IMX8MPLUS - Bit rate variations for H.264/2656 coded Video stream from Camera
ソリューションへジャンプ
849件の閲覧回数
Pankaj_flextride
I am using NXP i.MX8Mplus for a camera module product. I use two cameras, one on USB and second on MIPI-CSI2 interfaces. The data path looks like:
Camera sensor -> MIPI-CSI -> ISP (bypassed, just DMA) -> GPU (OSD) -> VPU  (h/w encoder) -> RTSP stream on ethernet.
I set my bit rate for encoded video stream to 4 Mbps. The pipeline setup looks like this:
gst-launch-1.0 -v \
v4l2src device=/dev/video2 io-mode=dmabuf ! \
video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 ! \
vpuenc_hevc bitrate=4000 gop-size=60 ! \
h265parse config-interval=1 ! \
fakesink sync=false
Problem: The customer reports that bitrate varies a lot, the variation is +/- 50%, sometimes even peaks to 100%.  Expectation of customer is variation must be capped to 20% max.
How can we achieve this, i saw that CBR is not supported in SDK i am using on IMX8Mplus. I am using Yocto SDK , old one 'mikeldore' branch:
repo init -u https://github.com/nxp-imx/imx-manifest.git -b imx-linux-mickledore -m imx-6.1.55-2.2.0.xml
Please le us know:
- if it is possible to lessen the variation to 20%, if yes how?
pankaj
833件の閲覧回数
yipingwang
Yes, you can reduce the variation, but:
  • Achieving strict ±20% bitrate on i.MX8MP VPU is NOT guaranteed
  • You can realistically reduce it from ±50–100% → ~±20–40% with proper tuning
  • True CBR requires:
    • v4l2-based encoder (v4l2h264enc / v4l2h265enc)
    • explicit rate-control + QP constraints
 Step 1 — Switch to V4L2 encoder (critical)
Replace:
vpuenc_hevc
with:
v4l2h265enc
Step 2 — Enable real rate control + CBR mode
gst-launch-1.0 -v \
v4l2h265enc extra-controls="encode, \
frame_level_rate_control_enable=1, \
video_bitrate_mode=1, \
video_bitrate=4000000, \
h265_min_qp=20, \
h265_max_qp=30" ! \
fakesink sync=false
Step 3 — Tune QP range (MOST IMPORTANT)
Setting
Effect
Wide QP (e.g. 10–51)
large bitrate variation
Narrow QP (e.g. 20–30)
lower variation, lower quality
Very narrow (e.g. 24–28)
near-CBR behavior
For the requirement:
  • Start with: QP range = 20–30
  • If still >20% variation → tighten to 22–28
Step 4 — GOP / I-frame control
Your current:
gop-size=60
Issue:
  • I-frame causes large spikes (2–5x bitrate)
gop-size=30 (shorter GOP helps)
Mitigation:
OR (better):
  • Enable intra-refresh (if supported)
  • Avoid large IDR spikes
Step 5 — Optional smoothing (network level)
Even after encoder tuning, short bursts may remain.
Add:
  • queue + rtpjitterbuffer
  • OR socket buffer shaping
This smooths network bitrate, even if encoder fluctuates.
3 返答(返信)
831件の閲覧回数
Pankaj_flextride
Thank you for the reply Yiping.  I am trying these suggestions now. One more question, what about IMX95 , does encoder in IMX95 support steady bitrate?
thanks
pankaj
830件の閲覧回数
yipingwang
i.MX95 does support encoder constant-bitrate control for H.264/H.265 through V4L2, but “steady bitrate” should be understood as CBR target control rather than perfectly fixed instantaneous output.
