How to debug Core A53 of iMX8MP using JLink debugger
1,548 次查看
AbdulELPRO
Hi, I'm trying to debug imx8mp (Custom board, SOM Solidrun) using J-Link but once I tried to connect Linux rebooted every time even I tried from UBoot as well. see the logs below from J-LINK
SEGGER J-Link Commander V8.54 (Compiled Jul 23 2025 12:21:02)
DLL version V8.54, compiled Jul 23 2025 12:20:05
Connecting to J-Link via USB...O.K.
Firmware: J-Link V10 compiled Jan 30 2023 11:28:07
Hardware version: V10.10
J-Link uptime (since boot): N/A (Not supported by this model)
S/N: 600113317
License(s): RDI, FlashBP, FlashDL, JFlash, GDB
VTref=3.425V
Type "connect" to establish a target connection, '?' for help
J-Link>connect
Please specify device / core. <Default>: MIMX8ML8_A53_0
Type '?' for selection dialog
Device>
Please specify target interface:
J) JTAG (Default)
S) SWD
T) cJTAG
TIF>J
Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
JTAGConf>
Specify target interface speed [kHz]. <Default>: 4000 kHz
Speed>
Device "MIMX8ML8_A53_0" selected.
Connecting to target via JTAG
ConfigTargetSettings() start
ConfigTargetSettings() end - Took 30us
InitTarget() start
InitTarget() end - Took 52.3ms
TotalIRLen = 5, IRPrint = 0x01
JTAG chain detection found 1 devices:
#0 Id: 0x00000000, IRLen: 05, Unknown device
Connect failed. Resetting via Reset pin and trying again.
ConfigTargetSettings() end - Took 40us
InitTarget() start
DAP: Could not power-up system power domain.
InitTarget() end - Took 4.70ms
Could not measure total IR len. TDO is constant high.
Failed to identify target. Resetting via Reset pin and trying again.
ConfigTargetSettings() end - Took 14us
InitTarget() start
InitTarget() end - Took 3.80ms
****** Error: CPU-TAP not found in JTAG chain
Supply voltage too low (1 Volt is required, Measured: 0.0 Volt).
Please check target power.
Target voltage too low. Please check https://kb.segger.com/J-Link_cannot_connect_to_the_CPU#Target_connection.
Error occurred: Could not connect to the target device.
For troubleshooting steps visit: https://kb.segger.com/J-Link_Troubleshooting
J-Link>
标记 (3)
1,520 次查看
AbdulELPRO
Got working, its need to be in eMMC mode
openocd -f interface/jlink.cfg -f board/imx8mp-evk.cfg
Open On-Chip Debugger 0.12.0 (2025-07-10) [https://github.com/sysprogs/openocd]
Licensed under GNU GPL v2
libusb1 d52e355daa09f17ce64819122cb067b8a2ee0d4b
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : [imx8mp.a53.0] Hardware thread awareness created
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : J-Link V10 compiled Jan 30 2023 11:28:07
Info : Hardware version: 10.10
Info : VTarget = 3.425 V
Info : clock speed 4000 kHz
Info : JTAG tap: imx8mp.cpu tap/device found: 0x5ba00477 (mfg: 0x23b (ARM Ltd), part: 0xba00, ver: 0x5)
Info : imx8mp.a53.0: hardware has 6 breakpoints, 4 watchpoints
Info : [imx8mp.a53.0] external reset detected
Info : [imx8mp.a53.0] Examination succeed
Info : [imx8mp.ahb] Examination succeed
Info : [imx8mp.a53.0] starting gdb server on 3333
Info : Listening on port 3333 for gdb connections
Info : [imx8mp.m4] starting gdb server on 3334
Info : Listening on port 3334 for gdb connections
Info : [imx8mp.ahb] gdb port disabled
1,521 次查看
AbdulELPRO
1,475 次查看
Rita_Wang
Good news it can works and thanks for sharing.
