ISP - <v4l2src0:pool0:src> can't allocate, setting maximum to minimum
854件の閲覧回数
r3gl0
Dear experts,
I'm currently working with the NXP IMX8MPLUS and trying to enable the ISP for the MT9V024 camera sensor.
My current set up is the following:
Yocto core image with IMAGE_INSTALL:append = " kernel-module-isp-vvcam gstreamer1.0 gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad v4l-utils isp-imx libtinyxml2 media-ctl fmt ".
Linux 5.15.71 Kirkstone
Is a headless build
Externally, I build in V4L2 mode:
- isp-imx-4.2.2.20.0
- isp-vvcam (lf-5.15.y_2.2.0)
My video convertor is telling me that there is video at 30 fps, width=752, height=480 on DPHY0
However, I cannot get a image from Gstreamer. I dont get any hard error, the closest thing is this information message: " <v4l2src0:pool0:src> can't allocate, setting maximum to minimum. "
Here is an example
root@imx8mp:~/build-out/sdk# gst-launch-1.0 -v v4l2src device=/dev/video0 num-buffers=5 ! "video/x-raw,format=YUY2,width=752,height=480,framerate=30/1" ! fakesink dump=true
0:00:00.000184125  2271   0x5599042800 INFO                GST_INIT gst.c:592:init_pre: Initializing GStreamer Core Library version 1.20.3
0:00:00.000278625  2271   0x5599042800 INFO                GST_INIT gst.c:593:init_pre: Using library installed in /usr/lib
0:00:00.000314500  2271   0x5599042800 INFO                GST_INIT gst.c:611:init_pre: Linux imx8mp 5.15.71+gea9b003902ee #1 SMP PREEMPT Tue Sep 12 14:15:41 UTC 2023 aarch64
0:00:00.000854500  2271   0x5599042800 INFO                GST_INIT gstmessage.c:129:_priv_gst_message_initialize: init messages
0:00:00.002470000  2271   0x5599042800 INFO                GST_INIT gstcontext.c:86:_priv_gst_context_initialize: init contexts
0:00:00.003066500  2271   0x5599042800 INFO      GST_PLUGIN_LOADING gstplugin.c:324:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.003352750  2271   0x5599042800 INFO      GST_PLUGIN_LOADING gstplugin.c:232:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.003399125  2271   0x5599042800 INFO      GST_PLUGIN_LOADING gstplugin.c:234:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.003510875  2271   0x5599042800 INFO            GST_REGISTRY gstregistry.c:1827:ensure_current_registry: reading registry cache: /home/root/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.028175500  2271   0x5599042800 INFO            GST_REGISTRY gstregistrybinary.c:683:priv_gst_registry_binary_read_cache: loaded /home/root/.cache/gstreamer-1.0/registry.aarch64.bin in 0.024588 seconds
0:00:00.028346375  2271   0x5599042800 INFO            GST_REGISTRY gstregistry.c:1693:scan_and_update_registry: Validating plugins from registry cache: /home/root/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.036117875  2271   0x5599042800 INFO            GST_REGISTRY gstregistry.c:1785:scan_and_update_registry: Registry cache has not changed
0:00:00.036177625  2271   0x5599042800 INFO            GST_REGISTRY gstregistry.c:1862:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.036202250  2271   0x5599042800 INFO                GST_INIT gst.c:833:init_post: GLib runtime version: 2.72.3
0:00:00.036224750  2271   0x5599042800 INFO                GST_INIT gst.c:835:init_post: GLib headers version: 2.72.3
0:00:00.036241250  2271   0x5599042800 INFO                GST_INIT gst.c:837:init_post: initialized GStreamer successfully
0:00:00.036313000  2271   0x5599042800 INFO            GST_PIPELINE gstparse.c:344:gst_parse_launch_full: parsing pipeline description 'v4l2src device=/dev/video0 num-buffers=5 ! video/x-raw,format=YUY2,width=752,height=480,framerate=30/1 ! fakesink dump=true '
0:00:00.119030500  2271   0x5599042800 INFO      GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/gstreamer-1.0/libgstvideo4linux2.so" loaded
0:00:00.119095500  2271   0x5599042800 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "v4l2src"
0:00:00.125341875  2271   0x5599042800 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstBaseSrc@0x55991ea130> adding pad 'src'
0:00:00.127313750  2271   0x5599042800 INFO      GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:00.127381000  2271   0x5599042800 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "fakesink"
0:00:00.127746375  2271   0x5599042800 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstBaseSink@0x55991e0610> adding pad 'sink'
0:00:00.127839250  2271   0x5599042800 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "pipeline"
0:00:00.128087000  2271   0x5599042800 INFO            GST_PIPELINE gst/parse/grammar.y:683:gst_parse_perform_link: linking some pad of GstV4l2Src named v4l2src0 to some pad of GstFakeSink named fakesink0 (0/0) with caps "video/x-raw, format=(string)YUY2, width=(int)752, height=(int)480, framerate=(fraction)30/1"
0:00:00.128130875  2271   0x5599042800 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "capsfilter"
0:00:00.128345250  2271   0x5599042800 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstBaseTransform@0x55991f20e0> adding pad 'sink'
0:00:00.128396375  2271   0x5599042800 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstBaseTransform@0x55991f20e0> adding pad 'src'
0:00:00.128437250  2271   0x5599042800 INFO              GST_STATES gstbin.c:2069:gst_bin_get_state_func:<pipeline0> getting state
0:00:00.128494250  2271   0x5599042800 INFO              GST_STATES gstelement.c:2806:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:00.128527625  2271   0x5599042800 INFO               GST_EVENT gstevent.c:1660:gst_event_new_reconfigure: creating reconfigure event
0:00:00.128564625  2271   0x5599042800 INFO        GST_ELEMENT_PADS gstutils.c:1816:gst_element_link_pads_full: trying to link element v4l2src0:(any) to element capsfilter0:sink
0:00:00.128592375  2271   0x5599042800 INFO        GST_ELEMENT_PADS gstelement.c:1016:gst_element_get_static_pad: found pad capsfilter0:sink
0:00:00.128618625  2271   0x5599042800 INFO                GST_PADS gstutils.c:1632:prepare_link_maybe_ghosting: v4l2src0 and capsfilter0 in same bin, no need for ghost pads
0:00:00.128662250  2271   0x5599042800 INFO                GST_PADS gstpad.c:2382:gst_pad_link_prepare: trying to link v4l2src0:src and capsfilter0:sink
0:00:00.128706250  2271   0x5599042800 INFO                GST_PADS gstpad.c:4357:gst_pad_peer_query:<capsfilter0:src> pad has no peer
0:00:00.128765750  2271   0x5599042800 INFO                GST_PADS gstpad.c:2590:gst_pad_link_full: linked v4l2src0:src and capsfilter0:sink, successful
0:00:00.128787375  2271   0x5599042800 INFO               GST_EVENT gstevent.c:1660:gst_event_new_reconfigure: creating reconfigure event
0:00:00.128810125  2271   0x5599042800 INFO               GST_EVENT gstpad.c:5946:gst_pad_send_event_unchecked:<v4l2src0:src> Received event on flushing pad. Discarding
0:00:00.128849500  2271   0x5599042800 INFO        GST_ELEMENT_PADS gstutils.c:1816:gst_element_link_pads_full: trying to link element capsfilter0:src to element fakesink0:(any)
0:00:00.128876375  2271   0x5599042800 INFO        GST_ELEMENT_PADS gstelement.c:1016:gst_element_get_static_pad: found pad capsfilter0:src
0:00:00.128907875  2271   0x5599042800 INFO                GST_PADS gstutils.c:1079:gst_pad_check_link: trying to link capsfilter0:src and fakesink0:sink
0:00:00.128978125  2271   0x5599042800 INFO                GST_PADS gstutils.c:1632:prepare_link_maybe_ghosting: capsfilter0 and fakesink0 in same bin, no need for ghost pads
0:00:00.129011625  2271   0x5599042800 INFO                GST_PADS gstpad.c:2382:gst_pad_link_prepare: trying to link capsfilter0:src and fakesink0:sink
0:00:00.129071250  2271   0x5599042800 INFO                GST_PADS gstpad.c:2590:gst_pad_link_full: linked capsfilter0:src and fakesink0:sink, successful
0:00:00.129091000  2271   0x5599042800 INFO               GST_EVENT gstevent.c:1660:gst_event_new_reconfigure: creating reconfigure event
0:00:00.129110625  2271   0x5599042800 INFO               GST_EVENT gstpad.c:5946:gst_pad_send_event_unchecked:<capsfilter0:src> Received event on flushing pad. Discarding
0:00:00.130531250  2271   0x5599042800 INFO              GST_STATES gstbin.c:2479:gst_bin_element_set_state:<fakesink0> current NULL pending VOID_PENDING, desired next READY
0:00:00.130569250  2271   0x5599042800 INFO              GST_STATES gstelement.c:2806:gst_element_continue_state:<fakesink0> completed state change to READY
0:00:00.130595000  2271   0x5599042800 INFO              GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<fakesink0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.130650625  2271   0x5599042800 INFO              GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'fakesink0' changed state to 2(READY) successfully
0:00:00.130682375  2271   0x5599042800 INFO              GST_STATES gstbin.c:2479:gst_bin_element_set_state:<capsfilter0> current NULL pending VOID_PENDING, desired next READY
0:00:00.130707125  2271   0x5599042800 INFO              GST_STATES gstelement.c:2806:gst_element_continue_state:<capsfilter0> completed state change to READY
0:00:00.130731875  2271   0x5599042800 INFO              GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.130764125  2271   0x5599042800 INFO              GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 2(READY) successfully
0:00:00.130796000  2271   0x5599042800 INFO              GST_STATES gstbin.c:2479:gst_bin_element_set_state:<v4l2src0> current NULL pending VOID_PENDING, desired next READY
0:00:00.131003250  2271   0x5599042800 INFO                    v4l2 v4l2_calls.c:588:gst_v4l2_open:<v4l2src0:src> Opened device 'VIV' (/dev/video0) successfully
0:00:00.131045250  2271   0x5599042800 INFO              GST_STATES gstelement.c:2806:gst_element_continue_state:<v4l2src0> completed state change to READY
0:00:00.131071625  2271   0x5599042800 INFO              GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<v4l2src0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.131107625  2271   0x5599042800 INFO              GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 2(READY) successfully
0:00:00.131145375  2271   0x5599042800 INFO              GST_STATES gstelement.c:2778:gst_element_continue_state:<pipeline0> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.131173500  2271   0x5599042800 INFO              GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.131253250  2271   0x5599042800 INFO              GST_STATES gstelement.c:2786:gst_element_continue_state:<pipeline0> continue state change READY to PAUSED, final PAUSED
0:00:00.131305125  2271   0x5599042800 INFO              GST_STATES gstbin.c:2479:gst_bin_element_set_state:<fakesink0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.131356500  2271   0x5599042800 INFO              GST_STATES gstbin.c:2935:gst_bin_change_state_func:<pipeline0> child 'fakesink0' is changing state asynchronously to PAUSED
0:00:00.131389875  2271   0x5599042800 INFO              GST_STATES gstbin.c:2479:gst_bin_element_set_state:<capsfilter0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.131430000  2271   0x5599042800 INFO              GST_STATES gstelement.c:2806:gst_element_continue_state:<capsfilter0> completed state change to PAUSED
0:00:00.131456875  2271   0x5599042800 INFO              GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.131492250  2271   0x5599042800 INFO              GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 3(PAUSED) successfully
0:00:00.131522125  2271   0x5599042800 INFO              GST_STATES gstbin.c:2479:gst_bin_element_set_state:<v4l2src0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.131581625  2271   0x5599042800 INFO                 basesrc gstbasesrc.c:1430:gst_base_src_do_seek:<v4l2src0> seeking: time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:00.131684250  2271   0x5599042800 INFO                    task gsttask.c:516:gst_task_set_lock: setting stream lock 0x55991ec260 on task 0x55991f4050
0:00:00.131710000  2271   0x5599042800 INFO                GST_PADS gstpad.c:6291:gst_pad_start_task:<v4l2src0:src> created task 0x55991f4050
0:00:00.131884375  2271   0x5599042800 INFO              GST_STATES gstelement.c:2806:gst_element_continue_state:<v4l2src0> completed state change to PAUSED
0:00:00.131916375  2271   0x5599042800 INFO              GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<v4l2src0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.131957500  2271   0x5599042800 INFO              GST_STATES gstbin.c:2971:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 3(PAUSED) successfully without preroll
0:00:00.131983625  2271   0x55991b3460 INFO        GST_ELEMENT_PADS gstelement.c:1013:gst_element_get_static_pad: no such pad 'sink' in element "v4l2src0"
0:00:00.131995000  2271   0x5599042800 INFO                pipeline gstpipeline.c:533:gst_pipeline_change_state:<pipeline0> pipeline is live
0:00:00.132039500  2271   0x5599042800 INFO              GST_STATES gstelement.c:2806:gst_element_continue_state:<pipeline0> completed state change to PAUSED
0:00:00.132067875  2271   0x5599042800 INFO              GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.132120625  2271   0x55991b3460 INFO                 v4l2src gstv4l2src.c:550:gst_v4l2src_query_preferred_size:<v4l2src0> Detect input 0 as `camera`
Pipeline is live and does not need PREROLL ...