834件の閲覧回数
yipingwang
Replace:
vpuenc_hevc
with:
v4l2h265enc
gst-launch-1.0 -v \
h265_min_qp=20, \
h265_max_qp=30" ! \
fakesink sync=false
Setting
Effect
near-CBR behavior
Your current:
gop-size=60
Issue:
Mitigation:
OR (better):
Add:
%3CLINGO-SUB%20id%3D%22lingo-sub-2382268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MPLUS%20-%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AEH.264%2F2656%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%83%93%E3%83%87%E3%82%AA%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E5%A4%89%E5%8B%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E8%A3%BD%E5%93%81%E3%81%A8%E3%81%97%E3%81%A6NXP%20i.MX8Mplus%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF2%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%821%E5%8F%B0%E3%81%AFUSB%E6%8E%A5%E7%B6%9A%E3%80%81%E3%82%82%E3%81%861%E5%8F%B0%E3%81%AFMIPI-CSI2%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E3%83%91%E3%82%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BB%E3%83%B3%E3%82%B5%20-%26gt%3B%20MIPI-CSI%20-%26gt%3B%20ISP(%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%80%81DMA%E3%81%AE%E3%81%BF)%20-%26gt%3B%20GPU(OSD)%20-%26gt%3B%20VPU(%E7%99%BD%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC)%20-%26gt%3B%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E4%B8%8A%E3%81%AERTSP%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%93%E3%83%87%E3%82%AA%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%82%924Mbps%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Egst-launch-1.0-v%20%5C%3CBR%20%2F%3E%20v4l2src%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3D%2Fdev%2Fvideo2%20io-mode%3Ddmabuf%20!%5C%3CBR%20%2F%3E%20video%2Fx-raw%E3%80%81format%3DNV12%E3%80%81width%3D1920%E3%80%81height%3D1080%E3%80%81framerate%3D30%2F1%20!%5C%3CBR%20%2F%3E%20vpuenc_hevc%20%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%3D4000%20gop-size%3D60%20!%5C%3CBR%20%2F%3E%20h265parse%20config-interval%3D1%20!%5C%3CBR%20%2F%3E%20fakesink%20sync%3Dfalse%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E7%82%B9%3A%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E5%A0%B1%E5%91%8A%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF%E5%A4%A7%E3%81%8D%E3%81%8F%E5%A4%89%E5%8B%95%E3%81%97%E3%80%81%E5%A4%89%E5%8B%95%E3%81%AF%2B%2F-50%25%E3%80%81%E6%99%82%E3%81%AB%E3%81%AF%E3%83%94%E3%83%BC%E3%82%AF%E3%81%8C100%25%E3%81%AB%E9%81%94%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E6%9C%9F%E5%BE%85%E5%80%A4%E3%81%AE%E5%A4%89%E5%8B%95%E3%81%AF%E6%9C%80%E5%A4%A720%25%E3%81%AB%E5%88%B6%E9%99%90%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%93%E3%82%8C%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3FIMX8Mplus%E3%81%A7%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8BSDK%E3%81%A7%E3%81%AFCBR%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%82%92%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AFYocto%20SDK%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%8F%A4%E3%81%84%E3%80%8Emikeldore%E3%80%8F%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%3ERepo%20init%20-U%3CSPAN%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest.git%3C%2FA%3E%3CSPAN%3E%3C%2FSPAN%3E%20-b%20IMX-Linux-mickledore%20-m%20imx-6.1.55-2.2.0.xml%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%A4%89%E5%8B%95%E5%B9%85%E3%82%9220%25%E3%81%AB%E6%8A%91%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9D%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%B3%E3%82%AB%E3%82%B8%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2382330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MPLUS%20-%20Bit%20rate%20variations%20for%20H.264%2F2656%20coded%20Video%20stream%20from%20Camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3Ei.MX95%E3%81%AFH.264%2FH.265%E3%81%8B%E3%82%89V4L2%E3%81%BE%E3%81%A7%E3%81%AE%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E5%AE%9A%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