1,538 次查看
AbdulELPRO
When I tried openocd then I got the following:
Info : clock speed 400 kHz
Info : JTAG tap: imx8mp.cpu tap/device found: 0x088e601d (mfg: 0x00e (Freescale (Motorola)), part: 0x88e6, ver: 0x0)
Warn : JTAG tap: imx8mp.cpu UNEXPECTED: 0x088e601d (mfg: 0x00e (Freescale (Motorola)), part: 0x88e6, ver: 0x0)
Error: JTAG tap: imx8mp.cpu expected 1 of 1: 0x5ba00477 (mfg: 0x23b (ARM Ltd), part: 0xba00, ver: 0x5)
Error: Trying to use configured scan chain anyway...
Error: IR capture error at bit 4, saw 0x21 not 0x...3
Warn : Bypassing JTAG setup events due to errors
Error: Invalid ACK (0) in DAP response
%3CLINGO-SUB%20id%3D%22lingo-sub-2148029%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20JLink%20%E8%B0%83%E8%AF%95%E5%99%A8%E8%B0%83%E8%AF%95%20iMX8MP%20%E7%9A%84%E6%A0%B8%E5%BF%83%20A53%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148029%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20J-Link%20%E8%B0%83%E8%AF%95%20imx8mp%EF%BC%88%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%EF%BC%8CSOM%20Solidrun%EF%BC%89%EF%BC%8C%E4%BD%86%E6%98%AF%E6%9C%89%E4%B8%80%E6%AC%A1%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%9E%E6%8E%A5%20Linux%20%E6%AF%8F%E6%AC%A1%E9%83%BD%E4%BC%9A%E9%87%8D%E5%90%AF%EF%BC%8C%E5%8D%B3%E4%BD%BF%E6%88%91%E4%B9%9F%E8%AF%95%E8%BF%87%20uBoot%E3%80%82%E8%AF%B7%E5%8F%82%E9%98%85%E4%B8%8B%E9%9D%A2%20J-LINK%20%E7%9A%84%E6%97%A5%E5%BF%97%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3ESEGGER%20J-Link%20Commander%20V8.54%20(Compiled%20Jul%2023%202025%2012%3A21%3A02)%3CBR%20%2F%3EDLL%20version%20V8.54%2C%20compiled%20Jul%2023%202025%2012%3A20%3A05%3C%2FP%3E%3CP%3E%E9%80%9A%E8%BF%87%20USB%20%E8%BF%9E%E6%8E%A5%20J-Link...%3CBR%20%2F%3E%3CSTRONG%3E%20%E5%A5%BD%20%E5%9B%BA%E4%BB%B6%EF%BC%9AJ-Link%20V10%20%E7%BC%96%E8%AF%91%E4%BA%8E%202023%20%E5%B9%B4%201%20%E6%9C%88%2030%20%E6%97%A5%2011%3A28%3A07%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%20%E7%A1%AC%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9AV10.10%3C%2FSTRONG%3E%3CBR%20%2F%3E%20J-Link%20%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E6%97%B6%E9%97%B4%EF%BC%88%E8%87%AA%E5%90%AF%E5%8A%A8%E4%BB%A5%E6%9D%A5%EF%BC%89%EF%BC%9AN%2FA%EF%BC%88%E6%AD%A4%E5%9E%8B%E5%8F%B7%E4%B8%8D%E6%94%AF%E6%8C%81%EF%BC%89%3CBR%20%2F%3