IMX8MPLUS - Bit rate variations for H.264/2656 coded Video stream from Camera
917 次查看
Pankaj_flextride
I am using NXP i.MX8Mplus for a camera module product. I use two cameras, one on USB and second on MIPI-CSI2 interfaces. The data path looks like:
Camera sensor -> MIPI-CSI -> ISP (bypassed, just DMA) -> GPU (OSD) -> VPU  (h/w encoder) -> RTSP stream on ethernet.
I set my bit rate for encoded video stream to 4 Mbps. The pipeline setup looks like this:
gst-launch-1.0 -v \
v4l2src device=/dev/video2 io-mode=dmabuf ! \
video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 ! \
vpuenc_hevc bitrate=4000 gop-size=60 ! \
h265parse config-interval=1 ! \
fakesink sync=false
Problem: The customer reports that bitrate varies a lot, the variation is +/- 50%, sometimes even peaks to 100%.  Expectation of customer is variation must be capped to 20% max.
How can we achieve this, i saw that CBR is not supported in SDK i am using on IMX8Mplus. I am using Yocto SDK , old one 'mikeldore' branch:
repo init -u https://github.com/nxp-imx/imx-manifest.git -b imx-linux-mickledore -m imx-6.1.55-2.2.0.xml
Please le us know:
- if it is possible to lessen the variation to 20%, if yes how?
pankaj
901 次查看
yipingwang
Yes, you can reduce the variation, but:
  • Achieving strict ±20% bitrate on i.MX8MP VPU is NOT guaranteed
  • You can realistically reduce it from ±50–100% → ~±20–40% with proper tuning
  • True CBR requires:
    • v4l2-based encoder (v4l2h264enc / v4l2h265enc)
    • explicit rate-control + QP constraints
 Step 1 — Switch to V4L2 encoder (critical)
Replace:
vpuenc_hevc
with:
v4l2h265enc
Step 2 — Enable real rate control + CBR mode
gst-launch-1.0 -v \
v4l2h265enc extra-controls="encode, \
frame_level_rate_control_enable=1, \
video_bitrate_mode=1, \
video_bitrate=4000000, \
h265_min_qp=20, \
h265_max_qp=30" ! \
fakesink sync=false
Step 3 — Tune QP range (MOST IMPORTANT)
Setting
Effect
Wide QP (e.g. 10–51)
large bitrate variation
Narrow QP (e.g. 20–30)
lower variation, lower quality
Very narrow (e.g. 24–28)
near-CBR behavior
For the requirement:
  • Start with: QP range = 20–30
  • If still >20% variation → tighten to 22–28
Step 4 — GOP / I-frame control
Your current:
gop-size=60
Issue:
  • I-frame causes large spikes (2–5x bitrate)
gop-size=30 (shorter GOP helps)
Mitigation:
OR (better):
  • Enable intra-refresh (if supported)
  • Avoid large IDR spikes
Step 5 — Optional smoothing (network level)
Even after encoder tuning, short bursts may remain.
Add:
  • queue + rtpjitterbuffer
  • OR socket buffer shaping
This smooths network bitrate, even if encoder fluctuates.
899 次查看
Pankaj_flextride
Thank you for the reply Yiping.  I am trying these suggestions now. One more question, what about IMX95 , does encoder in IMX95 support steady bitrate?
thanks
pankaj
898 次查看
yipingwang
i.MX95 does support encoder constant-bitrate control for H.264/H.265 through V4L2, but “steady bitrate” should be understood as CBR target control rather than perfectly fixed instantaneous output.