0:00:00.132187750  2271   0x55991b3460 INFO                    v4l2 gstv4l2object.c:1241:gst_v4l2_object_fill_format_list:<v4l2src0:src> got 4 format(s):
0:00:00.132220375  2271   0x55991b3460 INFO                    v4l2 gstv4l2object.c:1245:gst_v4l2_object_fill_format_list:<v4l2src0:src>   YUYV
0:00:00.132250750  2271   0x55991b3460 INFO                    v4l2 gstv4l2object.c:1245:gst_v4l2_object_fill_format_list:<v4l2src0:src>   NV12
0:00:00.132277000  2271   0x55991b3460 INFO                    v4l2 gstv4l2object.c:1245:gst_v4l2_object_fill_format_list:<v4l2src0:src>   NV16
0:00:00.132330375  2271   0x55991b3460 INFO                    v4l2 gstv4l2object.c:1245:gst_v4l2_object_fill_format_list:<v4l2src0:src>   BA10
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
0:00:00.133349250  2271   0x5599042800 INFO               GST_EVENT gstevent.c:1530:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.133414375  2271   0x5599042800 INFO                     bin gstbin.c:2759:gst_bin_do_latency_func:<pipeline0> configured latency of 0:00:00.000000000
0:00:00.133470250  2271   0x5599042800 INFO              GST_STATES gstbin.c:2479:gst_bin_element_set_state:<fakesink0> current READY pending PAUSED, desired next PLAYING
0:00:00.133500625  2271   0x5599042800 INFO              GST_STATES gstbin.c:2935:gst_bin_change_state_func:<pipeline0> child 'fakesink0' is changing state asynchronously to PLAYING
0:00:00.133534000  2271   0x5599042800 INFO              GST_STATES gstbin.c:2479:gst_bin_element_set_state:<capsfilter0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.133564625  2271   0x5599042800 INFO              GST_STATES gstelement.c:2806:gst_element_continue_state:<capsfilter0> completed state change to PLAYING
0:00:00.133592125  2271   0x5599042800 INFO              GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.133632125  2271   0x5599042800 INFO              GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 4(PLAYING) successfully
0:00:00.133668750  2271   0x5599042800 INFO              GST_STATES gstelement.c:2806:gst_element_continue_state:<v4l2src0> completed state change to PLAYING
0:00:00.133696625  2271   0x5599042800 INFO              GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<v4l2src0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.133766250  2271   0x5599042800 INFO              GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 4(PLAYING) successfully
New clock: GstSystemClock
0:00:00.278604625  2271   0x55991b3460 INFO                    v4l2 gstv4l2object.c:4752:gst_v4l2_object_probe_caps:<v4l2src0:src> probed caps: video/x-raw, format=(string)YUY2, width=(int)[ 176, 4096, 16 ], height=(int)[ 144, 3072, 8 ], pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 29/1, 28/1, 27/1, 26/1, 25/1, 24/1, 23/1, 22/1, 21/1, 20/1, 19/1, 18/1, 17/1, 16/1, 15/1, 14/1, 13/1, 12/1, 11/1, 10/1, 9/1, 8/1, 7/1, 6/1, 5/1, 4/1, 3/1, 2/1, 1/1 }; video/x-raw(format:Interlaced), format=(string)YUY2, width=(int)[ 176, 4096, 16 ], height=(int)[ 144, 3072, 8 ], pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 29/1, 28/1, 27/1, 26/1, 25/1, 24/1, 23/1, 22/1, 21/1, 20/1, 19/1, 18/1, 17/1, 16/1, 15/1, 14/1, 13/1, 12/1, 11/1, 10/1, 9/1, 8/1, 7/1, 6/1, 5/1, 4/1, 3/1, 2/1, 1/1 }, interlace-mode=(string)alternate; video/x-raw, format=(string)NV12, width=(int)[ 176, 4096, 16 ], height=(int)[ 144, 3072, 8 ], pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 29/1, 28/1, 27/1, 26/1, 25/1, 24/1, 23/1, 22/1, 21/1, 20/1, 19/1, 18/1, 17/1, 16/1, 15/1, 14/1, 13/1, 12/1, 11/1, 10/1, 9/1, 8/1, 7/1, 6/1, 5/1, 4/1, 3/1, 2/1, 1/1 }; video/x-raw(format:Interlaced), format=(string)NV12, width=(int)[ 176, 4096, 16 ], height=(int)[ 144, 3072, 8 ], pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 29/1, 28/1, 27/1, 26/1, 25/1, 24/1, 23/1, 22/1, 21/1, 20/1, 19/1, 18/1, 17/1, 16/1, 15/1, 14/1, 13/1, 12/1, 11/1, 10/1, 9/1, 8/1, 7/1, 6/1, 5/1, 4/1, 3/1, 2/1, 1/1 }, interlace-mode=(string)alternate; video/x-raw, format=(string)NV16, width=(int)[ 176, 4096, 16 ], height=(int)[ 144, 3072, 8 ], pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 29/1, 28/1, 27/1, 26/1, 25/1, 24/1, 23/1, 22/1, 21/1, 20/1, 19/1, 18/1, 17/1, 16/1, 15/1, 14/1, 13/1, 12/1, 11/1, 10/1, 9/1, 8/1, 7/1, 6/1, 5/1, 4/1, 3/1, 2/1, 1/1 }; video/x-raw(format:Interlaced), format=(string)NV16, width=(int)[ 176, 4096, 16 ], height=(int)[ 144, 3072, 8 ], pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 29/1, 28/1, 27/1, 26/1, 25/1, 24/1, 23/1, 22/1, 21/1, 20/1, 19/1, 18/1, 17/1, 16/1, 15/1, 14/1, 13/1, 12/1, 11/1, 10/1, 9/1, 8/1, 7/1, 6/1, 5/1, 4/1, 3/1, 2/1, 1/1 }, interlace-mode=(string)alternate
0:00:00.290160875  2271   0x55991b3460 INFO                 v4l2src gstv4l2src.c:647:gst_v4l2src_negotiate:<v4l2src0> fixated to: video/x-raw, format=(string)YUY2, width=(int)752, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709
0:00:00.290237750  2271   0x55991b3460 INFO               GST_EVENT gstevent.c:892:gst_event_new_caps: creating caps event video/x-raw, format=(string)YUY2, width=(int)752, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709
0:00:00.290429750  2271   0x55991b3460 INFO           basetransform gstbasetransform.c:1325:gst_base_transform_setcaps:<capsfilter0> reuse caps
0:00:00.290487375  2271   0x55991b3460 INFO               GST_EVENT gstevent.c:892:gst_event_new_caps: creating caps event video/x-raw, format=(string)YUY2, width=(int)752, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, format=(string)YUY2, width=(int)752, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, format=(string)YUY2, width=(int)752, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw, format=(string)YUY2, width=(int)752, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, format=(string)YUY2, width=(int)752, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709
0:00:00.406382625  2271   0x55991b3460 INFO                    v4l2 gstv4l2object.c:4083:gst_v4l2_object_set_format_full:<v4l2src0:src> Set capture framerate to 30/1
0:00:00.406454875  2271   0x55991b3460 INFO                    v4l2 gstv4l2object.c:3251:gst_v4l2_object_setup_pool:<v4l2src0:src> accessing buffers via mode 4
0:00:00.407197375  2271   0x55991b3460 INFO          v4l2bufferpool gstv4l2bufferpool.c:604:gst_v4l2_buffer_pool_set_config:<v4l2src0:pool0:src> increasing minimum buffers to 2
0:00:00.407344250  2271   0x55991b3460 INFO          v4l2bufferpool gstv4l2bufferpool.c:617:gst_v4l2_buffer_pool_set_config:<v4l2src0:pool0:src> reducing maximum buffers to 32
0:00:00.407469375  2271   0x55991b3460 INFO          v4l2bufferpool gstv4l2bufferpool.c:628:gst_v4l2_buffer_pool_set_config:<v4l2src0:pool0:src> can't allocate, setting maximum to minimum
0:00:00.407735125  2271   0x55991b3460 INFO          v4l2bufferpool gstv4l2bufferpool.c:617:gst_v4l2_buffer_pool_set_config:<v4l2src0:pool0:src> reducing maximum buffers to 32
0:00:00.407767625  2271   0x55991b3460 INFO          v4l2bufferpool gstv4l2bufferpool.c:628:gst_v4l2_buffer_pool_set_config:<v4l2src0:pool0:src> can't allocate, setting maximum to minimum
0:00:00.420490625  2271   0x55991b3460 WARN          v4l2bufferpool gstv4l2bufferpool.c:884:gst_v4l2_buffer_pool_start:<v4l2src0:pool0:src> Uncertain or not enough buffers, enabling copy threshold
I also tried gst-launch-1.0 -v  v4l2src device=/dev/video0 ! "video/x-raw,format=YUY2,width=752,height=480" ! queue ! videoconvert ! theoraenc ! oggmux ! filesink location=test_image.ogv , but i get a similar log.
Can anyone point me to the root of the issue?
My device tree looks like this:
&isp_0 {
    status = "okay";
&isp_1 {
    status = "disabled";
&dewarp {
    status = "okay";
&cameradev {
    status = "okay";
&isi_0 {
    cap_device {
&isi_1 {
    cap_device {
&mipi_csi_0 {
    status = "okay";
    port@0 {
        reg = <0>;
        mipi_csi0_ep: endpoint {
            remote-endpoint = <&mt9v024_mipi_0_ep>;
            data-lanes = <4>;
            csis-hs-settle = <16>;
dmesg log:
[ 1740.645667] enter viv_dwe_exit_module
[ 1740.645797] enter dwe_hw_remove
[ 1740.645893] enter fake_pdev_release
[ 1740.645898] vvcam dewarp driver removed
[ 1740.665504] enter viv_isp_exit_module
[ 1740.665647] enter isp_hw_remove
[ 1740.665655] vvcam isp driver removed
[ 1740.701803] : Unregistered all entities
[ 1740.735600]
                MT9V024, r3gl0: probe
[ 1740.735611] enter mt9v024_probe
[ 1740.735621] xclk frequency: 24000000 Hz
[ 1740.735626]
                MT9V024, r3gl0 mt9v024_read_reg16: Reading reg=0x0000
[ 1740.749169] MT9V024, CHIP VERSION MATCH
[ 1740.749178]
                MT9V024, r3gl0: before after
[ 1740.749196] mt9v024_probe camera mipi mt9v024, is found
[ 1740.767059] enter viv_isp_init_module
[ 1740.767405] enter isp_hw_probe
[ 1740.767471] vvcam isp driver registered
[ 1740.778665] enter viv_dwe_init_module
[ 1740.778987] enter dwe_hw_probe
[ 1740.779312] vvcam dewarp driver probed
[ 1740.789973] enter viv_video_init_module
[ 1740.804690] imx8_media_dev: module is from the staging directory, the quality is unknown, you hav
e been warned.
[ 1740.805623] mx8-img-md: Registered sensor subdevice: mt9v024 2-0048 (1)
[ 1740.805644]
                MT9V024, r3gl0: Entering link_setup
[ 1740.805647]
                MT9V024, r3gl0: Entity name: mt9v024 2-0048
[ 1740.805649]
                MT9V024, r3gl0: Local pad index: 0, flags: 2
[ 1740.805653]
                MT9V024, r3gl0: Remote pad index: 0, flags: 1
[ 1740.805655]
                MT9V024, r3gl0: Link flags: 0
[ 1740.805658]
                MT9V024, r3gl0: Exiting link_setup
[ 1740.805660] mx8-img-md: created link [mt9v024 2-0048] => [mxc-mipi-csi2.0]
[ 1740.805666] mxc-md 32c00000.bus:camera: mxc_md_create_links
[ 1740.821137] enter isp_mi_stop
[ 1740.822206]
                MT9V024, r3gl0: mt9v024_enum_mbus_code
[ 1740.822218]
                MT9V024, r3gl0: mt9v024_get_format_code
[ 1740.822221]
                getting MEDIA_BUS_FMT_SGRBG10_1X10
[ 1740.823629]
                MT9V024, r3gl0: mt9v024_priv_ioctl request, cmd=-2140645888
[ 1740.823647]
                MT9V024, r3gl0: mt9v024_query_capability
[ 1740.823650]
                MT9V024, r3gl0: mt9v024_query_capability + case
[ 1740.823652]
                MT9V024, r3gl0: returned mt9v024_query_capability
[ 1740.823655]
                MT9V024, r3gl0: mt9v024_priv_ioctl after case, ret=0
[ 1740.823658]
                MT9V024, r3gl0: mt9v024_priv_ioctl before final return
[ 1740.823660]
                flusher
[ 4323.157378]
[ 4323.157391]
[ 4323.157395]
[ 4323.157397]
[ 4323.157399]
[ 4323.157402]
[ 4323.157404]
                flusher
[ 4323.169944] enter isp_mi_stop
[ 4323.233321]
[ 4323.233332]
[ 4323.233336]
[ 4323.284807]
[ 4323.284822]
[ 4323.284826]
[ 4323.284829]
[ 4323.284832]
[ 4323.284835]
[ 4323.284838]
                flusher
[ 4323.297599] enter isp_mi_stop
[ 4323.365311]
[ 4323.365321]
[ 4323.365325]
[ 4323.444996]
[ 4323.445008]
[ 4323.445012]
[ 4323.445045]
[ 4323.445052]
[ 4323.445056]
[ 4323.445059]
[ 4323.445061]
[ 4323.445065]
[ 4323.445068]
                flusher
[ 4323.457682]
                MT9V024, r3gl0: mt9v024_priv_ioctl request, cmd=261
[ 4323.457698]
                MT9V024, r3gl0: VVSENSORIOC_QUERY
[ 4323.457701]
                MT9V024, r3gl0: CONFIG_HARDENED_USERCOPY = 0
[ 4323.457704]
                MT9V024, r3gl0: mt9v024_query_supports
[ 4323.457707]
[ 4323.457711]
[ 4323.457713]
                flusher
[ 4323.626584]
[ 4323.626602]
[ 4323.626604]
[ 4323.626606]
[ 4323.626609]
[ 4323.626612]
[ 4323.626614]
                flusher
[ 4323.626627]
                MT9V024, r3gl0: mt9v024_priv_ioctl request, cmd=257
[ 4323.626630]
[ 4323.626632]
[ 4323.626634]
                flusher
[ 4323.626638]
                MT9V024, r3gl0: mt9v024_priv_ioctl request, cmd=260
[ 4323.626640]
                MT9V024, r3gl0 mt9v024_get_clk
[ 4323.626644]
[ 4323.626646]
[ 4323.626648]
                flusher
[ 4323.626652]
                MT9V024, r3gl0: mt9v024_priv_ioctl request, cmd=259
[ 4323.626654]
[ 4323.626657]
[ 4323.626659]
                flusher
[ 4323.626662]
                MT9V024, r3gl0: mt9v024_priv_ioctl request, cmd=256
[ 4323.626665]
[ 4323.626667]
[ 4323.626669]
                flusher
[ 4323.626672]
                MT9V024, r3gl0: mt9v024_priv_ioctl request, cmd=262
[ 4323.626675]
                MT9V024, r3gl0: mt9v024_set_sensor_mode
[ 4323.626678]
[ 4323.626681]
[ 4323.626683]
                flusher
[ 4323.626686]
                MT9V024, r3gl0: mt9v024_priv_ioctl request, cmd=263
[ 4323.626688]
                MT9V024, r3gl0: mt9v024_get_sensor_mode
[ 4323.626691]
[ 4323.626693]
[ 4323.626695]
                flusher
[ 4323.626701]
[ 4323.626703]
[ 4323.626705]
[ 4323.626707]
[ 4323.626709]
[ 4323.626712]
[ 4323.626714]
                flusher
[ 4323.639847] enter isp_mi_stop
[ 4323.642856]
                MT9V024, r3gl0: mt9v024_set_fmt
[ 4323.642866]
[ 4323.642869]
[ 4323.642876]
                MT9V024, r3gl0: mt9v024_priv_ioctl request, cmd=285
[ 4323.642881]
                MT9V024, r3gl0 mt9v024_set_test_pattern - NOT implemented
[ 4323.642883]
[ 4323.642886]
[ 4323.642888]
                flusher
[ 4323.642898]
                MT9V024, r3gl0: mt9v024_priv_ioctl request, cmd=279
[ 4323.642901]
[ 4323.642903]
[ 4323.642905]
                flusher
[ 4323.642908]
[ 4323.642911]
[ 4323.642913]
[ 4323.642916]
[ 4323.642918]
                flusher
[ 4323.643324]
                MT9V024, r3gl0: mt9v024_priv_ioctl request, cmd=274
[ 4323.643332]
                MT9V024, r3gl0 mt9v024_set_exp - Not implemented
[ 4323.643335]
[ 4323.643338]
[ 4323.643340]
                flusher
[ 4323.643346]
                MT9V024, r3gl0: mt9v024_priv_ioctl request, cmd=277
[ 4323.643348]
                MT9V024, r3gl0 mt9v024_set_gain - Not implemented
[ 4323.643350]
[ 4323.643353]
[ 4323.643355]
                flusher
[ 4323.645211]
[ 4323.645223]
[ 4323.645226]
[ 4323.645342]
[ 4323.645345]
[ 4323.645347]
[ 4323.645486] enter isp_s_comp
[ 4323.645500] enter isp_s_comp
[ 4323.645505] enter isp_s_comp
[ 4323.645605]
[ 4323.645608]
[ 4323.645610]
[ 4323.661739] enter wdr3_hw_init
[ 4323.661752] wdr3 res: 752 480
[ 4323.693491] enter isp_set_stream 1
[ 4323.704723] enter isp_mi_start
[ 4323.705232]
                MT9V024, r3gl0: mt9v024_priv_ioctl request, cmd=272
[ 4323.705245]
                MT9V024, r3gl0: mt9v024_s_stream enable: 1
[ 4323.705249]
                MT9V024, r3gl0: mt9v024_superinit
[ 4327.005171]  MT9V024, r3gl0: Sensor enabled
this is how my media looks like:
root@imx8mp:~/build-out/sdk# media-ctl -p -d /dev/media0
Media controller API version 5.15.71
Media device information
driver          vvcam-video
model           viv_media
serial
bus info
hw revision     0x0
driver version  5.15.71
Device topology
- entity 1: viv_v4l20 (1 pad, 1 link)
            type Node subtype V4L flags 0
            device node name /dev/video0
        pad0: Sink
                <- "vvcam-dwe.0":0 [ENABLED]
- entity 5: vvcam-dwe.0 (2 pads, 2 links)
            device node name /dev/v4l-subdev0
        pad0: Source
                -> "viv_v4l20":0 [ENABLED]
        pad1: Sink
                <- "vvcam-isp.0":0 [ENABLED]
- entity 8: vvcam-isp.0 (1 pad, 1 link)
            device node name /dev/v4l-subdev1
        pad0: Source
                -> "vvcam-dwe.0":1 [ENABLED]
root@imx8mp:~/build-out/sdk# media-ctl -p -d /dev/media1
driver          mxc-md
model           FSL Capture Media Device
serial
bus info
hw revision     0x0
Device topology
- entity 1: mxc-mipi-csi2.0 (8 pads, 1 link)
            device node name /dev/v4l-subdev2
        pad0: Sink
                <- "mt9v024 2-0048":0 [ENABLED,IMMUTABLE]
        pad1: Sink
        pad2: Sink
        pad3: Sink
        pad4: Source
        pad5: Source
        pad6: Source
        pad7: Source
- entity 10: mt9v024 2-0048 (1 pad, 1 link)
             type V4L2 subdev subtype Sensor flags 0
             device node name /dev/v4l-subdev3
        pad0: Source
                [fmt:SGRBG10_1X10/752x480 field:none]
                -> "mxc-mipi-csi2.0":0 [ENABLED,IMMUTABLE]
my dewarp json file looks like this:
"dewarpConfigArray" :[
"source_image":{
"width" : 752,
"height" : 480
"?dewarpType": "LENS_CORRECTION, FISHEYE_EXPAND, SPLIT_SCREEN",
"dewarpType": "FISHEYE_DEWARP",
"scale": {
"roix" : 0,
"roiy" : 0,
"factor" : 1.0
"split": {
"horizon_line" : 240,
"vertical_line_up" : 367,
"vertical_line_down": 367
"bypass" : true,
"hflip" : false,
"vflip" : false,
"camera_matrix" : [ 3.9177894938743270e+003, 0., 1.9716642989691159e+003, 0.,3.9177894938743270e+003, 1.1024451486734267e+003, 0., 0., 1. ],
"distortion_coeff": [ -1.3019040624278982e-001, 2.2621318183135611e-001,1.2109476203374344e-003, 9.4317229120640680e-004,-7.1053958306120402e-001 ],
"perspective" : [1.0, 0, 0, 0, 1, 0, 0, 0, 1]
タグ(3)
423件の閲覧回数
r3gl0
I had a hardware issue that did not allowed proper CSI communication.
Regarding adapting the 1920x1080 to 752x480, I can confirm it does not produce a correct image, but it will get you an output.
4 返答(返信)
753件の閲覧回数
Bio_TICFSL
668件の閲覧回数
r3gl0
Hi @Bio_TICFSL, I already checked this, but it's been hard to pinpoint the exact error
I have a theory: I created my calibration file by borrowing the OS08a20_8M_10_1080p_linear.xml file. I did change the sensor name and resolution strings to match my sensor, but I’m wondering if changing the resolution from 1920x1080 to 752x480 could be causing an issue with the ISP. I understand this wouldn’t produce a correct image, but at this point, I’m just trying to get any kind of signal image, even if it’s distorted or incorrect.