E5%88%B6%E5%BE%A1%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%80%8C%E5%AE%9A%E5%B8%B8%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%80%8D%E3%81%AF%E5%AE%8C%E5%85%A8%E3%81%AB%E5%9B%BA%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E7%9E%AC%E6%99%82%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8FCBR%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E5%88%B6%E5%BE%A1%E3%81%A8%E3%81%97%E3%81%A6%E7%90%86%E8%A7%A3%E3%81%95%E3%82%8C%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2382326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MPLUS%20-%20Bit%20rate%20variations%20for%20H.264%2F2656%20coded%20Video%20stream%20from%20Camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYiping%E3%81%95%E3%82%93%E3%80%81%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%8A%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%8F%90%E6%A1%88%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E8%B3%AA%E5%95%8F%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81IMX95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3FIMX95%E3%81%AE%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%81%AF%E5%AE%9A%E5%B8%B8%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%B3%E3%82%AB%E3%82%B8%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2382317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MPLUS%20-%20Bit%20rate%20variations%20for%20H.264%2F2656%20coded%20Video%20stream%20from%20Camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%B0%E3%82%89%E3%81%A4%E3%81%8D%E3%82%92%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3Ei.MX8MP%20VPU%E3%81%A7%3CSTRONG%3E%C2%B120%25%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92%3C%2FSTRONG%3E%E5%8E%B3%E5%AF%86%E3%81%AB%E9%81%94%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%3CSTRONG%3E%E3%81%AF%E4%BF%9D%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%E9%81%A9%E5%88%87%E3%81%AA%E3%83%81%E3%83%A5%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%3CSTRONG%3E%C2%B150%E3%80%9C100%25%E2%86%92~%C2%B120%E3%80%9C40%25%3C%2FSTRONG%3E%E3%81%AB%E7%8F%BE%E5%AE%9F%E7%9A%84%E3%81%ABCAN%E6%B8%9B%E3%82%89%E3%81%9B%E3%81%BE%E3%81%99%3C%2FLI%3E%0A%3CLI%3E%E7%9C%9F%E3%81%AECBR%E3%81%AB%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3Ev4l2%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%EF%BC%88v4l2h264enc%20%2F%20v4l2h265enc%EF%BC%89%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AA%E9%80%9F%E5%BA%A6%E5%88%B6%E5%BE%A1%20%2B%20QP%E5%88%B6%E7%B4%84%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%971%20%E2%80%94%20V4L2%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%81%B8%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81(%E3%82%AF%E3%83%AA%E3%83%86%E3%82%A3%E3%82%AB%E3%83%AB)%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E4%BA%A4%E6%8F%9B%E3%81%99%E3%82%8B%EF%BC%9A%3C%2FP%3E%0A%3CP%3Evpuenc_hevc%3C%2FP%3E%0A%3CP%3E%E8%AA%AC%E6%98%8E%EF%BC%9A%3C%2FP%3E%0A%3CP%3Ev4l2h265enc%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%972%20%E2%80%94%20%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%E5%88%B6%E5%BE%A1%E3%81%A8CBR%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3Egst-launch-1.0-v%20%5C%3C%2FP%3E%0A%3CP%3Ev4l2src%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3D%2Fdev%2Fvideo2%20io-mode%3Ddmabuf%20!%5C%3C%2FP%3E%0A%3CP%3Evideo%2Fx-raw%E3%80%81format%3DNV12%E3%80%81width%3D1920%E3%80%81height%3D1080%E3%80%81framerate%3D30%2F1%20!%5C%3C%2FP%3E%0A%3CP%3Ev4l2h265enc%20extra-controls%3D%22encode%2C%20%5C%3C%2FP%3E%0A%3CP%3Eframe_level_rate_control_enable%3D1%2C%20%5C%3C%2FP%3E%0A%3CP%3Evideo_bitrate_mode%3D1%2C%20%5C%3C%2FP%3E%0A%3CP%3Evideo_bitrate%3D4000000%2C%20%5C%3C%2FP%3E%0A%3CP%3Eh265_min_qp%3D20%2C%20%5C%3C%2FP%3E%0A%3CP%3Eh265_max_qp%3D30%22%20!%5C%3C%2FP%3E%0A%3CP%3Eh265parse%20config-interval%3D1%20!