The rootfs provided in i.MX Linux SDK 6.6.23_2.0.0 is not Ubuntu rootfs, so the command "sudo apt-get install device-tree-compiler" doesn't work.
You could add "dtc" to rebuild rootfs in Yocto build environment.
I built attached "dtc" binaries file for you, please copy the attached tar ball to your target board directly.
# tar -xzvf image.tar.gz
# cp image/usr/lib/* /usr/lib/
# cp ./image/usr/bin/fdtput /usr/bin/
# fdtput
