Hi All,
In the attached file, how does the Analog Board (Master) distinguish between TD_ID_Board #1 (Slave#1) and TD_ID_Board #2 (Slave#2)?
In general, in the case of I2C, each Slave's address can be used to distinguish each Slave, but can PCA9616 also distinguish each Slave with an address like general I2C?
And should I set each TD_ID_Board to HW or SW? If so, can you tell me how?
Thank you in advance.