Is this likely the reason I’m not getting any output at all? Or should I still expect to get at least something even with an incorrect calibration?
If this is the issue, is there a way I can generate a basic/dummy 752x480 calibration file just to test and get some output? I’m not concerned about image quality right now, I am just looking for testing the pipeline.
424件の閲覧回数
r3gl0
672件の閲覧回数
r3gl0
I also built isp-imx in debug mode and tried the following:
root@imx8mp:~/build-out/sdk# gst-launch-1.0 -v v4l2src device=/dev/video0 ! "video/x-raw,format=YUY2,width=752,height=480,framerate=30/1" ! fakesink dump=true
INFO : [V4l2Event] Compose: left=0,top=0,width=752,height=480
INFO : [NativeSensor] jsonRequest 0xa01f
INFO : [MediaPipeline] MEDIA_EVENT_STREAM_OPEN
INFO : [MediaPipeline] stream0 connect NativeSensor:0 ---> NativeDewarp:0
INFO : [MediaPipeline] stream0 connect NativeDewarp:0 ---> V4l2Control:0
INFO : [MediaPipeline] MEDIA_EVENT_STREAM_SET_FMT
INFO : [MediaPipeline] set format:0 res: 752 480 1
INFO : [NativeSensor] setFormat isp crop: bounds 752X480 left 0 top 0 size 752X480
INFO : [NativeSensor] setFormat isp scale: bounds 752X480 left 0 top 0 size 752X480
[CITF][INF]: RESULT camdev::CitfDevice::calibrationLoadandInit(Json::Value&, Json::Value&)
[CITF][INF]: camdev::Operation::Operation(camdev::Operation_Handle*) (enter)
[CITF][INF]: camdev::SensorOps::SensorOps(camdev::CalibSensor&, HalHolder*) (enter)
[CITF][INF]: camdev::SensorOps::SensorOps(camdev::CalibSensor&, HalHolder*) (exit)
[CITF][INF]: camdev::Operation::Operation(camdev::Operation_Handle*) (exit)
[CITF][INF]: RESULT camdev::CitfSensor::sensorOpen(Json::Value&, Json::Value&)
CALIB_INF: tag: AF
CALIB_INF: tag: AEC
CALIB_WAN: Don't support: DampOverVideo
CALIB_WAN: Don't support: DampUnderVideo
CALIB_INF: tag: DEGAMMA
CALIB_INF: tag: WDR
[CITF][INF]: CitfBufferPoolClearBufList!, chain ID:0
[CITF][INF]: camdev::BuffPool* camdev::Bitf::bitfGetBufferPoolCtrl(ISPCORE_BUFIO_ID)
INFO : [MediaBufferQueue] create buffer queue 752 480 1 4
DEBUG : [MediaBuffer] alloc buffer 0x66c00000 0x000b1000
DEBUG : [MediaBuffer] alloc buffer 0x66d00000 0x000b1000
DEBUG : [MediaBuffer] alloc buffer 0x66f00000 0x000b1000
DEBUG : [MediaBuffer] alloc buffer 0x67000000 0x000b1000
INFO : [NativeSensor] push NativeDewarp sink buffer 0x66c00000 into isp
[CITF][INF]: CitfBufferPoolAddEntity!, chain ID:0
[CITF][INF]: static RESULT camdev::Bitf::bitfCheckBufSizeMax(uint32_t, ISPCORE_BUFIO_ID)
INFO : [NativeSensor] push NativeDewarp sink buffer 0x66d00000 into isp
INFO : [NativeSensor] push NativeDewarp sink buffer 0x66f00000 into isp
INFO : [NativeSensor] push NativeDewarp sink buffer 0x67000000 into isp
[CITF][INF]: CitfBufferPoolKernelAddrMap!, chain ID:0
[CITF][INF]: CitfBufferPoolSetBufToEngine!, chain ID:0
[CITF][INF]: CitfBufferPoolSetBufToEngine!, chain ID:0 buffer counter number , buf_context:4, set to Engine:4
[CITF][INF]: static RESULT camdev::Bitf::bitfCheckBufNumberMax(uint32_t, ISPCORE_BUFIO_ID)
[CITF][INF]: RESULT camdev::CitfDevice::cameraConnect(Json::Value&, Json::Value&)
[CITF][INF]: int32_t camdev::Operation::cameraConnect(bool, ItfBufferCb*, const ConnectInfo&) (enter)
CAMERIC-MI-DRV: CamerIcMiInit: (enter)
CAMERIC-MI-DRV: CamerIcMiInit: (exit)
CAMERIC-ISP-WDR-DRV: CamerIcIspWdr2Init: (enter)
CAMERIC-ISP-WDR-DRV: CamerIcIspWdr2Init: (exit)
[CITF][INF]: pathConfigSet in, set path, state: 0
[CITF][INF]: int32_t camdev::Operation::inputConnect() (enter)
CAMERIC-MI-DRV: CamerIcMiRegisterRequestCb: (enter)
CAMERIC-MI-DRV: CamerIcMiRegisterRequestCb: (exit)
CAMERIC-MI-DRV: CamerIcMiRegisterEventCb: (enter)
CAMERIC-MI-DRV: CamerIcMiRegisterEventCb: (exit)
CAMERIC-ISP-CAC-DRV: CamerIcIspCacDisable: (enter)
CAMERIC-ISP-CAC-DRV: CamerIcIspCacDisable: (exit)
CAMERIC-ISP-CAC-DRV: CamerIcIspCacConfig: (enter)
CAMERIC-ISP-CAC-DRV: CamerIcIspCacConfig: (exit)
CAMERIC-ISP-CAC-DRV: CamerIcIspCacEnable: (enter)
CAMERIC-ISP-CAC-DRV: CamerIcIspCacEnable: (exit)
CAMERIC-MI-DRV: CamerIcMiSetBurstLength: (enter)
CAMERIC-MI-DRV: CamerIcMiSetBurstLength: (exit)
CAMERIC-MI-DRV: CamerIcMiSetResolution: (enter)
CAMERIC-MI-DRV: CamerIcMiSetResolution: set resolution 0 (752, 480)->(752, 480)
CAMERIC-MI-DRV: CamerIcMiSetResolution: (exit)
CAMERIC-MI-DRV: CamerIcMiSetResolution: set resolution 1 (752, 480)->(752, 480)
CAMERIC-MI-DRV: CamerIcMiSetResolution: set resolution 2 (752, 480)->(752, 480)
CAMERIC-MI-DRV: CamerIcMiSetResolution: set resolution 3 (752, 480)->(752, 480)
CAMERIC-MI-DRV: CamerIcMiSetResolution: set resolution 4 (752, 480)->(752, 480)
CAMERIC-MI-DRV: CamerIcMiSetDataMode: (enter) 4
CAMERIC-MI-DRV: CamerIcMiSetDataMode: set datamode (0, 4)
CAMERIC-MI-DRV: CamerIcMiSetDataMode: (exit)
CAMERIC-MI-DRV: CamerIcMiSetDataLayout: (enter)
CAMERIC-MI-DRV: CamerIcMiSetDataLayout: set datalayout (0, 3)
CAMERIC-MI-DRV: CamerIcMiSetDataLayout: (exit)
CAMERIC-MI-DRV: CamerIcMiSetDataAlignMode: (enter) alignmode: 0, path:0
CAMERIC-MI-DRV: CamerIcMiSetDataAlignMode: set data_align_mode (0, 0)
CAMERIC-MI-DRV: CamerIcMiSetDataAlignMode: (exit)
CAMERIC-MI-DRV: CamerIcMiSetDataMode: (enter) 1
CAMERIC-MI-DRV: CamerIcMiSetDataMode: set datamode (1, 1)
CAMERIC-MI-DRV: CamerIcMiSetDataLayout: set datalayout (1, 3)
CAMERIC-MI-DRV: CamerIcMiSetDataAlignMode: (enter) alignmode: 0, path:1
CAMERIC-MI-DRV: CamerIcMiSetDataAlignMode: set data_align_mode (1, 0)
CAMERIC-MI-DRV: CamerIcMiSetDataMode: set datamode (2, 1)
CAMERIC-MI-DRV: CamerIcMiSetDataLayout: set datalayout (2, 3)
CAMERIC-MI-DRV: CamerIcMiSetDataAlignMode: (enter) alignmode: 0, path:2
CAMERIC-MI-DRV: CamerIcMiSetDataAlignMode: set data_align_mode (2, 0)
[CITF][INF]: CAM_ENGINE_CMD_START, ret = 0x0
[CITF][INF]: int32_t camdev::Operation::inputConnect() (exit)
[CITF][INF]: int32_t camdev::Operation::cameraConnect(bool, ItfBufferCb*, const ConnectInfo&) (exit)
INFO : [NativeSensor] setFormat 1 752 480, type 1, port: 0
INFO : [NativeDewarp] setFormat 1 752 480, type 0, port: 0
INFO : [NativeDewarp] setFormat dewarp input: 752x480 YUV422I
INFO : [NativeDewarp] setFormat 1 752 480, type 1, port: 0
INFO : [NativeDewarp] setFormat dewarp output: 752x480 YUV422I
INFO : [V4l2Event] get json request: {"id":"s.fps","fps":30}
INFO : [NativeSensor] jsonRequest 0x1801a
INFO : [V4l2Event] send json response: {
"result" : 0
INFO : [MediaPipeline] MEDIA_EVENT_STREAM_START
INFO : [DewarpDriver] start 752 480 48 31, stride: 1504 1504
INFO : [DEWARP_HW] enter setParams
INFO : [NativeSensor] enter start
[CITF][INF]: RESULT camdev::CitfDevice::previewStart(Json::Value&, Json::Value&)
[CITF][INF]: int32_t camdev::Operation::previewStart() (enter)
[CITF][INF]: int32_t camdev::Operation::streamingStart(uint) (enter)
HAL-ALTERA: HalConnectIrq connect src: 0
HAL-ALTERA: HalConnectIrq connect src: 4
HAL-ALTERA: HalConnectIrq connect src: 1
HAL-ALTERA: HalConnectIrq connect src: 2
[CITF][INF]: CAM_ENGINE_CMD_START_STREAMING, ret = 0x0
[CITF][INF]: int32_t camdev::Operation::streamingStart(uint) (exit)
[CITF][INF]: int32_t camdev::Operation::previewStart() (exit)
[CITF][INF]: CitfInitOutChain!, chain ID:0, frame_skip:0
[CITF][INF]: camdev::Xom::Xom() (enter)
[CITF][INF]: camdev::Xom::Xom() (exit)
[CITF][INF]: camdev::Xom::Xom(ISPCORE_BUFIO_ID, uint32_t, uint32_t) (enter)
[CITF][INF]: camdev::Xom::Xom(ISPCORE_BUFIO_ID, uint32_t, uint32_t) (exit)
[CITF][INF]: RESULT camdev::Bitf::bitfSetOutputCtrl(ISPCORE_BUFIO_ID, camdev::Xom*)
[CITF][INF]: CitfStartOutChain!, chain ID:0
[CITF][INF]: CitfAttachChain!, chain ID:0
root@imx8mp:~/build-out/sdk# ./vvext 0 "CAPTURE" 0
INFO : [VVEXT:] Open Device: /dev/video0 (fd=3)
INFO : [VVEXT:] Driver: viv_v4l2_device
INFO : [VVEXT:] found viv video dev /dev/video0
"id" : "dwe.g.params",
"streamid" : 0
INFO : [NativeSensor] jsonRequest 0x81000
"dwe" :
"bypass" : true,
"hflip" : false,
"mat" :
0.0,
0.0,
0.0,
0.0,
0.0,
0.0,
0.0,
0.0,
0.0,
0.0,
0.0,
0.0,
0.0,
0.0,
0.0,
0.0,
0.0
"mode" : 0,
"vflip" : false
"result" : 0
INFO : [VVEXT:] get command CAPTURE 0
"id" : "capture",
"streamid" : 0
INFO : [NativeSensor] jsonRequest 0x80002
ERROR : [NativeSensor] CaptureImage dump buf failed 1
"CaptureImage" : "Image_752_480_YUV422I_20220428175226.yuv",
"result" : -1
Capture Image_752_480_YUV422I_20220428175226.yuv failed
Feels like ISP does not have any issue but when capturing the image. wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
%3CLINGO-SUB%20id%3D%22lingo-sub-2153886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EISP%20-%20%26lt%3Bv4l2src0%3Apool0%3Asrc%26gt%3B%20%E3%81%AFCAN%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%80%E5%A4%A7%E5%80%A4%E3%82%92%E6%9C%80%E5%B0%8F%E5%80%A4%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%E5%B0%82%E9%96%80%E5%AE%B6%E3%81%AE%E7%9A%86%E6%A7%98%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8%E3%80%81NXP%20IMX8MPLUS%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81MT9V024%20%E3%82%AB%E3%83%A1%E3%83%A9%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%20ISP%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E7%A7%81%E3%81%AE%E7%8F%BE%E5%9C%A8%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3EIMAGE_INSTALL%3Aappend%20%3D%20%22%20kernel-module-isp-vvcam%20gstreamer1.0%20gstreamer1.0-plugins-base%20%E3%82%92%E5%90%AB%E3%82%80%20Yocto%20%E3%82%B3%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8gstreamer1.0-%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3-%E8%89%AF%E3%81%84gstreamer1.0-%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3-%E4%B8%8D%E8%89%AFv4l-utils%20isp-imx%20libtinyxml2%20%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9-ctl%20fmt%20%22%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3ELinux%205.15.71%20%E3%82%AB%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%88%E3%83%BC%E3%83%B3%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%98%E3%83%83%E3%83%89%E3%83%AC%E3%82%B9%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E5%A4%96%E9%83%A8%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81V4L2%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3Eisp-imx-4.2.2.20.0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3Eisp-vvcam%20(lf-5.15.y_2.2.0)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E7%A7%81%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AF%E3%80%81DPHY0%E3%81%AB30%20fps%E3%80%81%E5%B9%85%3D752%E3%80%81%E9%AB%98%E3%81%95%3D480%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81Gstreamer%E3%81%8B%E3%82%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%89%B9%E3%81%AB%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E5%87%BA%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E4%B8%80%E7%95%AA%E8%BF%91%E3%81%84%E3%81%AE%E3%81%AF%E3%80%8C%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Apool0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%80%E5%A4%A7%E5%80%A4%E3%82%92%E6%9C%80%E5%B0%8F%E5%80%A4%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E6%83%85%E5%A0%B1%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E3%81%93%E3%81%93%E3%81%AB%E4%BE%8B%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eroot%40imx8mp%3A~%2Fbuild-out%2Fsdk%23%20gst-launch-1.0-v%20v4l2src%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3D%2Fdev%2Fvideo0%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E6%95%B0%3D5%20!%E3%80%8Cvideo%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3DYUY2%E3%80%81%E5%B9%85%3D752%E3%80%81%E9%AB%98%E3%81%95%3D480%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D30%2F1%E3%80%8D!fakesink%20%E3%83%80%E3%83%B3%E3%83%97%3Dtrue%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.000184125%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_INIT%20gst.c%3A592%3Ainit_pre%3AGStreamer%20%E3%82%B3%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.20.3%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.000278625%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_INIT%20gst.c%3A593%3Ainit_pre%3A%2Fusr%2Flib%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.000314500%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_INIT%20gst.c%3A611%3Ainit_pre%3ALinux%20imx8mp%205.15.71%2Bgea9b003902ee%20%231%20SMP%20PREEMPT%20%E7%81%AB%209%E6%9C%8812%E6%97%A5%2014%3A15%3A41%20UTC%202023%20aarch64%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.000854500%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_INIT%20gstmessage.c%3A129%3A_priv_gst_message_initialize%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.002470000%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_INIT%20gstcontext.c%3A86%3A_priv_gst_context_initialize%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.003066500%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_PLUGIN_LOADING%20gstplugin.c%3A324%3A_priv_gst_plugin_initialize%3A0%E5%80%8B%E3%81%AE%E9%9D%99%E7%9A%84%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.003352750%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_PLUGIN_LOADING%20gstplugin.c%3A232%3Agst_plugin_register_static%3A%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E9%9D%99%E7%9A%84%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%80%8Cstaticelements%E3%80%8D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.003399125%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_PLUGIN_LOADING%20gstplugin.c%3A234%3Agst_plugin_register_static%3A%E9%9D%99%E7%9A%84%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%80%8Cstaticelements%E3%80%8D%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B5%90%E6%9E%9C%3A%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.003510875%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_REGISTRY%20gstregistry.c%3A1827%3Aensure_current_registry%3A%E3%83%AC%E3%82%B8%E3%82%B9%E3%83%88%E3%83%AA%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E4%B8%AD%3A%20%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Froot%2F.cache%2Fgstreamer-1.0%2Fregistry.aarch64.bin%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.028175500%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_REGISTRY%20gstregistrybinary.c%3A683%3Apriv_gst_registry_binary_read_cache%3A%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Froot%2F.cache%2Fgstreamer-1.0%2Fregistry.aarch64.bin%20%E3%82%92%200.024588%20%E7%A7%92%E3%81%A7%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.028346375%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_REGISTRY%20gstregistry.c%3A1693%3Ascan_and_update_registry%3A%E3%83%AC%E3%82%B8%E3%82%B9%E3%83%88%E3%83%AA%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Froot%2F.cache%2Fgstreamer-1.0%2Fregistry.aarch64.bin%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.036117875%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_REGISTRY%20gstregistry.c%3A1785%3Ascan_and_update_registry%3A%E3%83%AC%E3%82%B8%E3%82%B9%E3%83%88%E3%83%AA%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.036177625%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_REGISTRY%20gstregistry.c%3A1862%3Aensure_current_registry%3A%E3%83%AC%E3%82%B8%E3%82%B9%E3%83%88%E3%83%AA%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A8%E6%9B%B4%E6%96%B0%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B5%90%E6%9E%9C%20%3D%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.036202250%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_INIT%20gst.c%3A833%3Ainit_post%3AGLib%20%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%202.72.3%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.036224750%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_INIT%20gst.c%3A835%3Ainit_post%3AGLib%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%202.72.3%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.036241250%202271%200x5599042800%20INFO%20GST_INIT%20gst.c%3A837%3Ainit_post%3A%20GStreamer%20%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.036313000%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_PIPELINE%20gstparse.c%3A344%3Agst_parse_launch_full%3A%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E8%AA%AC%E6%98%8E%E3%82%92%E8%A7%A3%E6%9E%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20'v4l2src%20device%3D%2Fdev%2Fvideo0%20num-buffers%3D5%20!%E3%83%93%E3%83%87%E3%82%AA%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3DYUY2%E3%80%81%E5%B9%85%3D752%E3%80%81%E9%AB%98%E3%81%95%3D480%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D30%2F1%20!fakesink%20%E3%83%80%E3%83%B3%E3%83%97%3Dtrue%20'%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.119030500%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_PLUGIN_LOADING%20gstplugin.c%3A987%3A_priv_gst_plugin_load_file_for_registry%3A%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20%22%2Fusr%2Flib%2Fgstreamer-1.0%2Flibgstvideo4linux2.so%22%E3%83%AD%E3%83%BC%E3%83%89%E6%B8%88%E3%81%BF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.119095500%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_ELEMENT_FACTORY%20gstelementfactory.c%3A489%3Agst_element_factory_create_with_properties%3A%E8%A6%81%E7%B4%A0%E3%80%8Cv4l2src%E3%80%8D%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.125341875%202271%200x5599042800%20INFO%20GST_ELEMENT_PADS%20gstelement.c%3A759%3Agst_element_add_pad%3A%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3EGstBaseSrc%400x55991ea130%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%20%E3%83%91%E3%83%83%E3%83%89%20'src'%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.127313750%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_PLUGIN_LOADING%20gstplugin.c%3A987%3A_priv_gst_plugin_load_file_for_registry%3A%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20%22%2Fusr%2Flib%2Fgstreamer-1.0%2Flibgstcoreelements.so%22%E3%83%AD%E3%83%BC%E3%83%89%E6%B8%88%E3%81%BF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.127381000%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_ELEMENT_FACTORY%20gstelementfactory.c%3A489%3Agst_element_factory_create_with_properties%3A%E8%A6%81%E7%B4%A0%E3%80%8Cfakesink%E3%80%8D%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.127746375%202271%200x5599042800%20INFO%20GST_ELEMENT_PADS%20gstelement.c%3A759%3Agst_element_add_pad%3A%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3EGstBaseSink%400x55991e0610%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%20%E3%83%91%E3%83%83%E3%83%89%E3%80%8Csink%E3%80%8D%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.127839250%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_ELEMENT_FACTORY%20gstelementfactory.c%3A489%3Agst_element_factory_create_with_properties%3A%E8%A6%81%E7%B4%A0%E3%80%8C%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%80%8D%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128087000%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_PIPELINE%20gst%2Fparse%2Fgrammar.y%3A683%3Agst_parse_perform_link%3AGstV4l2Src%20%E3%81%AE%20v4l2src0%20%E3%81%A8%E3%81%84%E3%81%86%E3%83%91%E3%83%83%E3%83%89%E3%82%92%E3%80%81GstFakeSink%20%E3%81%AE%20fakesink0%20(0%2F0)%20%E3%81%A8%E3%81%84%E3%81%86%E3%83%91%E3%83%83%E3%83%89%E3%81%AB%E5%A4%A7%E6%96%87%E5%AD%97%E3%81%A7%20%22video%2Fx-raw%E3%80%81format%3D(string)YUY2%E3%80%81width%3D(int)752%E3%80%81height%3D(int)480%E3%80%81framerate%3D(fraction)30%2F1%22%20%E3%81%A8%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