ICODE SLIX SL2S2002 - Set and Write Privacy password
Abeaudoin
Hi everyone,
I've built a .NET application to communicate with a Slix2 Chip and do various manipulation. The software works as expected but I have some inconsistency sometimes. The write Privacy password don't always behave the same way. Sometimes it will set it correctly, sometimes it won't. For whatever reason, the Write privacy password doesn't return the same things from the chips as the other write passwords. Is this an intended behavior? Adding a delay between the commands seems to have a positive effect on the outcome but need to understand why sometimes it will write the password correctly and sometime not.
Thank you,
Tags (2)
KaiLi
Hello @Abeaudoin
What the exact type of the reader do you use? Could you share the log of how to operate Privacy password with us? Let me try on my side.