%5C%3C%2FP%3E%0A%3CP%3Efakesink%20sync%3Dfalse%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%973%20%E2%80%94%20QP%E7%AF%84%E5%9B%B2%E3%81%AE%E8%AA%BF%E6%95%B4%EF%BC%88%E6%9C%80%E3%82%82%E9%87%8D%E8%A6%81%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CTABLE%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%3CSTRONG%3E%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSTRONG%3E%E5%8A%B9%E6%9E%9C%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%E3%83%AF%E3%82%A4%E3%83%89QP%EF%BC%88%E4%BE%8B%EF%BC%9A10-51)%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AE%E5%A4%A7%E3%81%8D%E3%81%AA%E5%A4%89%E5%8B%95%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%E7%8B%AD%E3%81%84QP%EF%BC%88%E4%BE%8B%EF%BC%9A20%EF%BD%9E30%EF%BC%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%E5%A4%89%E5%8B%95%E3%81%8C%E5%B0%91%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E5%93%81%E8%B3%AA%E3%82%82%E4%BD%8E%E3%81%8F%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E3%81%AB%E7%8B%AD%E3%81%84%EF%BC%88%E4%BE%8B%EF%BC%9A24%EF%BD%9E28%EF%BC%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%E8%BF%91CBR%E6%8C%99%E5%8B%95%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CP%3E%E8%A6%81%E4%BB%B6%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E9%96%8B%E5%A7%8B%E5%80%A4%EF%BC%9AQP%E7%AF%84%E5%9B%B2%EF%BC%9D20%EF%BD%9E30%3C%2FLI%3E%0A%3CLI%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%8220%25%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E5%A4%89%E5%8B%95%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%8122%EF%BD%9E28%E3%81%AB%E7%B7%A0%E3%82%81%E4%BB%98%E3%81%91%E3%82%8B%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%26nbsp%3B%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSTRONG%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%974%20%E2%80%94%20GOP%20%2F%20I%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%88%B6%E5%BE%A1%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%8F%BE%E5%9C%A8%E3%81%AE%E7%8A%B6%E6%B3%81%3A%3C%2FP%3E%0A%3CP%3Egop-size%3D60%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EI%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AF%E5%A4%A7%E3%81%8D%E3%81%AA%E3%82%B9%E3%83%91%E3%82%A4%E3%82%AF%EF%BC%88%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AE2%EF%BD%9E5%E5%80%8D%EF%BC%89%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3Egop-size%3D30%EF%BC%88GOP%E3%81%8C%E7%9F%AD%E3%81%84%E6%96%B9%E3%81%8C%E5%8A%B9%E6%9E%9C%E7%9A%84%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E7%B7%A9%E5%92%8C%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%EF%BC%88%E3%82%88%E3%82%8A%E8%89%AF%E3%81%84%EF%BC%89%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%82%A4%E3%83%B3%E3%83%88%E3%83%A9%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%3C%2FSTRONG%3E%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%EF%BC%88%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%EF%BC%89%3C%2FLI%3E%0A%3CLI%3EIDR%E3%81%AE%E5%A4%A7%E5%B9%85%E3%81%AA%E6%80%A5%E5%A2%97%E3%82%92%E9%81%BF%E3%81%91%E3%82%8B%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%975%20%E2%80%94%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%B9%B3%E6%BB%91%E5%8C%96%EF%BC%88%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%AC%E3%83%99%E3%83%AB%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E8%AA%BF%E6%95%B4%E5%BE%8C%E3%81%A7%E3%82%82%E3%80%81%E7%9F%AD%E3%81%84%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%E3%83%8E%E3%82%A4%E3%82%BA%E3%81%8C%E6%AE%8B%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%82%AD%E3%83%A5%E3%83%BC%20%2B%20rtpjitterbuffer%3C%2FLI%3E%0A%3CLI%3EOR%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B7%E3%82%A7%E3%83%BC%E3%83%94%E3%83%B3%E3%82%B0%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8C%E5%A4%89%E5%8B%95%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%3CSTRONG%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%E3%81%8C%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