128130875%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_ELEMENT_FACTORY%20gstelementfactory.c%3A489%3Agst_element_factory_create_with_properties%3A%E8%A6%81%E7%B4%A0%E3%80%8Ccapsfilter%E3%80%8D%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128345250%202271%200x5599042800%20INFO%20GST_ELEMENT_PADS%20gstelement.c%3A759%3Agst_element_add_pad%3A%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3EGstBaseTransform%400x55991f20e0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%20%E3%83%91%E3%83%83%E3%83%89%E3%80%8C%E3%82%B7%E3%83%B3%E3%82%AF%E3%80%8D%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128396375%202271%200x5599042800%20INFO%20GST_ELEMENT_PADS%20gstelement.c%3A759%3Agst_element_add_pad%3A%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3EGstBaseTransform%400x55991f20e0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%20%E3%83%91%E3%83%83%E3%83%89%20'src'%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128437250%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2069%3Agst_bin_get_state_func%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%E3%82%92%E5%8F%96%E5%BE%97%E4%B8%AD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128494250%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2806%3Agst_element_continue_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ecapsfilter0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%E5%A4%89%E6%9B%B4%E3%81%8CNULL%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128527625%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_EVENT%20gstevent.c%3A1660%3Agst_event_new_reconfigure%3A%E5%86%8D%E6%A7%8B%E6%88%90%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128564625%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_ELEMENT_PADS%20gstutils.c%3A1816%3Agst_element_link_pads_full%3A%E8%A6%81%E7%B4%A0%20v4l2src0%3A(any)%20%E3%82%92%E8%A6%81%E7%B4%A0%20capsfilter0%3Asink%20%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128592375%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_ELEMENT_PADS%20gstelement.c%3A1016%3Agst_element_get_static_pad%3A%E3%83%91%E3%83%83%E3%83%89%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC0%3A%E3%82%B7%E3%83%B3%E3%82%AF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128618625%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_PADS%20gstutils.c%3A1632%3Aprepare_link_maybe_ghosting%3Av4l2src0%20%E3%81%A8%20capsfilter0%20%E3%81%8C%E5%90%8C%E3%81%98%E3%83%93%E3%83%B3%E3%81%AB%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%B4%E3%83%BC%E3%82%B9%E3%83%88%E3%83%91%E3%83%83%E3%83%89%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128662250%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_PADS%20gstpad.c%3A2382%3Agst_pad_link_prepare%3Av4l2src0%3Asrc%20%E3%81%A8%20capsfilter0%3Asink%20%E3%82%92%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128706250%202271%200x5599042800%20INFO%20GST_PADS%20gstpad.c%3A4357%3Agst_pad_peer_query%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ecapsfilter0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%83%91%E3%83%83%E3%83%89%E3%81%AB%E3%83%94%E3%82%A2%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128765750%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_PADS%20gstpad.c%3A2590%3Agst_pad_link_full%3Av4l2src0%3Asrc%20%E3%81%A8%20capsfilter0%3Asink%20%E3%82%92%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128787375%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_EVENT%20gstevent.c%3A1660%3Agst_event_new_reconfigure%3A%E5%86%8D%E6%A7%8B%E6%88%90%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128810125%202271%200x5599042800%20INFO%20GST_EVENT%20gstpad.c%3A5946%3Agst_pad_send_event_unchecked%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%83%91%E3%83%83%E3%83%89%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A0%B4%E6%A3%84%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128849500%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_ELEMENT_PADS%20gstutils.c%3A1816%3Agst_element_link_pads_full%3A%E8%A6%81%E7%B4%A0%20capsfilter0%3Asrc%20%E3%82%92%E8%A6%81%E7%B4%A0%20fakesink0%3A(any)%20%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128876375%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_ELEMENT_PADS%20gstelement.c%3A1016%3Agst_element_get_static_pad%3A%E3%83%91%E3%83%83%E3%83%89%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC0%3Asrc%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128907875%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_PADS%20gstutils.c%3A1079%3Agst_pad_check_link%3Acapsfilter0%3Asrc%20%E3%81%A8%20fakesink0%3Asink%20%E3%82%92%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.128978125%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_PADS%20gstutils.c%3A1632%3Aprepare_link_maybe_ghosting%3Acapsfilter0%E3%81%A8fakesink0%E3%81%8C%E5%90%8C%E3%81%98%E3%83%93%E3%83%B3%E3%81%AB%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%82%B4%E3%83%BC%E3%82%B9%E3%83%88%E3%83%91%E3%83%83%E3%83%89%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.129011625%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_PADS%20gstpad.c%3A2382%3Agst_pad_link_prepare%3Acapsfilter0%3Asrc%20%E3%81%A8%20fakesink0%3Asink%20%E3%82%92%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.129071250%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_PADS%20gstpad.c%3A2590%3Agst_pad_link_full%3Acapsfilter0%3Asrc%20%E3%81%A8%20fakesink0%3Asink%20%E3%82%92%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.129091000%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_EVENT%20gstevent.c%3A1660%3Agst_event_new_reconfigure%3A%E5%86%8D%E6%A7%8B%E6%88%90%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.129110625%202271%200x5599042800%20INFO%20GST_EVENT%20gstpad.c%3A5946%3Agst_pad_send_event_unchecked%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ecapsfilter0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%83%91%E3%83%83%E3%83%89%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A0%B4%E6%A3%84%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.130531250%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2479%3Agst_bin_element_set_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Efakesink0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8NULL%E4%BF%9D%E7%95%99%E4%B8%ADVOID_PENDING%E3%80%81%E6%AC%A1%E5%B8%8C%E6%9C%9BREADY%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.130569250%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2806%3Agst_element_continue_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Efakesink0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%E3%81%8CREADY%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.130595000%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2706%3A_priv_gst_element_state_changed%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Efakesink0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%E3%81%8C%20NULL%20%E3%81%8B%E3%82%89%20READY%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E9%80%9A%E7%9F%A5%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(VOID_PENDING%20%E4%BF%9D%E7%95%99%E4%B8%AD)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.130650625%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2928%3Agst_bin_change_state_func%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%20'fakesink0'%20%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%8C%202(READY)%20%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.130682375%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2479%3Agst_bin_element_set_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ecapsfilter0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8NULL%E4%BF%9D%E7%95%99%E4%B8%ADVOID_PENDING%E3%80%81%E6%AC%A1%E5%B8%8C%E6%9C%9BREADY%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.130707125%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2806%3Agst_element_continue_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ecapsfilter0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EREADY%E3%81%B8%E3%81%AE%E7%8A%B6%E6%85%8B%E5%A4%89%E6%9B%B4%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.130731875%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2706%3A_priv_gst_element_state_changed%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ecapsfilter0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%E5%A4%89%E6%9B%B4%20NULL%20%E3%81%8B%E3%82%89%20READY%20(VOID_PENDING%20%E4%BF%9D%E7%95%99%E4%B8%AD)%20%E3%82%92%E9%80%9A%E7%9F%A5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.130764125%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2928%3Agst_bin_change_state_func%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%20'capsfilter0'%20%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%8C%202(READY)%20%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.130796000%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2479%3Agst_bin_element_set_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8NULL%E4%BF%9D%E7%95%99%E4%B8%ADVOID_PENDING%E3%80%81%E6%AC%A1%E5%B8%8C%E6%9C%9BREADY%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131003250%202271%200x5599042800%20INFO%20v4l2%20v4l2_calls.c%3A588%3Agst_v4l2_open%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20'VIV'%20(%2Fdev%2Fvideo0)%20%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131045250%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2806%3Agst_element_continue_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EREADY%E3%81%B8%E3%81%AE%E7%8A%B6%E6%85%8B%E5%A4%89%E6%9B%B4%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131071625%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2706%3A_priv_gst_element_state_changed%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%E5%A4%89%E6%9B%B4%20NULL%20%E3%81%8B%E3%82%89%20READY%20(VOID_PENDING%20%E4%BF%9D%E7%95%99%E4%B8%AD)%20%E3%82%92%E9%80%9A%E7%9F%A5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131107625%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2928%3Agst_bin_change_state_func%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%20'v4l2src0'%20%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%8C%202(READY)%20%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131145375%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2778%3Agst_element_continue_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%E3%82%92%20NULL%20%E3%81%8B%E3%82%89%20READY%20%E3%81%AB%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E4%B8%AD%E3%80%81PAUSED%20%E4%BF%9D%E7%95%99%E4%B8%AD%E3%80%81%E6%AC%A1%20PAUSED%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131173500%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2706%3A_priv_gst_element_state_changed%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%E5%A4%89%E6%9B%B4%20NULL%20%E3%81%8B%E3%82%89%20READY%20(PAUSED%20%E4%BF%9D%E7%95%99%E4%B8%AD)%20%E3%81%B8%E3%81%AE%E9%80%9A%E7%9F%A5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131253250%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2786%3Agst_element_continue_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%B6%99%E7%B6%9A%E7%8A%B6%E6%85%8B%E3%81%8CREADY%E3%81%8B%E3%82%89PAUSED%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%80%81%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%ABPAUSED%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131305125%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2479%3Agst_bin_element_set_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Efakesink0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8READY%E3%80%81%E4%BF%9D%E7%95%99%E4%B8%ADVOID_PENDING%E3%80%81%E6%AC%A1PAUSED%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131356500%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2935%3Agst_bin_change_state_func%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%20'fakesink0'%20%E3%81%8C%E9%9D%9E%E5%90%8C%E6%9C%9F%E7%9A%84%E3%81%AB%20PAUSED%20%E3%81%AB%E7%8A%B6%E6%85%8B%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131389875%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2479%3Agst_bin_element_set_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ecapsfilter0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8READY%E3%80%81%E4%BF%9D%E7%95%99%E4%B8%ADVOID_PENDING%E3%80%81%E6%AC%A1PAUSED%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131430000%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2806%3Agst_element_continue_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ecapsfilter0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%E3%81%8C%20PAUSED%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131456875%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2706%3A_priv_gst_element_state_changed%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ecapsfilter0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EREADY%20%E3%81%8B%E3%82%89%20PAUSED%20%E3%81%B8%E3%81%AE%E7%8A%B6%E6%85%8B%E5%A4%89%E6%9B%B4%20(VOID_PENDING%20%E4%BF%9D%E7%95%99%E4%B8%AD)%20%E3%82%92%E9%80%9A%E7%9F%A5%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131492250%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2928%3Agst_bin_change_state_func%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%20'capsfilter0'%20%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%8C%203(PAUSED)%20%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131522125%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2479%3Agst_bin_element_set_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8%E3%81%AFREADY%E3%80%81VOID_PENDING%E3%81%8C%E4%BF%9D%E7%95%99%E4%B8%AD%E3%80%81%E6%AC%A1%E3%81%AFPAUSED%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131581625%202271%200x5599042800%20INFO%20basesrc%20gstbasesrc.c%3A1430%3Agst_base_src_do_seek%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B7%E3%83%BC%E3%82%AF%3A%20%E6%99%82%E9%96%93%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E9%96%8B%E5%A7%8B%3D0%3A00%3A00.000000000%E3%80%81%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3D0%3A00%3A00.000000000%E3%80%81%E5%81%9C%E6%AD%A2%3D99%3A99%3A99.999999999%E3%80%81%E3%83%AC%E3%83%BC%E3%83%88%3D1.000000%E3%80%81%E9%81%A9%E7%94%A8%E3%83%AC%E3%83%BC%E3%83%88%3D1.000000%E3%80%81%E3%83%95%E3%83%A9%E3%82%B0%3D0x00%E3%80%81%E6%99%82%E9%96%93%3D0%3A00%3A00.000000000%E3%80%81%E3%83%99%E3%83%BC%E3%82%B9%3D0%3A00%3A00.000000000%E3%80%81%E4%BD%8D%E7%BD%AE%200%3A00%3A00.000000000%E3%80%81%E7%B6%99%E7%B6%9A%E6%99%82%E9%96%9399%3A99%3A99.999999999%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131684250%202271%200x5599042800%20%E6%83%85%E5%A0%B1%E3%82%BF%E3%82%B9%E3%82%AF%20gsttask.c%3A516%3Agst_task_set_lock%3A%E3%82%BF%E3%82%B9%E3%82%AF%200x55991f4050%20%E3%81%AB%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%20%E3%83%AD%E3%83%83%E3%82%AF%200x55991ec260%20%E3%82%92%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131710000%202271%200x5599042800%20INFO%20GST_PADS%20gstpad.c%3A6291%3Agst_pad_start_task%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%82%BF%E3%82%B9%E3%82%AF%200x55991f4050%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131884375%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2806%3Agst_element_continue_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%E3%81%8CPAUSED%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131916375%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2706%3A_priv_gst_element_state_changed%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EREADY%20%E3%81%8B%E3%82%89%20PAUSED%20%E3%81%B8%E3%81%AE%E7%8A%B6%E6%85%8B%E5%A4%89%E6%9B%B4%20(VOID_PENDING%20%E4%BF%9D%E7%95%99%E4%B8%AD)%20%E3%82%92%E9%80%9A%E7%9F%A5%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131957500%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2971%3Agst_bin_change_state_func%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%20'v4l2src0'%20%E3%81%8C%E3%83%97%E3%83%AA%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%AA%E3%81%97%E3%81%A7%E7%8A%B6%E6%85%8B%E3%82%92%203(PAUSED)%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131983625%202271%200x55991b3460%20%E6%83%85%E5%A0%B1%20GST_ELEMENT_PADS%20gstelement.c%3A1013%3Agst_element_get_static_pad%3A%E8%A6%81%E7%B4%A0%20%22v4l2src0%22%20%E3%81%AB%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%91%E3%83%83%E3%83%89%20'sink'%20%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.131995000%202271%200x5599042800%20INFO%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%20gstpipeline.c%3A533%3Agst_pipeline_change_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%83%A9%E3%82%A4%E3%83%96%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.132039500%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2806%3Agst_element_continue_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%E3%81%8C%20PAUSED%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.132067875%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2706%3A_priv_gst_element_state_changed%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%E3%81%8CREADY%E3%81%8B%E3%82%89PAUSED%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E9%80%9A%E7%9F%A5%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(VOID_PENDING%E3%81%AF%E4%BF%9D%E7%95%99%E4%B8%AD)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.132120625%202271%200x55991b3460%20INFO%20v4l2src%20gstv4l2src.c%3A550%3Agst_v4l2src_query_preferred_size%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%E5%85%A5%E5%8A%9B0%E3%82%92%3CSPAN%3E%E3%80%8C%E3%82%AB%E3%83%A1%E3%83%A9%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%81%A8%E3%81%97%E3%81%A6%E6%A4%9C%E5%87%BA%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%83%A9%E3%82%A4%E3%83%96%E3%81%AA%E3%81%AE%E3%81%A7%20PREROLL%20%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93...%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.132187750%202271%200x55991b3460%20INFO%20v4l2%20gstv4l2object.c%3A1241%3Agst_v4l2_object_fill_format_list%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AF%204%20%E3%81%A4%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.132220375%202271%200x55991b3460%20%E6%83%85%E5%A0%B1%20v4l2%20gstv4l2object.c%3A1245%3Agst_v4l2_object_fill_format_list%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EYUYV%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.132250750%202271%200x55991b3460%20%E6%83%85%E5%A0%B1%20v4l2%20gstv4l2object.c%3A1245%3Agst_v4l2_object_fill_format_list%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ENV12%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.132277000%202271%200x55991b3460%20%E6%83%85%E5%A0%B1%20v4l2%20gstv4l2object.c%3A1245%3Agst_v4l2_object_fill_format_list%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ENV16%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.132330375%202271%200x55991b3460%20%E6%83%85%E5%A0%B1%20v4l2%20gstv4l2object.c%3A1245%3Agst_v4l2_object_fill_format_list%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EBA10%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPipeline%20is%20PREROLLED%20...%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ESetting%20pipeline%20to%20PLAYING%20...