I2c reg write in imx_atf code imx93_psci.c
1,497 次查看
sbmd_1234
Hi NXP Team,
How to access(read and write ) the i2c registers in the imx_atf code ./plat/imx/imx93/imx93_psci.c.
Thanks.
4 回复数
1,478 次查看
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
You need to add the base address of the desired module that's within the peripheral bridge accessed (AIPS Peripheral Bridge 1).
E.g.
1,450 次查看
sbmd_1234
I didn't get your point I want to use i2c registers for PMIC please tell me an example or something that will be good for me.
Thanks.
1,337 次查看
JosephAtNXP
1,465 次查看
sbmd_1234
One more query here why can't I use this command to put system in low drive mode.
echo 2 > /sys/devices/platform/imx93-lpm/mode