902 次查看
yipingwang
Replace:
vpuenc_hevc
with:
v4l2h265enc
gst-launch-1.0 -v \
h265_min_qp=20, \
h265_max_qp=30" ! \
fakesink sync=false
Setting
Effect
near-CBR behavior
Your current:
gop-size=60
Issue:
Mitigation:
OR (better):
Add:
%3CLINGO-SUB%20id%3D%22lingo-sub-2382268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MPLUS%20-%20%E6%9D%A5%E8%87%AA%E6%91%84%E5%83%8F%E6%9C%BA%E7%9A%84%20H.264%2F2656%20%E7%BC%96%E7%A0%81%E8%A7%86%E9%A2%91%E6%B5%81%E7%9A%84%E6%AF%94%E7%89%B9%E7%8E%87%E5%8F%98%E5%8C%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20NXP%20i.MX8Mplus%20%E5%BC%80%E5%8F%91%E4%B8%80%E6%AC%BE%E7%9B%B8%E6%9C%BA%E6%A8%A1%E5%9D%97%E4%BA%A7%E5%93%81%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E4%B8%A4%E5%8F%B0%E6%91%84%E5%83%8F%E6%9C%BA%EF%BC%8C%E4%B8%80%E5%8F%B0%E9%80%9A%E8%BF%87%20USB%20%E8%BF%9E%E6%8E%A5%EF%BC%8C%E5%8F%A6%E4%B8%80%E5%8F%B0%E9%80%9A%E8%BF%87%20MIPI-CSI2%20%E6%8E%A5%E5%8F%A3%E8%BF%9E%E6%8E%A5%E3%80%82%E6%95%B0%E6%8D%AE%E8%B7%AF%E5%BE%84%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%91%84%E5%83%8F%E5%A4%B4%E4%BC%A0%E6%84%9F%E5%99%A8%20-%26gt%3B%20MIPI-CSI%20-%26gt%3B%20ISP%EF%BC%88%E7%BB%95%E8%BF%87%EF%BC%8C%E4%BB%85%20DMA%EF%BC%89%20-%26gt%3B%20GPU%EF%BC%88OSD%EF%BC%89%20-%26gt%3B%20VPU%EF%BC%88%E7%A1%AC%E4%BB%B6%E7%BC%96%E7%A0%81%E5%99%A8%EF%BC%89%20-%26gt%3B%20%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%B8%8A%E7%9A%84%20RTSP%20%E6%B5%81%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E7%BC%96%E7%A0%81%E8%A7%86%E9%A2%91%E6%B5%81%E7%9A%84%E6%AF%94%E7%89%B9%E7%8E%87%E8%AE%BE%E7%BD%AE%E4%B8%BA%204%20Mbps%E3%80%82%E6%B5%81%E6%B0%B4%E7%BA%BF%E8%AE%BE%E7%BD%AE%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3Egst-launch-1.0-v%20%5C%3CBR%20%2F%3E%20v4l2src%20%E8%AE%BE%E5%A4%87%3D%2Fdev%2Fvideo2%20io-mode%3Ddmabuf%20!%5C%3CBR%20%2F%3E%20video%2Fx-raw%2Cformat%3DNV12%2Cwidth%3D1920%2Cheight%3D1080%2Cframerate%3D30%2F1%20!%5C%3CBR%20%2F%3E%20vpuenc_hevc%20%E6%AF%94%E7%89%B9%E7%8E%87%3D4000%20gop-size%3D60%20%EF%BC%81%5C%3CBR%20%2F%3E%20h265parse%20%E9%85%8D%E7%BD%AE%E9%97%B4%E9%9A%94%3D1%EF%BC%81%5C%3CBR%20%2F%3E%20fakesink%20%E5%90%8C%E6%AD%A5%3Dfalse%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%EF%BC%9A%E5%AE%A2%E6%88%B7%E5%8F%8D%E6%98%A0%E6%AF%94%E7%89%B9%E7%8E%87%E6%B3%A2%E5%8A%A8%E5%BE%88%E5%A4%A7%EF%BC%8C%E6%B3%A2%E5%8A%A8%E5%B9%85%E5%BA%A6%E4%B8%BA%20%2B%2F-%2050%25%EF%BC%8C%E6%9C%89%E6%97%B6%E7%94%9A%E8%87%B3%E9%AB%98%E8%BE%BE%20100%25%E3%80%82%E5%AE%A2%E6%88%B7%E6%9C%9F%E6%9C%9B%E7%9A%84%E5%81%8F%E5%B7%AE%E5%BF%85%E9%A1%BB%E9%99%90%E5%88%B6%E5%9C%A820%25%E4%BB%A5%E5%86%85%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%AF%A5%E5%A6%82%E4%BD%95%E5%AE%9E%E7%8E%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%9F%E6%88%91%E5%8F%91%E7%8E%B0%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%20IMX8Mplus%20SDK%20%E4%B8%8D%E6%94%AF%E6%8C%81%20CBR%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