IMXRT1176 enet qos DMA reset fail
1,555 次查看
whk1619
phy of sdk 's evkmimxrt1170_lwip_httpsrv_enet_qos_bm_cm7 replace ksz8081,however,DMA Bus Mode not reset.
/* Reset first and wait for the complete
* The reset bit will automatically be cleared after complete. */
base->DMA_MODE |= ENET_QOS_DMA_MODE_SWR_MASK;
while ((base->DMA_MODE & ENET_QOS_DMA_MODE_SWR_MASK) != 0U)
stop on here.phy can link,all register can be read.if colse dma,Unable to connect to the http_server.
4 回复数
792 次查看
Hrapnx
Same is true with me. What solved your problem? Any troubleshooting tips to share?
782 次查看
Hrapnx
After enable of SION flag for REF_CLK in mux config, problem is solved.
999 次查看
luk1
Hi @whk1619
Did you find any solution for this. Can you please tell me, if you have found any solution for this, because i am facing the same issue.
1,302 次查看
Aravind_nxp
Hi @whk1619