E%20S%2FN%EF%BC%9A600113317%3CBR%20%2F%3E%20%E8%AE%B8%E5%8F%AF%E8%AF%81%EF%BC%9ARDI%E3%80%81FlashBP%E3%80%81FlashDL%E3%80%81jFlash%E3%80%81GDB%3CBR%20%2F%3E%20v%20tref%3D3.425V%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E9%94%AE%E5%85%A5%20%22%20connect%20%22%20%E5%BB%BA%E7%AB%8B%E7%9B%AE%E6%A0%87%E8%BF%9E%E6%8E%A5%EF%BC%8C'%EF%BC%9F'%E5%A6%82%E9%9C%80%E5%B8%AE%E5%8A%A9%20%3CBR%20%2F%3E%20J-Link%20%26gt%3B%20connect%20%3CBR%20%2F%3E%20%E8%AF%B7%E6%8C%87%E5%AE%9A%E8%AE%BE%E5%A4%87%2F%E5%86%85%E6%A0%B8%E3%80%82%3CDEFAULT%3E%3A%20MIMX8ML8%20_A53_0%3CBR%20%2F%3E%20%E7%B1%BB%E5%9E%8B%20'%EF%BC%9F'%E5%AF%B9%E4%BA%8E%E9%80%89%E6%8B%A9%E5%AF%B9%E8%AF%9D%E6%A1%86%3CBR%20%2F%3E%20%E8%AE%BE%E5%A4%87%20%26gt%3B%3CBR%20%2F%3E%20%E8%AF%B7%E6%8C%87%E5%AE%9A%E7%9B%AE%E6%A0%87%E6%8E%A5%E5%8F%A3%EF%BC%9A%3CBR%20%2F%3E%20J)%20JTAG%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3CBR%20%2F%3E%20S)%20SWD%3CBR%20%2F%3E%20T)%20cjTag%3CBR%20%2F%3E%20TIF%20%26gt%3B%20J%3CBR%20%2F%3E%20%E8%AE%BE%E5%A4%87%E5%9C%A8%20JTAG%3CDEFAULT%3E%20%E9%93%BE%EF%BC%88irPre%E3%80%81drPre%EF%BC%89%E4%B8%AD%E7%9A%84%E4%BD%8D%E7%BD%AE%3A%20-1%EF%BC%8C-1%20%3D%20%26gt%3B%20%E8%87%AA%E5%8A%A8%E6%A3%80%E6%B5%8B%3CBR%20%2F%3E%20jtagConf%20%26gt%3B%3CBR%20%2F%3E%20%E6%8C%87%E5%AE%9A%E7%9B%AE%E6%A0%87%E6%8E%A5%E5%8F%A3%E9%80%9F%E5%BA%A6%20%5BkHz%5D%E3%80%82%3CDEFAULT%3E%3A%204000%20kHz%3CBR%20%2F%3E%20%E9%80%9F%E5%BA%A6%20%26gt%3B%3CBR%20%2F%3E%20%E8%AE%BE%E5%A4%87%20%22%20MIMX8ML8_A53_0%20%22%20%E5%B7%B2%E9%80%89%E6%8B%A9%E3%80%82%3C%2FDEFAULT%3E%3C%2FDEFAULT%3E%3C%2FDEFAULT%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E9%80%9A%E8%BF%87%20JTAG%20%3CBR%20%2F%3E%20ConfigTargetSettings%20()%20%E8%BF%9E%E6%8E%A5%E7%9B%AE%E6%A0%87%E5%90%AF%E5%8A%A8%20c%20%3CBR%20%2F%3E%20onfigTargetSettings%20()%20%E7%BB%93%E6%9D%9F-%E8%8A%B1%E4%BA%86%2030%20%E4%B8%AA%E5%B0%8F%E6%97%B6%20initTarg%20%3CBR%20%2F%3E%20et%20()%20%E5%90%AF%E5%8A%A8%20%3CBR%20%2F%3E%20initTarget%20()%20%E7%BB%93%E6%9D%9F-%E8%8A%B1%E4%BA%86%2052.3%20%E6%AF%AB%E7%A7%92%20t%20%3CBR%20%2F%3E%20otalIrlen%20%3D%205%EF%BC%8CirPrint%20%3D%200x01%20%3CBR%20%2F%3E%20JTAG%20%E9%93%BE%E6%A3%80%E6%B5%8B%E5%8F%91%E7%8E%B0%201%20%E5%8F%B0%E8%AE%BE%E5%A4%87%EF%BC%9A%230%20ID%EF%BC%9A0x00000000%EF%BC%8CIRlen%EF%BC%9A05%EF%BC%8C%E6