%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.133349250%202271%200x5599042800%20%E6%83%85%E5%A0%B1%20GST_EVENT%20gstevent.c%3A1530%3Agst_event_new_latency%3A%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%200%3A00%3A00.000000000%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.133414375%202271%200x5599042800%20INFO%20bin%20gstbin.c%3A2759%3Agst_bin_do_latency_func%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%AF%200%3A00%3A00.000000000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.133470250%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2479%3Agst_bin_element_set_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Efakesink0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8READY%20%E4%BF%9D%E7%95%99PAUSED%E3%80%81%E6%AC%A1PLAYING%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.133500625%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2935%3Agst_bin_change_state_func%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%20'fakesink0'%20%E3%81%8C%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%81%AB%E7%8A%B6%E6%85%8B%E3%82%92%20PLAYING%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.133534000%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2479%3Agst_bin_element_set_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ecapsfilter0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E4%B8%AD%E3%80%81%E4%BF%9D%E7%95%99%E4%B8%AD%E3%81%AFVOID_PENDING%E3%80%81%E6%AC%A1%E3%81%AFPLAYING%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.133564625%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2806%3Agst_element_continue_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ecapsfilter0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EPLAYING%E3%81%B8%E3%81%AE%E7%8A%B6%E6%85%8B%E5%A4%89%E6%9B%B4%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.133592125%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2706%3A_priv_gst_element_state_changed%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ecapsfilter0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%E3%81%8CPAUSED%E3%81%8B%E3%82%89PLAYING%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E9%80%9A%E7%9F%A5%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88VOID_PENDING%E3%81%AF%E4%BF%9D%E7%95%99%E4%B8%AD%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.133632125%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2928%3Agst_bin_change_state_func%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%20'capsfilter0'%20%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%8C%204(PLAYING)%20%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.133668750%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2806%3Agst_element_continue_state%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EPLAYING%E3%81%B8%E3%81%AE%E7%8A%B6%E6%85%8B%E5%A4%89%E6%9B%B4%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.133696625%202271%200x5599042800%20INFO%20GST_STATES%20gstelement.c%3A2706%3A_priv_gst_element_state_changed%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%E3%81%8C%20PAUSED%20%E3%81%8B%E3%82%89%20PLAYING%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E9%80%9A%E7%9F%A5%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(VOID_PENDING%20%E3%81%AF%E4%BF%9D%E7%95%99%E4%B8%AD)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.133766250%202271%200x5599042800%20INFO%20GST_STATES%20gstbin.c%3A2928%3Agst_bin_change_state_func%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Epipeline0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%20'v4l2src0'%20%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%8C%204(PLAYING)%20%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%96%B0%E3%81%97%E3%81%84%E6%99%82%E8%A8%88%3A%20GstSystemClock%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.278604625%202271%200x55991b3460%20INFO%20v4l2%20gstv4l2object.c%3A4752%3Agst_v4l2_object_probe_caps%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3A%20video%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3D(%E6%96%87%E5%AD%97%E5%88%97)YUY2%E3%80%81%E5%B9%85%3D(int)%5B%20176%2C%204096%2C%2016%20%5D%E3%80%81%E9%AB%98%E3%81%95%3D(int)%5B%20144%2C%203072%2C%208%20%5D%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%3D(%E5%88%86%E6%95%B0)1%2F1%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D(%E5%88%86%E6%95%B0)%7B%2030%2F1%2C%2029%2F1%2C%2028%2F1%2C%2027%2F1%2C%2026%2F1%2C%2025%2F1%2C%2024%2F1%2C%2023%2F1%2C%2022%2F1%2C%2021%2F1%2C%2020%2F1%2C%2019%2F1%E3%80%8118%2F1%E3%80%8117%2F1%E3%80%8116%2F1%E3%80%8115%2F1%E3%80%8114%2F1%E3%80%8113%2F1%E3%80%8112%2F1%E3%80%8111%2F1%E3%80%8110%2F1%E3%80%819%2F1%E3%80%818%2F1%E3%80%817%2F1%E3%80%816%2F1%E3%80%815%2F1%E3%80%814%2F1%E3%80%813%2F1%E3%80%812%2F1%E3%80%811%2F1%20%7D%3B%20video%2Fx-raw(%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9)%2C%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3D(%E6%96%87%E5%AD%97%E5%88%97)YUY2%2C%20%E5%B9%85%3D(%E6%95%B4%E6%95%B0)%5B%20176%2C%204096%2C%2016%20%5D%2C%20%E9%AB%98%E3%81%95%3D(%E6%95%B4%E6%95%B0)%5B%20144%2C%203072%2C%208%20%5D%2C%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%3D(%E5%88%86%E6%95%B0)1%2F1%2C%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D(%E5%88%86%E6%95%B0)%7B%2030%2F1%2C%2029%2F1%2C%2028%2F1%2C%2027%2F1%2C%2026%2F1%2C%2025%2F1%2C%2024%2F1%2C%2023%2F1%2C%2022%2F1%2C%2021%2F1%2C%2020%2F1%2C%2019%2F1%2C%2018%2F1%2C%2017%2F1%2C%2016%2F1%2C%2015%2F1%2C%2014%2F1%2C%2013%2F1%2C%2012%2F1%2C%2011%2F1%2C%2010%2F1%2C%209%2F1%2C%208%2F1%2C%207%2F1%2C%206%2F1%2C%205%2F1%2C%204%2F1%E3%80%813%2F1%E3%80%812%2F1%E3%80%811%2F1%20%7D%E3%80%81interlace-mode%3D(%E6%96%87%E5%AD%97%E5%88%97)alternate%3B%20video%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3D(%E6%96%87%E5%AD%97%E5%88%97)NV12%E3%80%81%E5%B9%85%3D(%E6%95%B4%E6%95%B0)%5B%20176%2C%204096%2C%2016%20%5D%E3%80%81%E9%AB%98%E3%81%95%3D(%E6%95%B4%E6%95%B0)%5B%20144%2C%203072%2C%208%20%5D%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%3D(%E5%88%86%E6%95%B0)1%2F1%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D(%E5%88%86%E6%95%B0)%7B%2030%2F1%2C%2029%2F1%2C%2028%2F1%2C%2027%2F1%2C%2026%2F1%2C%2025%2F1%2C%2024%2F1%2C%2023%2F1%2C%2022%2F1%2C%2021%2F1%2C%2020%2F1%2C%2019%2F1%2C%2018%2F1%2C%2017%2F1%2C%2016%2F1%2C%2015%2F1%2C%2014%2F1%2C%2013%2F1%2C%2012%2F1%2C%2011%2F1%2C%2010%2F1%2C%209%2F1%2C%208%2F1%2C%207%2F1%2C%206%2F1%2C%205%2F1%2C%204%2F1%2C%203%2F1%E3%80%812%2F1%E3%80%811%2F1%20%7D%3B%20video%2Fx-raw(%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9)%2C%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3D(%E6%96%87%E5%AD%97%E5%88%97)NV12%2C%20%E5%B9%85%3D(%E6%95%B4%E6%95%B0)%5B%20176%2C%204096%2C%2016%20%5D%2C%20%E9%AB%98%E3%81%95%3D(%E6%95%B4%E6%95%B0)%5B%20144%2C%203072%2C%208%20%5D%2C%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%3D(%E5%88%86%E6%95%B0)1%2F1%2C%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D(%E5%88%86%E6%95%B0)%7B%2030%2F1%2C%2029%2F1%2C%2028%2F1%2C%2027%2F1%2C%2026%2F1%2C%2025%2F1%2C%2024%2F1%2C%2023%2F1%2C%2022%2F1%2C%2021%2F1%2C%2020%2F1%2C%2019%2F1%2C%2018%2F1%2C%2017%2F1%2C%2016%2F1%2C%2015%2F1%2C%2014%2F1%2C%2013%2F1%2C%2012%2F1%2C%2011%2F1%2C%2010%2F1%2C%209%2F1%2C%208%2F1%2C%207%2F1%2C%206%2F1%2C%205%2F1%2C%204%2F1%E3%80%813%2F1%E3%80%812%2F1%E3%80%811%2F1%20%7D%E3%80%81interlace-mode%3D(%E6%96%87%E5%AD%97%E5%88%97)alternate%3B%20video%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3D(%E6%96%87%E5%AD%97%E5%88%97)NV16%E3%80%81%E5%B9%85%3D(%E6%95%B4%E6%95%B0)%5B%20176%2C%204096%2C%2016%20%5D%E3%80%81%E9%AB%98%E3%81%95%3D(%E6%95%B4%E6%95%B0)%5B%20144%2C%203072%2C%208%20%5D%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%3D(%E5%88%86%E6%95%B0)1%2F1%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D(%E5%88%86%E6%95%B0)%7B%2030%2F1%2C%2029%2F1%2C%2028%2F1%2C%2027%2F1%2C%2026%2F1%2C%2025%2F1%2C%2024%2F1%2C%2023%2F1%2C%2022%2F1%2C%2021%2F1%2C%2020%2F1%2C%2019%2F1%2C%2018%2F1%2C%2017%2F1%2C%2016%2F1%2C%2015%2F1%2C%2014%2F1%2C%2013%2F1%2C%2012%2F1%2C%2011%2F1%2C%2010%2F1%2C%209%2F1%2C%208%2F1%2C%207%2F1%2C%206%2F1%2C%205%2F1%2C%204%2F1%2C%203%2F1%E3%80%812%2F1%E3%80%811%2F1%20%7D%3B%20video%2Fx-raw(format%3AInterlaced)%2C%20format%3D(string)NV16%2C%20width%3D(int)%5B%20176%2C%204096%2C%2016%20%5D%2C%20height%3D(int)%5B%20144%2C%203072%2C%208%20%5D%2C%20pixel-aspect-ratio%3D(fraction)1%2F1%2C%20framerate%3D(fraction)%7B%2030%2F1%2C%2029%2F1%2C%2028%2F1%2C%2027%2F1%2C%2026%2F1%2C%2025%2F1%2C%2024%2F1%2C%2023%2F1%2C%2022%2F1%2C%2021%2F1%2C%2020%2F1%2C%2019%2F1%2C%2018%2F1%2C%2017%2F1%2C%2016%2F1%2C%2015%2F1%2C%2014%2F1%2C%2013%2F1%2C%2012%2F1%2C%2011%2F1%2C%2010%2F1%2C%209%2F1%2C%208%2F1%2C%207%2F1%2C%206%2F1%2C%205%2F1%2C%204%2F1%E3%80%813%2F1%E3%80%812%2F1%E3%80%811%2F1%20%7D%E3%80%81interlace-mode%3D(%E6%96%87%E5%AD%97%E5%88%97)alternate%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.290160875%202271%200x55991b3460%20INFO%20v4l2src%20gstv4l2src.c%3A647%3Agst_v4l2src_negotiate%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AF%E3%80%81video%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3D(%E6%96%87%E5%AD%97%E5%88%97)YUY2%E3%80%81%E5%B9%85%3D(%E6%95%B4%E6%95%B0)752%E3%80%81%E9%AB%98%E3%81%95%3D(%E6%95%B4%E6%95%B0)480%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D(%E5%B0%8F%E6%95%B0)30%2F1%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%3D(%E5%B0%8F%E6%95%B0)1%2F1%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%3D(%E6%96%87%E5%AD%97%E5%88%97)%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%80%81%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%88%E3%83%AA%3D(%E6%96%87%E5%AD%97%E5%88%97)bt709%20%E3%81%AB%E5%9B%BA%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.290237750%202271%200x55991b3460%20%E6%83%85%E5%A0%B1%20GST_EVENT%20gstevent.c%3A892%3Agst_event_new_caps%3Acaps%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%20video%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20%3D%20(%E6%96%87%E5%AD%97%E5%88%97)%20YUY2%E3%80%81%E5%B9%85%20%3D%20(%E6%95%B4%E6%95%B0)%20752%E3%80%81%E9%AB%98%E3%81%95%20%3D%20(%E6%95%B4%E6%95%B0)%20480%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%20%3D%20(%E5%B0%8F%E6%95%B0)%2030%2F1%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%20%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%20%3D%20(%E5%B0%8F%E6%95%B0)%201%2F1%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20(%E6%96%87%E5%AD%97%E5%88%97)%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%80%81%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%88%E3%83%AA%20%3D%20(%E6%96%87%E5%AD%97%E5%88%97)%20bt709%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.290429750%202271%200x55991b3460%20INFO%20basetransform%20gstbasetransform.c%3A1325%3Agst_base_transform_setcaps%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ecapsfilter0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%E3%82%92%E5%86%8D%E5%88%A9%E7%94%A8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.290487375%202271%200x55991b3460%20%E6%83%85%E5%A0%B1%20GST_EVENT%20gstevent.c%3A892%3Agst_event_new_caps%3Acaps%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%20video%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20%3D%20(%E6%96%87%E5%AD%97%E5%88%97)%20YUY2%E3%80%81%E5%B9%85%20%3D%20(%E6%95%B4%E6%95%B0)%20752%E3%80%81%E9%AB%98%E3%81%95%20%3D%20(%E6%95%B4%E6%95%B0)%20480%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%20%3D%20(%E5%B0%8F%E6%95%B0)%2030%2F1%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%20%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%20%3D%20(%E5%B0%8F%E6%95%B0)%201%2F1%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20(%E6%96%87%E5%AD%97%E5%88%97)%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%80%81%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%88%E3%83%AA%20%3D%20(%E6%96%87%E5%AD%97%E5%88%97)%20bt709%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2FGstPipeline%3Apipeline0%2FGstV4l2Src%3Av4l2src0.GstPad%3Asrc%3A%20caps%20%3D%20video%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3D(%E6%96%87%E5%AD%97%E5%88%97)YUY2%E3%80%81%E5%B9%85%3D(%E6%95%B4%E6%95%B0)752%E3%80%81%E9%AB%98%E3%81%95%3D(%E6%95%B4%E6%95%B0)480%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D(%E5%B0%8F%E6%95%B0)30%2F1%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%3D(%E5%B0%8F%E6%95%B0)1%2F1%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%3D(%E6%96%87%E5%AD%97%E5%88%97)%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%80%81%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%88%E3%83%AA%3D(%E6%96%87%E5%AD%97%E5%88%97)bt709%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2FGstPipeline%3Apipeline0%2FGstCapsFilter%3Acapsfilter0.GstPad%3Asrc%3A%20caps%20%3D%20video%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3D(%E6%96%87%E5%AD%97%E5%88%97)YUY2%E3%80%81%E5%B9%85%3D(%E6%95%B4%E6%95%B0)752%E3%80%81%E9%AB%98%E3%81%95%3D(%E6%95%B4%E6%95%B0)480%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D(%E5%B0%8F%E6%95%B0)30%2F1%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%3D(%E5%B0%8F%E6%95%B0)1%2F1%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%3D(%E6%96%87%E5%AD%97%E5%88%97)%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%80%81%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%88%E3%83%AA%3D(%E6%96%87%E5%AD%97%E5%88%97)bt709%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2FGstPipeline%3Apipeline0%2FGstFakeSink%3Afakesink0.GstPad%3Asink%3A%20caps%20%3D%20video%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3D(%E6%96%87%E5%AD%97%E5%88%97)YUY2%E3%80%81%E5%B9%85%3D(%E6%95%B4%E6%95%B0)752%E3%80%81%E9%AB%98%E3%81%95%3D(%E6%95%B4%E6%95%B0)480%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D(%E5%B0%8F%E6%95%B0)30%2F1%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%3D(%E5%B0%8F%E6%95%B0)1%2F1%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%3D(%E6%96%87%E5%AD%97%E5%88%97)%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%80%81%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%88%E3%83%AA%3D(%E6%96%87%E5%AD%97%E5%88%97)bt709%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2FGstPipeline%3Apipeline0%2FGstCapsFilter%3Acapsfilter0.GstPad%3Asink%3A%20caps%20%3D%20video%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3D(%E6%96%87%E5%AD%97%E5%88%97)YUY2%E3%80%81%E5%B9%85%3D(%E6%95%B4%E6%95%B0)752%E3%80%81%E9%AB%98%E3%81%95%3D(%E6%95%B4%E6%95%B0)480%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D(%E5%B0%8F%E6%95%B0)30%2F1%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%3D(%E5%B0%8F%E6%95%B0)1%2F1%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%3D(%E6%96%87%E5%AD%97%E5%88%97)%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%80%81%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%88%E3%83%AA%3D(%E6%96%87%E5%AD%97%E5%88%97)bt709%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.406382625%202271%200x55991b3460%20INFO%20v4l2%20gstv4l2object.c%3A4083%3Agst_v4l2_object_set_format_full%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%E3%82%9230%2F1%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.406454875%202271%200x55991b3460%20INFO%20v4l2%20gstv4l2object.c%3A3251%3Agst_v4l2_object_setup_pool%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%83%A2%E3%83%BC%E3%83%894%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.407197375%202271%200x55991b3460%20INFO%20v4l2bufferpool%20gstv4l2bufferpool.c%3A604%3Agst_v4l2_buffer_pool_set_config%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Apool0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E6%9C%80%E5%B0%8F%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%922%E3%81%AB%E5%A2%97%E3%82%84%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.407344250%202271%200x55991b3460%20INFO%20v4l2bufferpool%20gstv4l2bufferpool.c%3A617%3Agst_v4l2_buffer_pool_set_config%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Apool0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E6%9C%80%E5%A4%A7%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%9232%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.407469375%202271%200x55991b3460%20INFO%20v4l2bufferpool%20gstv4l2bufferpool.c%3A628%3Agst_v4l2_buffer_pool_set_config%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Apool0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%80%E5%A4%A7%E5%80%A4%E3%82%92%E6%9C%80%E5%B0%8F%E5%80%A4%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.407735125%202271%200x55991b3460%20INFO%20v4l2bufferpool%20gstv4l2bufferpool.c%3A617%3Agst_v4l2_buffer_pool_set_config%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Apool0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E6%9C%80%E5%A4%A7%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%9232%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.407767625%202271%200x55991b3460%20INFO%20v4l2bufferpool%20gstv4l2bufferpool.c%3A628%3Agst_v4l2_buffer_pool_set_config%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Apool0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%80%E5%A4%A7%E5%80%A4%E3%82%92%E6%9C%80%E5%B0%8F%E5%80%A4%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0%3A00%3A00.420490625%202271%200x55991b3460%20WARN%20v4l2bufferpool%20gstv4l2bufferpool.c%3A884%3Agst_v4l2_buffer_pool_start%3A%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Ev4l2src0%3Apool0%3Asrc%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%8C%E4%B8%8D%E7%A2%BA%E5%AE%9F%E3%81%BE%E3%81%9F%E3%81%AF%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E-------------------------------%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Egst-launch-1.0%E3%82%82%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F-v%20v4l2src%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%3D%20%2Fdev%2Fvideo0%20!%E3%80%8Cvideo%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3DYUY2%E3%80%81%E5%B9%85%3D752%E3%80%81%E9%AB%98%E3%81%95%3D480%E3%80%8D!