20Yocto%20SDK%EF%BC%8C%E6%97%A7%E7%89%88%E6%9C%AC%E6%98%AF%20'mikeldore'%20%E5%88%86%E6%94%AF%EF%BC%9A%3C%2FP%3E%3CP%3Erepo%20init%20-u%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest.git%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E-b%20imx-linux-mickledore%20-m%20imx-6.1.55-2.2.0.xml%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E5%91%8A%E7%9F%A5%E6%88%91%E4%BB%AC%EF%BC%9A%3C%2FP%3E%3CP%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%89%E5%8F%AF%E8%83%BD%E5%B0%86%E6%B3%A2%E5%8A%A8%E5%B9%85%E5%BA%A6%E9%99%8D%E4%BD%8E%E5%88%B0%2020%25%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%8F%AF%E4%BB%A5%EF%BC%8C%E8%AF%A5%E5%A6%82%E4%BD%95%E5%81%9A%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E6%BD%98%E5%8D%A1%E6%9D%B0%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2382330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MPLUS%20-%20Bit%20rate%20variations%20for%20H.264%2F2656%20coded%20Video%20stream%20from%20Camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3Ei.MX95%20%E7%A1%AE%E5%AE%9E%E6%94%AF%E6%8C%81%E9%80%9A%E8%BF%87%20V4L2%20%E5%AF%B9%20H.264%2FH.265%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A0%81%E5%99%A8%E6%81%92%E5%AE%9A%E6%AF%94%E7%89%B9%E7%8E%87%E6%8E%A7%E5%88%B6%EF%BC%8C%E4%BD%86%E2%80%9C%E7%A8%B3%E5%AE%9A%E6%AF%94%E7%89%B9%E7%8E%87%E2%80%9D%E5%BA%94%E8%AF%A5%E7%90%86%E8%A7%A3%E4%B8%BA%20CBR%20%E7%9B%AE%E6%A0%87%E6%8E%A7%E5%88%B6%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E5%AE%8C%E5%85%A8%E5%9B%BA%E5%AE%9A%E7%9A%84%E7%9E%AC%E6%97%B6%E8%BE%93%E5%87%BA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2382326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MPLUS%20-%20Bit%20rate%20variations%20for%20H.264%2F2656%20coded%20Video%20stream%20from%20Camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%E4%B8%80%E5%B9%B3%E3%80%82%E6%88%91%E7%8E%B0%E5%9C%A8%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E8%BF%99%E4%BA%9B%E5%BB%BA%E8%AE%AE%E3%80%82%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8CIMX95%E7%BC%96%E7%A0%81%E5%99%A8%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%E7%A8%B3%E5%AE%9A%E6%AF%94%E7%89%B9%E7%8E%87%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E6%BD%98%E5%8D%A1%E6%9D%B0%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2382317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MPLUS%20-%20Bit%20rate%20variations%20for%20H.264%2F2656%20coded%20Video%20stream%20from%20Camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%87%8F%E5%B0%91%E8%BF%99%E7%A7%8D%E6%B3%A2%E5%8A%A8%EF%BC%8C%E4%BD%86%E6%98%AF%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%9C%A8%20i.MX8MP%20VPU%20%E4%B8%8A%E5%AE%9E%E7%8E%B0%E4%B8%A5%E6%A0%BC%E7%9A%84%3CSTRONG%3E%C2%B120%25%20%E6%AF%94%E7%89%B9%E7%8E%87%E7%B2%BE%E5%BA%A6%3C%2FSTRONG%3E%3CSTRONG%3E%E6%97%A0%E6%B3%95%E4%BF%9D%E8%AF%81%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