%9C%AA%E7%9F%A5%E8%AE%BE%E5%A4%87%E8%BF%9E%E6%8E%A5%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E9%80%9A%E8%BF%87%20RESET%20%E5%AF%86%E7%A0%81%20RESET%20%E5%B9%B6%E9%87%8D%E8%AF%95%E3%80%82%3CBR%20%2F%3EconfigTargetSettings%20()%20%E5%90%AF%E5%8A%A8%20%3CBR%20%2F%3E%20configTargetSettings%20()%20%E7%BB%93%E6%9D%9F%E2%80%94%E2%80%94%E8%8A%B1%E4%BA%86%2040%20%E4%B8%AA%3CBR%20%2F%3E%E5%B0%8F%E6%97%B6%E5%88%9D%E5%A7%8B%E5%8C%96%E7%9B%AE%E6%A0%87%20()%20%E5%90%AF%E5%8A%A8%20%3CBR%20%2F%3E%20DAP%EF%BC%9A%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E5%8A%9F%E7%8E%87%E5%9F%9F%E3%80%82%3CBR%20%2F%3EInitTarget()%20end%20-%20%E8%80%97%E6%97%B6%204.70ms%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E6%B5%8B%E9%87%8F%E7%BA%A2%E5%A4%96%E6%80%BB%E9%95%BF%E5%BA%A6%E3%80%82TDO%20%E5%A7%8B%E7%BB%88%E4%B8%BA%E9%AB%98%E7%94%B5%E5%B9%B3%E3%80%82%3CBR%20%2F%3E%E6%9C%AA%E8%83%BD%E8%AF%86%E5%88%AB%E7%9B%AE%E6%A0%87%E3%80%82%E9%80%9A%E8%BF%87%20RESET%20%E5%AF%86%E7%A0%81%20RESET%20%E5%B9%B6%E9%87%8D%E8%AF%95%E3%80%82%3CBR%20%2F%3EconfigTargetSettings%20()%20%E5%90%AF%E5%8A%A8%20%3CBR%20%2F%3E%20configTargetSettings%20()%20%E7%BB%93%E6%9D%9F%E2%80%94%E2%80%94%E8%8A%B1%E4%BA%86%2014%20%E4%B8%AA%3CBR%20%2F%3E%E5%B0%8F%E6%97%B6%E5%88%9D%E5%A7%8B%E5%8C%96%E7%9B%AE%E6%A0%87%20()%20%E5%90%AF%E5%8A%A8%20%3CBR%20%2F%3E%20DAP%EF%BC%9A%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E7%B3%BB%E7%BB%9F%E5%8A%9F%E7%8E%87%E5%9F%9F%E3%80%82%3CBR%20%2F%3EInitTarget()%20%E7%BB%93%E6%9D%9F%20-%20%E8%80%97%E6%97%B6%203.80ms%3C%2FP%3E%3CP%3E******%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%9C%A8%20JTAG%20%E9%93%BE%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%20CPU-TAP%20%3CBR%20%2F%3E%20%E7%94%B5%E6%BA%90%E7%94%B5%E5%8E%8B%E5%A4%AA%E4%BD%8E%EF%BC%88%E9%9C%80%E8%A6%81%201%20%E4%BC%8F%E7%89%B9%EF%BC%8C%E6%B5%8B%E9%87%8F%EF%BC%9A0.0%20%E4%BC%8F%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E6%A3%80%E6%9F%A5%E7%9B%AE%E6%A0%87%E5%8A%9F%E7%8E%87%E3%80%82%3CBR%20%2F%3E%E7%9B%AE%E6%A0%87%E7%94%B5%E5%8E%8B%E5%A4%AA%E4%BD%8E%E3%80%82%E8%AF%B7%E6%9F%A5%E9%98%85%3CA%20href%3D%22https%3A%2F%2Fkb.segger.com%2FJ-Link_cannot_connect_to_the_CPU%23Target_connection%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fkb.segger.com%2FJ-Link_cannot_connect_to_the_CPU%23Target_connection%E3%80%82%3C%2FA%3E%3CBR%20%2F%3E%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%9B%AE%E6%A0%87%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3E%E6%9C%89%E5%85%B3%E6%95%85%E9%9A%9C%E6%8E%92%E9%99%A4%E6%AD%A5%E9%AA%A4%EF%BC%8C%E8%AF%B7%E8%AE%BF%E9%97%AE%3CA%20href%3D%22https%3A%2F%2Fkb.segger.com%2FJ-Link_Troubleshooting%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%20https%3A%2F%2Fkb.segger.com%2FJ-Link_Troubleshooting%3C%2FA%3E%3CBR%20%2F%3EJ-Link%26gt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20debug%20Core%20A53%20of%20iMX8MP%20using%20JLink%20debugger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E6%B6%88%E6%81%AF%E6%98%AF%E5%AE%83%E8%83%BD%E5%8F%91%E6%8C%A5%E4%BD%9C%E7%94%A8%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%88%86%E4%BA%AB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20debug%20Core%20A53%20of%20iMX8MP%20using%20JLink%20debugger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BC%80%E5%A7%8B%E5%B7%A5%E4%BD%9C%E4%BA%86%EF%BC%8C%E9%9C%80%E8%A6%81%E8%BF%9B%E5%85%A5%20eMMC%20%E6%A8%A1%E5%BC%8F%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20openocd-f%20interface%2Fjlink.cfg-f%20%E6%9D%BF%2Fimx8mp-evk.cfg%20%3CBR%20%2F%3E%E5%BC%80%E6%94%BE%E5%BC%8F%E7%89%87%E4%B8%8A%E8%B0%83%E8%AF%95%E5%99%A8%200.12.0%20(2025-07-10)%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fsysprogs%2Fopenocd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%5Bhttps%3A%2F%2Fgithub.com%2Fsysprogs%2Fopenocd%5D%3C%2FA%3E%3CBR%20%2F%3E%E9%87%87%E7%94%A8%20GNU%20GPL%20v2%20%E8%AE%B8%E5%8F%AF%3CBR%20%2F%3Elibusb1%20d52e355daa09f17ce64819122cb067b8a2ee0d4b%3CBR%20%2F%3E%E6%9C%89%E5%85%B3%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%EF%BC%8C%E8%AF%B7%E9%98%85%E8%AF%BB%3CBR%20%2F%3E%3CA%20href%3D%22http%3A%2F%2Fopenocd.org%2Fdoc%2Fdoxygen%2Fbugs.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fopenocd.org%2Fdoc%2Fdoxygen%2Fbugs.html%3C%2FA%3E%3CBR%20%2F%3E%E4%BF%A1%E6%81%AF%20%3A%20%5Bimx8mp.a53.0%5D%E5%B7%B2%E5%88%9B%E5%BB%BA%E7%A1%AC%E4%BB%B6%E7%BA%BF%E7%A8%8B%E6%84%9F%E7%9F%A5%3CBR%20%2F%3E%E4%BF%A1%E6%81%AF%EF%BC%9A%E5%9C%A8%E7%AB%AF%E5%8F%A3%206666%20%E4%B8%8A%E7%9B%91%E5%90%AC%20tcl%20%E8%BF%9E%E6%8E%A5%3CBR%20%2F%3E%E4%BF%A1%E6%81%AF%EF%BC%9A