wfd0-0, reason: 3
[ 129.801285] wlan: REASON: (Deauth) Sending STA is leaving (or has left) IBSS or ESS
[ 129.804429] p2p-wfd0-0:
[ 129.808965] wlan: HostMlme Disconnected: sub_type=12 a8:XX:XX:XX:2d:1f
[ 130.055877] wlan: HostMlme p2p-wfd0-0 send auth to bssid a8:XX:XX:XX:2d:1f
[ 130.096961] p2p-wfd0-0:
[ 130.096983] wlan: HostMlme Auth received from a8:XX:XX:XX:2d:1f
[ 130.207597] wlan: HostMlme p2p-wfd0-0 Connected to bssid a8:XX:XX:XX:2d:1f su ccessfully
[ 130.217090] p2p-wfd0-0:
[ 130.217102] wlan: Send EAPOL pkt to a8:XX:XX:XX:2d:1f
[ 130.319644] p2p-wfd0-0:
[ 130.319655] wlan: Send EAPOL pkt to a8:XX:XX:XX:2d:1f
[ 130.327574] p2p-wfd0-0:
[ 130.327584] wlan: Send EAPOL pkt to a8:XX:XX:XX:2d:1f
[ 130.335519] p2p-wfd0-0:
[ 130.335529] wlan: Send EAPOL pkt to a8:XX:XX:XX:2d:1f
[ 130.344939] IPv6: ADDRCONF(NETDEV_CHANGE): p2p-wfd0-0: link becomes ready
<3>P2P-GROUP-STARTED p2p-wfd0[ 130.352705] woal_cfg80211_set_rekey_data return: gtk_rekey_offload is DISABLE
-0 client ssid="DIRECT-fo" freq=2437 psk=5a4529654a93eafc6c63a7ec8813c8678671c5c f7f550068f7e9dead2e557fe7 go_dev_addr=a8:10:87:6e:2d:1f
[ 130.416083] p2p-wfd0-0:
[ 130.416106] wlan: Send EAPOL pkt to a8:XX:XX:XX:2d:1f
[ 130.426502] woal_cfg80211_set_rekey_data return: gtk_rekey_offload is DISABLE
Oscar