%E5%88%97%20%EF%BC%81%E3%83%93%E3%83%87%E3%82%AA%E5%A4%89%E6%8F%9B%EF%BC%81%E7%90%86%E8%AB%96%EF%BC%81oggmux%20!filesink%20location%3Dtest_image.ogv%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%90%8C%E6%A7%98%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3ECAN%E8%AA%B0%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%AE%E6%A0%B9%E6%9C%AC%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E------------------------------%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E7%A7%81%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26amp%3Bisp_0%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26amp%3Bisp_1%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E7%84%A1%E5%8A%B9%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26amp%3Bdewarp%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26amp%3Bcameradev%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26amp%3Bisi_0%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E7%84%A1%E5%8A%B9%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E7%84%A1%E5%8A%B9%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26amp%3Bisi_1%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E7%84%A1%E5%8A%B9%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E7%84%A1%E5%8A%B9%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26amp%3Bmipi_csi_0%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E3%83%9D%E3%83%BC%E3%83%88%400%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emipi_csi0_ep%3A%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%20%26lt%3B%26amp%3Bmt9v024_mipi_0_ep%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%B3%20%3D%20%26lt%3B4%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecsis-hs-settle%20%3D%20%26lt%3B16%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E-----%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edmesg%20%E3%83%AD%E3%82%B0%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%5B%201740.645667%5D%20viv_dwe_exit_module%20%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.645797%5D%20dwe_hw_remove%20%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.645893%5D%20fake_pdev_release%20%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.645898%5D%20vvcam%20%E3%83%87%E3%83%AF%E3%83%BC%E3%83%97%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.665504%5D%20viv_isp_exit_module%E3%81%AB%E5%85%A5%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.665647%5D%20isp_hw_remove%E3%82%92%E5%85%A5%E5%8A%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.665655%5D%20vvcam%20isp%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.701803%5D%20%3A%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%86%E3%82%A3%E3%83%86%E3%82%A3%E3%82%92%E7%99%BB%E9%8C%B2%E8%A7%A3%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.735600%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.735611%5D%20mt9v024_probe%E3%82%92%E5%85%A5%E5%8A%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.735621%5D%20xclk%E5%91%A8%E6%B3%A2%E6%95%B0%3A%2024000000%20Hz%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.735626%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%20mt9v024_read_reg16%3A%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3D0x0000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.749169%5DMT9V024%E3%80%81%E3%83%81%E3%83%83%E3%83%97%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E4%B8%80%E8%87%B4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.749178%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20%E5%89%8D%E5%BE%8C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.749196%5D%20mt9v024_probe%E3%82%AB%E3%83%A1%E3%83%A9mipi%20mt9v024%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.767059%5D%20viv_isp_init_module%E3%82%92%E5%85%A5%E5%8A%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.767405%5D%20isp_hw_probe%E3%82%92%E5%85%A5%E5%8A%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.767471%5D%20vvcam%20isp%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.778665%5D%20viv_dwe_init_module%20%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.778987%5D%20dwe_hw_probe%20%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.779312%5D%20vvcam%20%E3%83%87%E3%83%AF%E3%83%BC%E3%83%97%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E6%A4%9C%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.789973%5D%20viv_video_init_module%E3%81%AB%E5%85%A5%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.804690%5D%20imx8_media_dev%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%83%B3%E3%82%B0%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%8B%E3%82%89%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%93%81%E8%B3%AA%E3%81%AF%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%AD%A6%E5%91%8A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.805623%5D%20mx8-img-md%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A%20mt9v024%202-0048%20(1)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.805644%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20link_setup%20%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.805647%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20%E3%82%A8%E3%83%B3%E3%83%86%E3%82%A3%E3%83%86%E3%82%A3%E5%90%8D%3A%20mt9v024%202-0048%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.805649%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%91%E3%83%83%E3%83%89%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3A%200%E3%80%81%E3%83%95%E3%83%A9%E3%82%B0%3A%202%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.805653%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%91%E3%83%83%E3%83%89%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3A%200%E3%80%81%E3%83%95%E3%83%A9%E3%82%B0%3A%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.805655%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%95%E3%83%A9%E3%82%B0%3A%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.805658%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20link_setup%20%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.805660%5D%20mx8-img-md%3A%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%5Bmt9v024%202-0048%5D%20%3D%26gt%3B%20%5B%3C%2FSPAN%3E%20%3CSPAN%3Emxc-mipi-csi2.0%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.805666%5D%20mxc-md%2032c00000.bus%3A%E3%82%AB%E3%83%A1%E3%83%A9%3Amxc_md_create_links%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.821137%5D%20isp_mi_stop%20%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.822206%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_enum_mbus_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.822218%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_get_format_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.822221%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMEDIA_BUS_FMT_SGRBG10_1X10%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.823629%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D-2140645888%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.823647%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_%E3%82%AF%E3%82%A8%E3%83%AA%E6%A9%9F%E8%83%BD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.823650%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_query_capability%20%2B%20CASE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.823652%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_query_capability%20%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.823655%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.823658%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%201740.823660%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.157378%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D-2140645888%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.157391%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_%E3%82%AF%E3%82%A8%E3%83%AA%E6%A9%9F%E8%83%BD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.157395%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_query_capability%20%2B%20CASE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.157397%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_query_capability%20%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.157399%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.157402%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.157404%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.169944%5D%20isp_mi_stop%20%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.233321%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_enum_mbus_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.233332%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_get_format_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.233336%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMEDIA_BUS_FMT_SGRBG10_1X10%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.284807%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D-2140645888%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.284822%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_%E3%82%AF%E3%82%A8%E3%83%AA%E6%A9%9F%E8%83%BD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.284826%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_query_capability%20%2B%20CASE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.284829%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_query_capability%20%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.284832%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.284835%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.284838%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.297599%5D%20isp_mi_stop%20%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.365311%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_enum_mbus_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.365321%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_get_format_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.365325%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMEDIA_BUS_FMT_SGRBG10_1X10%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.444996%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_enum_mbus_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.445008%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_get_format_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.445012%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMEDIA_BUS_FMT_SGRBG10_1X10%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.445045%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D-2140645888%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.445052%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_%E3%82%AF%E3%82%A8%E3%83%AA%E6%A9%9F%E8%83%BD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.445056%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_query_capability%20%2B%20CASE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.445059%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_query_capability%20%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.445061%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.445065%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.445068%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.457682%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D261%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.457698%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20VVSENSORIOC_QUERY%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.457701%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20CONFIG_HARDENED_USERCOPY%20%3D%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.457704%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_query_supports%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.457707%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.457711%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.457713%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626584%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D261%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626602%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20VVSENSORIOC_QUERY%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626604%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20CONFIG_HARDENED_USERCOPY%20%3D%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626606%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_query_supports%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626609%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626612%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626614%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626627%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D257%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626630%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626632%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626634%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626638%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D260%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626640%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%20mt9v024_get_clk%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626644%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626646%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626648%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626652%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D259%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626654%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626657%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626659%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626662%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D256%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626665%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626667%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626669%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626672%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D262%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626675%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_set_sensor_mode%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626678%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626681%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626683%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626686%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D263%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626688%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_get_sensor_mode%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626691%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626693%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626695%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626701%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D261%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626703%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20VVSENSORIOC_QUERY%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626705%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20CONFIG_HARDENED_USERCOPY%20%3D%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626707%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_query_supports%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626709%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626712%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.626714%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.639847%5D%20isp_mi_stop%20%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642856%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_set_fmt%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642866%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_get_format_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642869%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMEDIA_BUS_FMT_SGRBG10_1X10%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642876%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D285%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642881%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%20mt9v024_set_test_pattern%20-%20%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642883%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642886%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642888%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642898%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D279%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642901%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642903%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642905%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642908%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D263%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642911%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_get_sensor_mode%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642913%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642916%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.642918%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.643324%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D274%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.643332%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%20mt9v024_set_exp%20-%20%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.643335%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.643338%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.643340%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.643346%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D277%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.643348%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%20mt9v024_set_gain%20-%20%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.643350%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E5%BE%8C%20case%E3%80%81ret%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.643353%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20%E6%9C%80%E7%B5%82%E6%88%BB%E3%82%8A%E5%89%8D%E3%81%AE%20mt9v024_priv_ioctl%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.643355%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.645211%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_enum_mbus_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.645223%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_get_format_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.645226%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMEDIA_BUS_FMT_SGRBG10_1X10%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.645342%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_enum_mbus_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.645345%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_get_format_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.645347%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMEDIA_BUS_FMT_SGRBG10_1X10%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.645486%5D%20isp_s_comp%20%E3%82%92%E5%85%A5%E5%8A%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.645500%5D%20isp_s_comp%20%E3%82%92%E5%85%A5%E5%8A%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.645505%5D%20isp_s_comp%20%E3%82%92%E5%85%A5%E5%8A%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.645605%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_enum_mbus_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.645608%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_get_format_code%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.645610%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMEDIA_BUS_FMT_SGRBG10_1X10%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.661739%5D%20wdr3_hw_init%20%E3%82%92%E5%85%A5%E5%8A%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.661752%5D%20wdr3%20%E8%A7%A3%E5%83%8F%E5%BA%A6%3A%20752%20480%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.693491%5D%20isp_set_stream%201%20%E3%82%92%E5%85%A5%E5%8A%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.704723%5D%20isp_mi_start%E3%82%92%E5%85%A5%E5%8A%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.705232%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_priv_ioctl%20%E8%A6%81%E6%B1%82%E3%80%81cmd%3D272%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.705245%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%E3%80%81r3gl0%3A%20mt9v024_s_stream%20%E6%9C%89%E5%8A%B9%E5%8C%96%3A%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204323.705249%5D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMT9V024%2C%20r3gl0%3A%20mt9v024_superinit%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%204327.005171%5DMT9V024%E3%80%81r3gl0%3A%20%E3%82%BB%E3%83%B3%E3%82%B5%E6%9C%89%E5%8A%B9%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E---%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Eroot%40imx8mp%3A~%2Fbuild-out%2Fsdk%23%20%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9-ctl%20-p%20-d%20%2Fdev%2F%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B90%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20API%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%205.15.71%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E------------------------%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20vvcam-video%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%A2%E3%83%87%E3%83%AB%20viv_media%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%90%E3%82%B9%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%200x0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B35.15.71%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%88%E3%83%9D%E3%83%AD%E3%82%B8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A8%E3%83%B3%E3%83%86%E3%82%A3%E3%83%86%E3%82%A3%201%3A%20viv_v4l20%20(1%20%E3%83%91%E3%83%83%E3%83%89%E3%80%811%20%E3%83%AA%E3%83%B3%E3%82%AF)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%BF%E3%82%A4%E3%83%97%20%E3%83%8E%E3%83%BC%E3%83%89%20%E3%82%B5%E3%83%96%E3%82%BF%E3%82%A4%E3%83%97%20V4L%20%E3%83%95%E3%83%A9%E3%82%B0%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E5%90%8D%20%2Fdev%2Fvideo0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epad0%3A%20%E3%82%B7%E3%83%B3%E3%82%AF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B-%20%22vvcam-dwe.0%22%3A0%20%5B%3C%2FSPAN%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E-%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A8%E3%83%B3%E3%83%86%E3%82%A3%E3%83%86%E3%82%A3%205%3A%20vvcam-dwe.0%20(%E3%83%91%E3%83%83%E3%83%89%202%20%E5%80%8B%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%202%20%E5%80%8B)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%BF%E3%82%A4%E3%83%97%20%E3%83%8E%E3%83%BC%E3%83%89%20%E3%82%B5%E3%83%96%E3%82%BF%E3%82%A4%E3%83%97%20V4L%20%E3%83%95%E3%83%A9%E3%82%B0%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E5%90%8D%20%2Fdev%2Fv4l-subdev0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epad0%3A%20%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-%26gt%3B%20%22viv_v4l20%22%3A0%20%5B%3C%2FSPAN%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%91%E3%83%83%E3%83%891%3A%20%E3%82%B7%E3%83%B3%E3%82%AF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B-%20%22vvcam-isp.0%22%3A0%20%5B%3C%2FSPAN%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E-%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A8%E3%83%B3%E3%83%86%E3%82%A3%E3%83%86%E3%82%A38%3A%20vvcam-isp.0%20(1%E3%83%91%E3%83%83%E3%83%89%E3%80%811%E3%83%AA%E3%83%B3%E3%82%AF)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%BF%E3%82%A4%E3%83%97%20%E3%83%8E%E3%83%BC%E3%83%89%20%E3%82%B5%E3%83%96%E3%82%BF%E3%82%A4%E3%83%97%20V4L%20%E3%83%95%E3%83%A9%E3%82%B0%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E5%90%8D%20%2Fdev%2Fv4l-subdev1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epad0%3A%20%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-%26gt%3B%20%22vvcam-dwe.0%22%3A1%20%5B%3C%2FSPAN%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Eroot%40imx8mp%3A~%2Fbuild-out%2Fsdk%23%20%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9-ctl%20-p%20-d%20%2Fdev%2F%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B91%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20API%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%205.15.71%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E------------------------%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20mxc-md%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%A2%E3%83%87%E3%83%AB%20FSL%20%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%90%E3%82%B9%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%200x0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B35.15.71%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%88%E3%83%9D%E3%83%AD%E3%82%B8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A8%E3%83%B3%E3%83%86%E3%82%A3%E3%83%86%E3%82%A3%201%3A%20mxc-mipi-csi2.0%20(8%20%E3%83%91%E3%83%83%E3%83%89%E3%80%811%20%E3%83%AA%E3%83%B3%E3%82%AF)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%BF%E3%82%A4%E3%83%97%20%E3%83%8E%E3%83%BC%E3%83%89%20%E3%82%B5%E3%83%96%E3%82%BF%E3%82%A4%E3%83%97%20V4L%20%E3%83%95%E3%83%A9%E3%82%B0%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E5%90%8D%20%2Fdev%2Fv4l-subdev2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epad0%3A%20%E3%82%B7%E3%83%B3%E3%82%AF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B-%20%22mt9v024%202-0048%22%3A0%20%5B%3C%2FSPAN%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%E3%80%81%E5%A4%89%E6%9B%B4%E4%B8%8D%E5%8F%AF%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%91%E3%83%83%E3%83%891%3A%20%E3%82%B7%E3%83%B3%E3%82%AF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%91%E3%83%83%E3%83%892%3A%20%E3%82%B7%E3%83%B3%E3%82%AF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epad3%3A%20%E3%82%B7%E3%83%B3%E3%82%AF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epad4%3A%20%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epad5%3A%20%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epad6%3A%20%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epad7%3A%20%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E-%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A8%E3%83%B3%E3%83%86%E3%82%A3%E3%83%86%E3%82%A310%3A%20mt9v024%202-0048%20(%E3%83%91%E3%83%83%E3%83%891%E5%80%8B%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF1%E5%80%8B)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%BF%E3%82%A4%E3%83%97%20V4L2%20%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%82%B5%E3%83%96%E3%82%BF%E3%82%A4%E3%83%97%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%95%E3%83%A9%E3%82%B0%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E5%90%8D%20%2Fdev%2Fv4l-subdev3%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epad0%3A%20%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5Bfmt%3ASGRBG10_1X10%2F752x480%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%3A%E3%81%AA%E3%81%97%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-%26gt%3B%20%22mxc-mipi-csi2.0%22%3A0%20%5B%3C%2FSPAN%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%E3%80%81%E5%A4%89%E6%9B%B4%E4%B8%8D%E5%8F%AF%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E%5D%3CBR%20%2F%3E%3CBR%20%2F%3E%20----%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%20dewarp%20json%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%3E%7B%3CBR%20%2F%3E%20%E3%80%8CdewarpConfigArray%E3%80%8D%3A%5B%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20%E3%80%8C%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%80%8D%3A%7B%3CBR%20%2F%3E%20%E3%80%8C%E5%B9%85%E3%80%8D%3A%20752%2C%3CBR%20%2F%3E%20%E3%80%8C%E9%AB%98%E3%81%95%E3%80%8D%3A%20480%3CBR%20%2F%3E%20%7D%2C%3C%2FP%3E%3CP%3E%22%3FdewarpType%22%3A%20%22%E3%83%AC%E3%83%B3%E3%82%BA%E8%A3%9C%E6%AD%A3%E3%80%81%E9%AD%9A%E7%9C%BC%E6%8B%A1%E5%A4%A7%E3%80%81%E5%88%86%E5%89%B2%E7%94%BB%E9%9D%A2%22%2C%3CBR%20%2F%3E%20%22dewarpType%22%3A%20%22FISHEYE_DEWARP%22%2C%3C%2FP%3E%3CP%3E%E3%80%8C%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%80%8D%3A%20%7B%3CBR%20%2F%3E%20%E3%80%8C%E3%83%AD%E3%83%AF%E3%80%8D%3A%200%2C%3CBR%20%2F%3E%20%E3%80%8C%E3%83%AD%E3%82%A4%E3%80%8D%3A%200%2C%3CBR%20%2F%3E%20%E3%80%8C%E4%BF%82%E6%95%B0%E3%80%8D%3A%201.0%3CBR%20%2F%3E%20%7D%2C%3C%2FP%3E%3CP%3E%22%E3%82%B9%E3%83%97%E3%83%AA%E3%83%83%E3%83%88%22%EF%BC%9A%20%7B%3CBR%20%2F%3E%20%22horizon_line%22%3A%20240%2C%3CBR%20%2F%3E%20%22%E5%9E%82%E7%9B%B4%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%22%20%3A%20367%2C%3CBR%20%2F%3E%20%22%E5%9E%82%E7%9B%B4%E7%B7%9A%E4%B8%8B%22%3A%20367%3CBR%20%2F%3E%20%7D%2C%3C%2FP%3E%3CP%3E%E3%80%8C%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%80%8D%EF%BC%9Atrue%E3%80%81%3CBR%20%2F%3E%20%22hflip%22%20%3A%20%E5%81%BD%2C%3CBR%20%2F%3E%20%E3%80%8Cvflip%E3%80%8D%3A%20%E5%81%BD%E3%80%81%3C%2FP%3E%3CP%3E%22%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%9E%E3%83%88%E3%83%AA%E3%83%83%E3%82%AF%E3%82%B9%22%20%3A%20%5B%203.9177894938743270e%2B003%2C%200.%2C%201.9716642989691159e%2B003%2C%200.%2C3.9177894938743270e%2B003%2C1.1024451486734267e%2B003%2C%200.%2C%200.%2C%201.%20%5D%2C%3CBR%20%2F%3E%20%22%E6%AD%AA%E3%81%BF%E4%BF%82%E6%95%B0%22%3A%20%5B%20-1.3019040624278982e-001%2C%202.2621318183135611e-001%2C1.2109476203374344e-003%2C%209.4317229120640680e-004%2C-7.1053958306120402e-001%20%5D%2C%3CBR%20%2F%3E%20%E3%80%8C%E8%A6%96%E7%82%B9%E3%80%8D%3A%20%5B1.0%2C%200%2C%200%2C%200%2C%201%2C%200%2C%200%2C%200%2C%201%5D%3C%2FP%3E%3CP%3E%7D%3CBR%20%2F%3E%20%5D%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2165051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ISP%20-%20%26lt%3Bv4l2src0%3Apool0%3Asrc%26gt%3B%20can't%20allocate%2C%20setting%20maximum%20to%20minimum%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2165051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E9%81%A9%E5%88%87%E3%81%AA%20CSI%20%E9%80%9A%E4%BF%A1%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E1920x1080%20%E3%82%92%20752x480%20%E3%81%AB%E9%81%A9%E5%90%88%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E7%94%BB%E5%83%8F%E3%81%AF%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92CAN%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%87%BA%E5%8A%9B%E3%81%AF%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158302%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ISP%20-%20%26lt%3Bv4l2src0%3Apool0%3Asrc%26gt%3B%20can't%20allocate%2C%20setting%20maximum%20to%20minimum%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158302%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%3C%2FA%3E%20%E3%80%81%E3%81%99%E3%81%A7%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%AD%A3%E7%A2%BA%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E5%9B%B0%E9%9B%A3%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E7%90%86%E8%AB%96%E3%81%AF%E3%80%81OS08a20_8M_10_1080p_linear.xml%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%80%9F%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%82%BB%E3%83%B3%E3%82%B5%E5%90%8D%E3%81%A8%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%AE%E6%96%87%E5%AD%97%E5%88%97%E3%82%92%E8%87%AA%E5%88%86%E3%81%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%92%201920x1080%20%E3%81%8B%E3%82%89%20752x480%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%A8%20ISP%20%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%A7%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E7%94%BB%E5%83%8F%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AF%E6%89%BF%E7%9F%A5%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E3%80%81%E3%81%9F%E3%81%A8%E3%81%88%E6%AD%AA%E3%82%93%E3%81%A7%E3%81%84%E3%81%9F%E3%82%8A%E4%B8%8D%E6%AD%A3%E7%A2%BA%E3%81%A7%E3%81%82%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E3%81%82%E3%82%89%E3%82%86%E3%82%8B%E7%A8%AE%E9%A1%9E%E3%81%AE%E4%BF%A1%E5%8F%B7%E7%94%BB%E5%83%8F%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E5%87%BA%E5%8A%9B%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%82%82%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E4%BD%95%E3%81%8B%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%82%8B%E3%81%A8%E6%9C%9F%E5%BE%85%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E5%87%BA%E5%8A%9B%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A0%E3%81%91%E3%81%AB%E3%80%81%E5%9F%BA%E6%9C%AC%2F%E3%83%80%E3%83%9F%E3%83%BC%E3%81%AE%20752x480%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AFCAN%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E7%94%BB%E5%83%8F%E3%81%AE%E5%93%81%E8%B3%AA%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E6%B0%97%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8A%E3%82%89%E3%81%9A%E3%80%81%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E3%81%BF%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ISP%20-%20%26lt%3Bv4l2src0%3Apool0%3Asrc%26gt%3B%20can't%20allocate%2C%20setting%20maximum%20to%20minimum%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81isp-imx%20%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Eroot%40imx8mp%3A~%2Fbuild-out%2Fsdk%23%20gst-launch-1.0-v%20v4l2src%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%3D%20%2Fdev%2Fvideo0%20!%E3%80%8Cvideo%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3DYUY2%E3%80%81%E5%B9%85%3D752%E3%80%81%E9%AB%98%E3%81%95%3D480%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D30%2F1%E3%80%8D!fakesink%20%E3%83%80%E3%83%B3%E3%83%97%3Dtrue%3CBR%20%2F%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%83%A9%E3%82%A4%E3%83%96%E3%81%AA%E3%81%AE%E3%81%A7%20PREROLL%20%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93...%3CBR%20%2F%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E4%BA%8B%E5%89%8D%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%86%8D%E7%94%9F%E4%B8%AD%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E6%96%B0%E3%81%97%E3%81%84%E6%99%82%E8%A8%88%3A%20GstSystemClock%3CBR%20%2F%3E%20%2FGstPipeline%3Apipeline0%2FGstV4l2Src%3Av4l2src0.GstPad%3Asrc%3A%20caps%20%3D%20video%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3D(%E6%96%87%E5%AD%97%E5%88%97)YUY2%E3%80%81%E5%B9%85%3D(%E6%95%B4%E6%95%B0)752%E3%80%81%E9%AB%98%E3%81%95%3D(%E6%95%B4%E6%95%B0)480%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D(%E5%B0%8F%E6%95%B0)30%2F1%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%3D(%E5%B0%8F%E6%95%B0)1%2F1%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%3D(%E6%96%87%E5%AD%97%E5%88%97)%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%80%81%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%88%E3%83%AA%3D(%E6%96%87%E5%AD%97%E5%88%97)bt709%3CBR%20%2F%3E%20%2FGstPipeline%3Apipeline0%2FGstCapsFilter%3Acapsfilter0.GstPad%3Asrc%3A%20caps%20%3D%20video%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3D(%E6%96%87%E5%AD%97%E5%88%97)YUY2%E3%80%81%E5%B9%85%3D(%E6%95%B4%E6%95%B0)752%E3%80%81%E9%AB%98%E3%81%95%3D(%E6%95%B4%E6%95%B0)480%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D(%E5%B0%8F%E6%95%B0)30%2F1%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%3D(%E5%B0%8F%E6%95%B0)1%2F1%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%3D(%E6%96%87%E5%AD%97%E5%88%97)%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%80%81%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%88%E3%83%AA%3D(%E6%96%87%E5%AD%97%E5%88%97)bt709%3CBR%20%2F%3E%20%2FGstPipeline%3Apipeline0%2FGstFakeSink%3Afakesink0.GstPad%3Asink%3A%20caps%20%3D%20video%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3D(%E6%96%87%E5%AD%97%E5%88%97)YUY2%E3%80%81%E5%B9%85%3D(%E6%95%B4%E6%95%B0)752%E3%80%81%E9%AB%98%E3%81%95%3D(%E6%95%B4%E6%95%B0)480%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D(%E5%B0%8F%E6%95%B0)30%2F1%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%3D(%E5%B0%8F%E6%95%B0)1%2F1%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%3D(%E6%96%87%E5%AD%97%E5%88%97)%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%80%81%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%88%E3%83%AA%3D(%E6%96%87%E5%AD%97%E5%88%97)bt709%3CBR%20%2F%3E%20%2FGstPipeline%3Apipeline0%2FGstCapsFilter%3Acapsfilter0.GstPad%3Asink%3A%20caps%20%3D%20video%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3D(%E6%96%87%E5%AD%97%E5%88%97)YUY2%E3%80%81%E5%B9%85%3D(%E6%95%B4%E6%95%B0)752%E3%80%81%E9%AB%98%E3%81%95%3D(%E6%95%B4%E6%95%B0)480%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D(%E5%B0%8F%E6%95%B0)30%2F1%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%3D(%E5%B0%8F%E6%95%B0)1%2F1%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%3D(%E6%96%87%E5%AD%97%E5%88%97)%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%80%81%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%88%E3%83%AA%3D(%E6%96%87%E5%AD%97%E5%88%97)bt709%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BV4l2Event%5D%20%E6%A7%8B%E6%88%90%3A%20%E5%B7%A6%3D0%E3%80%81%E4%B8%8A%3D0%E3%80%81%E5%B9%85%3D752%E3%80%81%E9%AB%98%E3%81%95%3D480%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%3A%20%5B%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%5D%20jsonRequest%200xa01f%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BMediaPipeline%5D%20MEDIA_EVENT_STREAM_OPEN%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BMediaPipeline%5D%20stream0%20%E3%82%92%20NativeSensor%3A0%20%E3%81%AB%E6%8E%A5%E7%B6%9A%20---%26gt%3B%20NativeDewarp%3A0%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BMediaPipeline%5D%20stream0%20%E3%82%92%20NativeDewarp%3A0%20%E3%81%AB%E6%8E%A5%E7%B6%9A%20---%26gt%3B%20V4l2Control%3A0%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BMediaPipeline%5D%20MEDIA_EVENT_STREAM_SET_FMT%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BMediaPipeline%5D%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%3A0%20%E8%A7%A3%E5%83%8F%E5%BA%A6%3A%20752%20480%201%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BNativeSensor%5D%20setFormat%20isp%20crop%3A%20%E5%A2%83%E7%95%8C%20752X480%20%E5%B7%A6%200%20%E4%B8%8A%200%20%E3%82%B5%E3%82%A4%E3%82%BA%20752X480%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%3A%20%5BNativeSensor%5D%20setFormat%20isp%20%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%3A%20%E5%A2%83%E7%95%8C%20752X480%20%E5%B7%A6%200%20%E4%B8%8A%200%20%E3%82%B5%E3%82%A4%E3%82%BA%20752X480%3C%2FP%3E%3CP%3E%5BCITF%5D%5BINF%5D%3A%20%E7%B5%90%E6%9E%9C%20camdev%3A%3ACitfDevice%3A%3AcalibrationLoadandInit(Json%3A%3AValue%26amp%3B%2C%20Json%3A%3AValue%26amp%3B)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3AOperation%3A%3AOperation(camdev%3A%3AOperation_Handle*)%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ASensorOps%3A%3ASensorOps(camdev%3A%3ACalibSensor%26amp%3B%2C%20HalHolder*)%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ASensorOps%3A%3ASensorOps(camdev%3A%3ACalibSensor%26amp%3B%2C%20HalHolder*)%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ASensorOps%3A%3ASensorOps(camdev%3A%3ACalibSensor%26amp%3B%2C%20HalHolder*)%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ASensorOps%3A%3ASensorOps(camdev%3A%3ACalibSensor%26amp%3B%2C%20HalHolder*)%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ASensorOps%3A%3ASensorOps(camdev%3A%3ACalibSensor%26amp%3B%2C%20HalHolder*)%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ASensorOps%3A%3ASensorOps(camdev%3A%3ACalibSensor%26amp%3B%2C%20HalHolder*)%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ASensorOps%3A%3ASensorOps(camdev%3A%3ACalibSensor%26amp%3B%2C%20HalHolder*)%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ASensorOps%3A%3ASensorOps(camdev%3A%3ACalibSensor%26amp%3B%2C%20HalHolder*)%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3AOperation%3A%3AOperation(camdev%3A%3AOperation_Handle*)%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20%E7%B5%90%E6%9E%9C%20camdev%3A%3ACitfSensor%3A%3AsensorOpen(Json%3A%3AValue%26amp%3B%2C%20Json%3A%3AValue%26amp%3B)%3CBR%20%2F%3E%20CALIB_INF%3A%20%E3%82%BF%E3%82%B0%3A%20AF%3CBR%20%2F%3E%20CALIB_INF%3A%20%E3%82%BF%E3%82%B0%3A%20AEC%3CBR%20%2F%3E%20CALIB_WAN%3A%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3A%20DampOverVideo%3CBR%20%2F%3E%20CALIB_WAN%3A%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E5%AF%BE%E8%B1%A1%E5%A4%96%3A%20DampUnderVideo%3CBR%20%2F%3E%20CALIB_INF%3A%20%E3%82%BF%E3%82%B0%3A%20DEGAMMA%3CBR%20%2F%3E%20CALIB_INF%3A%20%E3%82%BF%E3%82%B0%3A%20WDR%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20CitfBufferPoolClearBufList!