%E9%80%9A%E8%BF%87%E9%80%82%E5%BD%93%E7%9A%84%E8%B0%83%E6%95%B4%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%9C%89%E6%95%88%E5%9C%B0%3CSTRONG%3E%E5%B0%86%E8%AF%AF%E5%B7%AE%E8%8C%83%E5%9B%B4%E4%BB%8E%C2%B150%E2%80%93100%25%E9%99%8D%E4%BD%8E%E5%88%B0~%C2%B120%E2%80%9340%25%E3%80%82%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%E7%9C%9F%E6%AD%A3%E7%9A%84%E5%9F%BA%E4%BA%8E%E6%9D%A1%E4%BB%B6%E7%9A%84%E6%8E%A8%E7%90%86%EF%BC%88CBR%EF%BC%89%E9%9C%80%E8%A6%81%EF%BC%9A%3C%2FLI%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E5%9F%BA%E4%BA%8E%20v4l2%20%E7%9A%84%E7%BC%96%E7%A0%81%E5%99%A8%EF%BC%88v4l2h264enc%20%2F%20v4l2h265enc%EF%BC%89%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E6%98%BE%E5%BC%8F%E9%80%9F%E7%8E%87%E6%8E%A7%E5%88%B6%20%2B%20QP%20%E7%BA%A6%E6%9D%9F%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%AD%A5%E9%AA%A4%201%20%E2%80%94%20%E5%88%87%E6%8D%A2%E5%88%B0%20V4L2%20%E7%BC%96%E7%A0%81%E5%99%A8%EF%BC%88%E5%85%B3%E9%94%AE%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E4%BB%A3%E6%9B%BF%EF%BC%9A%3C%2FP%3E%0A%3CP%3Evpuenc_hevc%3C%2FP%3E%0A%3CP%3E%E5%85%B6%E4%B8%AD%EF%BC%9A%3C%2FP%3E%0A%3CP%3Ev4l2h265enc%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%AD%A5%E9%AA%A4%202%20%E2%80%94%20%E5%90%AF%E7%94%A8%E5%AE%9E%E9%99%85%E9%80%9F%E7%8E%87%E6%8E%A7%E5%88%B6%20%2B%20CBR%20%E6%A8%A1%E5%BC%8F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3Egst-launch-1.0-v%20%5C%3C%2FP%3E%0A%3CP%3Ev4l2src%20%E8%AE%BE%E5%A4%87%3D%2Fdev%2Fvideo2%20io-mode%3Ddmabuf%20!%5C%3C%2FP%3E%0A%3CP%3Evideo%2Fx-raw%2Cformat%3DNV12%2Cwidth%3D1920%2Cheight%3D1080%2Cframerate%3D30%2F1%20!%5C%3C%2FP%3E%0A%3CP%3Ev4l2h265enc%20extra-controls%3D%22encode%2C%20%5C%3C%2FP%3E%0A%3CP%3Eframe_level_rate_control_enable%3D1%2C%20%5C%3C%2FP%3E%0A%3CP%3Evideo_bitrate_mode%3D1%2C%20%5C%3C%2FP%3E%0A%3CP%3Evideo_bitrate%3D4000000%2C%20%5C%3C%2FP%3E%0A%3CP%3Eh265_min_qp%3D20%2C%20%5C%3C%2FP%3E%0A%3CP%3Eh265_max_qp%3D30%22%20%EF%BC%81%5C%3C%2FP%3E%0A%3CP%3Eh265parse%20%E9%85%8D%E7%BD%AE%E9%97%B4%E9%9A%94%3D1%EF%BC%81%5C%3C%2FP%3E%0A%3CP%3Efakesink%20%E5%90%8C%E6%AD%A5%3Dfalse%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E6%AD%A5%E9%AA%A4%203%20%E2%80%94%20%E8%B0%83%E6%95%B4%20QP%20%E8%8C%83%E5%9B%B4%EF%BC%88%E6%9C%80%E9%87%8D%E8%A6%81%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CTABLE%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%3CSTRONG%3E%E8%AE%BE%E7%BD%AE%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSTRONG%3E%E5%BD%B1%E5%93%8D%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%E5%AE%BD%20QP%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8910%E2%80%9351)%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%E6%AF%94%E7%89%B9%E7%8E%87%E5%A4%A7%E5%B9%85%E6%B3%A2%E5%8A%A8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%E7%AA%84%20QP%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8920%E2%80%9330%EF%BC%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%E5%8F%98%E5%BC%82%E6%80%A7%E8%BE%83%E4%BD%8E%EF%BC%8C%E8%B4%A8%E9%87%8F%E8%BE%83%E4%BD%8E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E7%AA%84%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8924%E2%80%9328)%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%E6%8E%A5%E8%BF%91CBR%E8%A1%8C%E4%B8%BA%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CP%3E%E9%92%88%E5%AF%B9%E4%BB%A5%E4%B8%8B%E8%A6%81%E6%B1%82%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%88%9D%E5%A7%8B%E5%80%BC%EF%BC%9AQP%20%E8%8C%83%E5%9B%B4%20%3D%2020%E2%80%9330%3C%2FLI%3E%0A%3CLI%3E%E5%A6%82%E6%9E%9C%E5%B7%AE%E5%BC%82%E4%BB%8D%E7%84%B6%E5%A4%A7%E4%BA%8E%2020%25%20%E2%86%92%20%E6%94%B6%E7%B4%A7%E8%87%B3%2022%E2%80%9328%3C%2FLI%3E%0A%3CLI%3E%26nbsp%3B%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSTRONG%3E%E7%AC%AC%E5%9B%9B%E6%AD%A5%E2%80%94%E2%80%94%E5%85%B1%E5%92%8C%E5%85%9A%2FI%E6%A1%86%E6%9E%B6%E6%8E%A7%E5%88%B6%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%BD%93%E5%89%8D%E7%9A%84%EF%BC%9A%3C%2FP%3E%0A%3CP%3Egop-size%3D60%3C%2FP%3E%0A%3CP%3E%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EI%E5%B8%A7%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%AF%94%E7%89%B9%E7%8E%87%E5%A4%A7%E5%B9%85%E6%B3%A2%E5%8A%A8%EF%BC%882-5%E5%80%8D%E6%AF%94%E7%89%B9%E7%8E%87%EF%BC%89%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3Egop-size%3D30%EF%BC%88GOP%E5%AD%97%E5%BD%A2%E8%B6%8A%E7%9F%AD%E8%B6%8A%E5%A5%BD%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E5%87%8F%E8%BD%BB%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E6%88%96%E8%80%85%EF%BC%88%E6%9B%B4%E5%A5%BD%EF%BC%89%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%90%AF%E7%94%A8%3CSTRONG%3E%E5%B8%A7%E5%86%85%E5%88%B7%E6%96%B0%3C%2FSTRONG%3E%EF%BC%88%E5%A6%82%E6%9E%9C%E6%94%AF%E6%8C%81%EF%BC%89%3C%2FLI%3E%0A%3CLI%3E%E9%81%BF%E5%85%8DIDR%E5%B3%B0%E5%80%BC%E8%BF%87%E5%A4%A7%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E6%AD%A5%E9%AA%A4%205%20%E2%80%94%20%E5%8F%AF%E9%80%89%E7%9A%84%E5%B9%B3%E6%BB%91%EF%BC%88%E7%BD%91%E7%BB%9C%E5%B1%82%E9%9D%A2%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E5%8D%B3%E4%BD%BF%E7%BB%8F%E8%BF%87%E7%BC%96%E7%A0%81%E5%99%A8%E8%B0%83%E6%95%B4%EF%BC%8C%E4%BB%8D%E5%8F%AF%E8%83%BD%E5%AD%98%E5%9C%A8%E7%9F%AD%E8%84%89%E5%86%B2%E4%B8%B2%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%B7%BB%E5%8A%A0%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E9%98%9F%E5%88%97%20%2B%20rtpjitterbuffer%3C%2FLI%3E%0A%3CLI%3E%E6%88%96%E5%A5%97%E6%8E%A5%E5%AD%97%E7%BC%93%E5%86%B2%E5%8C%BA%E6%95%B4%E5%BD%A2%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E5%8D%B3%E4%BD%BF%E7%BC%96%E7%A0%81%E5%99%A8%E5%87%BA%E7%8E%B0%E6%B3%A2%E5%8A%A8%EF%BC%8C%E8%BF%99%E4%B9%9F%E8%83%BD%E5%B9%B3%E6%BB%91%3CSTRONG%3E%E7%BD%91%E7%BB%9C%E6%AF%94%E7%89%B9%E7%8E%87%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
