How to modify the device model
2,111件の閲覧回数
biomedicalengineering00
Input/output impedance by s-parameter when designing small-signal amplification circuits using transistors.
The analysis results using spicemodel and the actual measurement results using a network analyzer were different. What is the procedure for correcting this? We have confirmed that the bandwidth used is the VHF band, so there is almost no influence by the distribution constant in the layout of the device and board.
thank you
Reference: Photo sent to us
タグ(1)
2,000件の閲覧回数
Irene
NXP Pro Support
NXP Pro Support
Which target processor are you referring to here?