%E3%80%81%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3ID%3A0%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ABuffPool*%20camdev%3A%3ABitf%3A%3AbitfGetBufferPoolCtrl(ISPCORE_BUFIO_ID)%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BMediaBufferQueue%5D%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%92%E4%BD%9C%E6%88%90%20752%20480%201%204%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%5BMediaBuffer%5D%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%200x66c00000%200x000b1000%20%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%5BMediaBuffer%5D%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%200x66d00000%200x000b1000%20%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%5BMediaBuffer%5D%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%200x66f00000%200x000b1000%20%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%5BMediaBuffer%5D%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%200x67000000%200x000b1000%20%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BNativeSensor%5D%20NativeDewarp%E3%82%B7%E3%83%B3%E3%82%AF%E3%83%90%E3%83%83%E3%83%95%E3%82%A10x66c00000%E3%82%92ISP%E3%81%AB%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5BCITF%5D%5BINF%5D%3A%20CitfBufferPoolAddEntity!%E3%80%81%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3ID%3A0%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ABuffPool*%20camdev%3A%3ABitf%3A%3AbitfGetBufferPoolCtrl(ISPCORE_BUFIO_ID)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20%E9%9D%99%E7%9A%84%E7%B5%90%E6%9E%9C%20camdev%3A%3ABitf%3A%3AbitfCheckBufSizeMax(uint32_t%2C%20ISPCORE_BUFIO_ID)%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BNativeSensor%5D%20NativeDewarp%E3%82%B7%E3%83%B3%E3%82%AF%E3%83%90%E3%83%83%E3%83%95%E3%82%A10x66d00000%E3%82%92ISP%E3%81%AB%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5BCITF%5D%5BINF%5D%3A%20CitfBufferPoolAddEntity!%E3%80%81%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3ID%3A0%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ABuffPool*%20camdev%3A%3ABitf%3A%3AbitfGetBufferPoolCtrl(ISPCORE_BUFIO_ID)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20%E9%9D%99%E7%9A%84%E7%B5%90%E6%9E%9C%20camdev%3A%3ABitf%3A%3AbitfCheckBufSizeMax(uint32_t%2C%20ISPCORE_BUFIO_ID)%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BNativeSensor%5D%20NativeDewarp%E3%82%B7%E3%83%B3%E3%82%AF%E3%83%90%E3%83%83%E3%83%95%E3%82%A10x66f00000%E3%82%92ISP%E3%81%AB%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5BCITF%5D%5BINF%5D%3A%20CitfBufferPoolAddEntity!%E3%80%81%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3ID%3A0%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ABuffPool*%20camdev%3A%3ABitf%3A%3AbitfGetBufferPoolCtrl(ISPCORE_BUFIO_ID)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20%E9%9D%99%E7%9A%84%E7%B5%90%E6%9E%9C%20camdev%3A%3ABitf%3A%3AbitfCheckBufSizeMax(uint32_t%2C%20ISPCORE_BUFIO_ID)%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BNativeSensor%5D%20NativeDewarp%E3%82%B7%E3%83%B3%E3%82%AF%E3%83%90%E3%83%83%E3%83%95%E3%82%A10x67000000%E3%82%92ISP%E3%81%AB%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5BCITF%5D%5BINF%5D%3A%20CitfBufferPoolAddEntity!%E3%80%81%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3ID%3A0%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ABuffPool*%20camdev%3A%3ABitf%3A%3AbitfGetBufferPoolCtrl(ISPCORE_BUFIO_ID)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20%E9%9D%99%E7%9A%84%E7%B5%90%E6%9E%9C%20camdev%3A%3ABitf%3A%3AbitfCheckBufSizeMax(uint32_t%2C%20ISPCORE_BUFIO_ID)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20CitfBufferPoolKernelAddrMap!%E3%80%81%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%20ID%3A0%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ABuffPool*%20camdev%3A%3ABitf%3A%3AbitfGetBufferPoolCtrl(ISPCORE_BUFIO_ID)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20CitfBufferPoolSetBufToEngine!%E3%80%81%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3ID%3A0%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3ABuffPool*%20camdev%3A%3ABitf%3A%3AbitfGetBufferPoolCtrl(ISPCORE_BUFIO_ID)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20CitfBufferPoolSetBufToEngine!%E3%80%81%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3ID%3A0%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E7%95%AA%E5%8F%B7%E3%80%81buf_context%3A4%E3%80%81Engine%3A4%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E%5BCITF%5D%5BINF%5D%3A%20%E9%9D%99%E7%9A%84%20RESULT%20camdev%3A%3ABitf%3A%3AbitfCheckBufNumberMax(uint32_t%2C%20ISPCORE_BUFIO_ID)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20%E7%B5%90%E6%9E%9C%20camdev%3A%3ACitfDevice%3A%3AcameraConnect(Json%3A%3AValue%26amp%3B%2C%20Json%3A%3AValue%26amp%3B)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20int32_t%20camdev%3A%3AOperation%3A%3AcameraConnect(bool%2C%20ItfBufferCb*%2C%20const%20ConnectInfo%26amp%3B)%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiInit%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiInit%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-ISP-WDR-DRV%3A%20CamerIcIspWdr2Init%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-ISP-WDR-DRV%3A%20CamerIcIspWdr2Init%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20pathConfigSet%20in%E3%80%81%E3%83%91%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%80%81%E7%8A%B6%E6%85%8B%3A%200%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20int32_t%20camdev%3A%3AOperation%3A%3AinputConnect()%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiRegisterRequestCb%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiRegisterRequestCb%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiRegisterEventCb%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiRegisterEventCb%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-ISP-CAC-DRV%3A%20CamerIcIspCacDisable%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-ISP-CAC-DRV%3A%20CamerIcIspCacDisable%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-ISP-CAC-DRV%3A%20CamerIcIspCacConfig%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-ISP-CAC-DRV%3A%20CamerIcIspCacConfig%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-ISP-CAC-DRV%3A%20CamerIcIspCacEnable%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-ISP-CAC-DRV%3A%20CamerIcIspCacEnable%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetBurstLength%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetBurstLength%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%92%200%20(752%2C%20480)-%26gt%3B(752%2C%20480)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3ECAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20%E8%A8%AD%E5%AE%9A%20%E8%A7%A3%E5%83%8F%E5%BA%A61%20(752%2C%20480)-%26gt%3B(752%2C%20480)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20%E8%A7%A3%E5%83%8F%E5%BA%A62%E3%82%92%E8%A8%AD%E5%AE%9A%20(752%2C%20480)-%26gt%3B(752%2C%20480)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%92%203%20(752%2C%20480)-%26gt%3B(752%2C%20480)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3ECAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%92%204%20(752%2C%20480)-%26gt%3B(752%2C%20480)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3ECAMERIC-MI-DRV%3A%20CamerIcMiSetResolution%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataMode%3A%20(%E5%85%A5%E5%8A%9B)%204%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataMode%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%20(0%2C%204)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataMode%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataLayout%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataLayout%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A(0%2C%203)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataLayout%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataAlignMode%3A%20(%E5%85%A5%E5%8A%9B)%20alignmode%3A%200%E3%80%81%E3%83%91%E3%82%B9%3A0%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataAlignMode%3A%20data_align_mode%20%E3%82%92%20(0%2C%200)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3ECAMERIC-MI-DRV%3A%20CamerIcMiSetDataAlignMode%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataMode%3A%20(%E5%85%A5%E5%8A%9B)%201%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataMode%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A(1%2C%201)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataMode%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataLayout%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataLayout%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A(1%2C%203)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataLayout%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataAlignMode%3A%20(%E5%85%A5%E5%8A%9B)%20alignmode%3A%200%E3%80%81%E3%83%91%E3%82%B9%3A%201%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataAlignMode%3A%20data_align_mode%20%E3%82%92%E8%A8%AD%E5%AE%9A%20(1%2C%200)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataAlignMode%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataMode%3A%20(%E5%85%A5%E5%8A%9B)%201%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataMode%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%20(2%2C%201)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataMode%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataLayout%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataLayout%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%20(2%2C%203)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataLayout%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataAlignMode%3A%20(%E5%85%A5%E5%8A%9B)%20alignmode%3A%200%E3%80%81%E3%83%91%E3%82%B9%3A2%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataAlignMode%3A%20data_align_mode%20%E3%82%92%E8%A8%AD%E5%AE%9A%20(2%2C%200)%3CBR%20%2F%3E%20CAMERIC-MI-DRV%3A%20CamerIcMiSetDataAlignMode%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20CAM_ENGINE_CMD_START%E3%80%81ret%20%3D%200x0%3CBR%20%2F%3E%20CAMERIC-ISP-CAC-DRV%3A%20CamerIcIspCacEnable%3A%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20CAMERIC-ISP-CAC-DRV%3A%20CamerIcIspCacEnable%3A%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20int32_t%20camdev%3A%3AOperation%3A%3AinputConnect()%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20int32_t%20camdev%3A%3AOperation%3A%3AcameraConnect(bool%2C%20ItfBufferCb*%2C%20const%20ConnectInfo%26amp%3B)%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BNativeSensor%5D%20setFormat%201%20752%20480%E3%80%81%E3%82%BF%E3%82%A4%E3%83%97%201%E3%80%81%E3%83%9D%E3%83%BC%E3%83%88%3A%200%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BNativeDewarp%5D%20setFormat%201%20752%20480%E3%80%81%E3%82%BF%E3%82%A4%E3%83%97%200%E3%80%81%E3%83%9D%E3%83%BC%E3%83%88%3A%200%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BNativeDewarp%5D%20setFormat%20%E3%83%87%E3%83%AF%E3%83%BC%E3%83%97%E5%85%A5%E5%8A%9B%3A%20752x480%20YUV422I%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%3A%20%5BNativeDewarp%5D%20setFormat%201%20752%20480%E3%80%81%E3%82%BF%E3%82%A4%E3%83%97%201%E3%80%81%E3%83%9D%E3%83%BC%E3%83%88%3A%200%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BNativeDewarp%5D%20setFormat%20%E3%83%87%E3%83%AF%E3%83%BC%E3%83%97%E5%87%BA%E5%8A%9B%3A%20752x480%20YUV422I%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%3A%20%5BV4l2Event%5D%20JSON%20%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E5%8F%96%E5%BE%97%3A%20%7B%22id%22%3A%22s.fps%22%2C%22fps%22%3A30%7D%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5B%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%5D%20jsonRequest%200x1801a%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BV4l2Event%5D%20JSON%E5%BF%9C%E7%AD%94%E3%82%92%E9%80%81%E4%BF%A1%3A%20%7B%3CBR%20%2F%3E%20%E3%80%8C%E7%B5%90%E6%9E%9C%E3%80%8D%3A%200%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%3A%20%5BMediaPipeline%5D%20MEDIA_EVENT_STREAM_START%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BDewarpDriver%5D%20%E9%96%8B%E5%A7%8B%20752%20480%2048%2031%E3%80%81%E3%82%B9%E3%83%88%E3%83%A9%E3%82%A4%E3%83%89%3A%201504%201504%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BDEWARP_HW%5D%20setParams%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BNativeSensor%5D%20%E9%96%8B%E5%A7%8B%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%5BCITF%5D%5BINF%5D%3A%20%E7%B5%90%E6%9E%9C%20camdev%3A%3ACitfDevice%3A%3ApreviewStart(Json%3A%3AValue%26amp%3B%2C%20Json%3A%3AValue%26amp%3B)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20int32_t%20camdev%3A%3AOperation%3A%3ApreviewStart()%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20int32_t%20camdev%3A%3AOperation%3A%3AstreamingStart(uint)%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20HAL-ALTERA%3A%20HalConnectIrq%20%E6%8E%A5%E7%B6%9A%E3%82%BD%E3%83%BC%E3%82%B9%3A%200%3CBR%20%2F%3E%20HAL-ALTERA%3A%20HalConnectIrq%20%E6%8E%A5%E7%B6%9A%E3%82%BD%E3%83%BC%E3%82%B9%3A%204%3CBR%20%2F%3E%20HAL-ALTERA%3A%20HalConnectIrq%20%E6%8E%A5%E7%B6%9A%E3%82%BD%E3%83%BC%E3%82%B9%3A%201%3CBR%20%2F%3E%20HAL-ALTERA%3A%20HalConnectIrq%20%E6%8E%A5%E7%B6%9A%E3%82%BD%E3%83%BC%E3%82%B9%3A%202%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20CAM_ENGINE_CMD_START_STREAMING%E3%80%81ret%20%3D%200x0%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20int32_t%20camdev%3A%3AOperation%3A%3AstreamingStart(uint)%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20int32_t%20camdev%3A%3AOperation%3A%3ApreviewStart()%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20CitfInitOutChain!%E3%80%81%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%20ID%3A0%E3%80%81frame_skip%3A0%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3AXom%3A%3AXom()%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3AXom%3A%3AXom()%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3AXom%3A%3AXom(ISPCORE_BUFIO_ID%2C%20uint32_t%2C%20uint32_t)%20(%E5%85%A5%E5%8A%9B)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20camdev%3A%3AXom%3A%3AXom(ISPCORE_BUFIO_ID%2C%20uint32_t%2C%20uint32_t)%20(%E7%B5%82%E4%BA%86)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20%E7%B5%90%E6%9E%9C%20camdev%3A%3ABitf%3A%3AbitfSetOutputCtrl(ISPCORE_BUFIO_ID%2C%20camdev%3A%3AXom*)%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20CitfStartOutChain!%E3%80%81%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3ID%3A0%3CBR%20%2F%3E%20%5BCITF%5D%5BINF%5D%3A%20CitfAttachChain!%E3%80%81%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%20ID%3A0%3C%2FP%3E%3CP%3E-------%3CBR%20%2F%3E%E3%83%AB%E3%83%BC%E3%83%88%40imx8mp%3A~%2Fbuild-out%2Fsdk%23%20.%2Fvvext0%20%E3%80%8C%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%80%8D%200%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BVVEXT%3A%5D%20%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A%20%2Fdev%2Fvideo0%20(fd%3D3)%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BVVEXT%3A%5D%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3A%20viv_v4l2_device%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BVVEXT%3A%5D%20viv%20%E3%83%93%E3%83%87%E3%82%AA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%2Fdev%2Fvideo0%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BV4l2Event%5D%20JSON%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E5%8F%96%E5%BE%97%3A%20%7B%3CBR%20%2F%3E%20%E3%80%8Cid%E3%80%8D%3A%E3%80%8Cdwe.g.params%E3%80%8D%E3%80%81%3CBR%20%2F%3E%20%E3%80%8C%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0ID%E3%80%8D%3A%200%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%3A%20%5B%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%5D%20jsonRequest%200x81000%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BV4l2Event%5D%20JSON%E5%BF%9C%E7%AD%94%E3%82%92%E9%80%81%E4%BF%A1%3A%20%7B%3CBR%20%2F%3E%20%E3%80%8Cdwe%E3%80%8D%3A%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20%E3%80%8C%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%80%8D%EF%BC%9Atrue%E3%80%81%3CBR%20%2F%3E%20%22hflip%22%20%3A%20%E5%81%BD%2C%3CBR%20%2F%3E%20%E3%80%8C%E3%83%9E%E3%83%83%E3%83%88%E3%80%8D%EF%BC%9A%3CBR%20%2F%3E%20%5B%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%2C%3CBR%20%2F%3E%200.0%3CBR%20%2F%3E%20%5D%2C%3CBR%20%2F%3E%20%E3%80%8C%E3%83%A2%E3%83%BC%E3%83%89%E3%80%8D%3A%200%2C%3CBR%20%2F%3E%20%E3%80%8Cvflip%E3%80%8D%3A%20%E5%81%BD%3CBR%20%2F%3E%7D%2C%3CBR%20%2F%3E%20%E3%80%8C%E7%B5%90%E6%9E%9C%E3%80%8D%3A%200%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%3A%20%5BVVEXT%3A%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20CAPTURE%200%20%E3%82%92%E5%8F%96%E5%BE%97%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BV4l2Event%5D%20JSON%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E5%8F%96%E5%BE%97%3A%20%7B%3CBR%20%2F%3E%20%E3%80%8Cid%E3%80%8D%3A%E3%80%8C%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%80%8D%E3%80%81%3CBR%20%2F%3E%20%E3%80%8C%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0ID%E3%80%8D%3A%200%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%3A%20%5B%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%5D%20jsonRequest%200x80002%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%5BNativeSensor%5D%20CaptureImage%20%E3%83%80%E3%83%B3%E3%83%97%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%201%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%3A%20%5BV4l2Event%5D%20JSON%E5%BF%9C%E7%AD%94%E3%82%92%E9%80%81%E4%BF%A1%3A%20%7B%3CBR%20%2F%3E%20%E3%80%8C%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E7%94%BB%E5%83%8F%E3%80%8D%3A%20%E3%80%8CImage_752_480_YUV422I_20220428175226.yuv%E3%80%8D%E3%80%81%3CBR%20%2F%3E%E3%80%8C%E7%B5%90%E6%9E%9C%E3%80%8D%3A%20-1%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3EImage_752_480_YUV422I_20220428175226.yuv%20%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E------------%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%94%BB%E5%83%8F%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E4%BB%A5%E5%A4%96%E3%81%AF%20ISP%20%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%EF%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2154456%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ISP%20-%20%26lt%3Bv4l2src0%3Apool0%3Asrc%26gt%3B%20can't%20allocate%2C%20setting%20maximum%20to%20minimum%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2154456%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13712.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13712.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12060.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12060.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
