I need the method for compile uboot only without compile kernel about the lx2160A product
1,240 次查看
an897465624
Whether NXP supports compile uboot only, without compile kernel.
1,233 次查看
yipingwang
You could download the latest LSDK 21.08 from the following link.
https://www.nxp.com/design/software/embedded-software/linux-software-and-development-tools/layerscap...
Then build u-boot with the following command
$ source setup.env
$ flex-builder -c atf -b xspi -m lx2160ardb_rev2
Build atf command with the following command
$ flex-builder -c atf -m lx2160ardb_rev2