%E5%9C%A8%E7%AB%AF%E5%8F%A3%204444%20%E4%B8%8A%E7%9B%91%E5%90%AC%E8%BF%9C%E7%A8%8B%E7%99%BB%E5%BD%95%E8%BF%9E%E6%8E%A5%E4%BF%A1%E6%81%AF%EF%BC%9AJ-Link%20V10%20%E5%B7%B2%E7%BC%96%E8%AF%91%202023%20%E5%B9%B4%201%20%E6%9C%88%2030%20%E6%97%A5%2011%3A28%3A07%20%3CBR%20%2F%3E%20%E4%BF%A1%E6%81%AF%EF%BC%9AvTarget%20%3D%203.425%20V%20%E4%BF%A1%E6%81%AF%EF%BC%9A%E6%97%B6%E9%92%9F%E9%80%9F%E5%BA%A6%204000%20kHz%20%3CBR%20%2F%3E%20%E4%BF%A1%E6%81%AF%EF%BC%9AJTAG%20TAP%EF%BC%9Aimx8mp.%20%3CBR%20%2F%3E%20cpu%20TAP%2F%E6%89%BE%E5%88%B0%E7%9A%84%E8%AE%BE%E5%A4%87%EF%BC%9A0x5ba00477%EF%BC%88m%20%3CBR%20%2F%3E%20fg%EF%BC%9A0x23b%20(Arm%20Ltd)%EF%BC%8C%E9%83%A8%E5%88%86%EF%BC%9A0xba00%EF%BC%8C%E7%89%88%E6%9C%AC%EF%BC%9A0x5)%20%3CBR%20%2F%3E%20%E4%BF%A1%E6%81%AF%EF%BC%9Aimx8mp.a53.0%EF%BC%9A%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E6%9C%89%206%20%E4%B8%AA%E6%96%AD%E7%82%B9%EF%BC%8C4%20%E4%B8%AA%E8%A7%82%E5%AF%9F%E7%82%B9%3CBR%20%2F%3EInfo%20%3A%20%5Bimx8mp.a53.0%5D%E6%A3%80%E6%B5%8B%E5%88%B0%E5%A4%96%E9%83%A8RESET%3CBR%20%2F%3E%E4%BF%A1%E6%81%AF%EF%BC%9A%5Bimx8mp.a53.0%5D%E8%80%83%E8%AF%95%E6%88%90%E5%8A%9F%3CBR%20%2F%3E%E4%BF%A1%E6%81%AF%20%3A%20%5Bimx8mp.ahb%5DExamination%20succeed%3CBR%20%2F%3EInfo%20%3A%20%5Bimx8mp.a53.0%5D%E5%90%AF%E5%8A%A8%203333%20%E7%AB%AF%E5%8F%A3%E4%B8%8A%E7%9A%84%20gdb%20%E6%9C%8D%E5%8A%A1%E5%99%A8%3CBR%20%2F%3EInfo%20%3A%20%E7%9B%91%E5%90%AC%203333%20%E7%AB%AF%E5%8F%A3%E4%B8%8A%E7%9A%84%20gdb%20%E8%BF%9E%E6%8E%A5%3CBR%20%2F%3EInfo%20%3A%20%5Bimx8mp.m4%5D%E5%90%AF%E5%8A%A8%203334%20%E7%AB%AF%E5%8F%A3%E4%B8%8A%E7%9A%84%20gdb%20%E6%9C%8D%E5%8A%A1%E5%99%A8%3CBR%20%2F%3EInfo%20%3A%20%E7%9B%91%E5%90%AC%203334%20%E7%AB%AF%E5%8F%A3%E4%B8%8A%E7%9A%84%20gdb%20%E8%BF%9E%E6%8E%A5%3CBR%20%2F%3EInfo%20%3A%20%5Bimx8mp.ahb%5D%E7%A6%81%E7%94%A8%20gdb%20%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20debug%20Core%20A53%20of%20iMX8MP%20using%20JLink%20debugger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BD%93%E6%88%91%E8%AF%95%E7%94%A8%20openocd%20%E6%97%B6%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E7%BB%93%E6%9E%9C%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3Eopenocd%20-f%20interface%2Fjlink.cfg%20-f%20%E6%9D%BF%2Fimx8mp-evk.cfg%20%3CBR%20%2F%3E%E5%BC%80%E6%94%BE%E5%BC%8F%E7%89%87%E4%B8%8A%E8%B0%83%E8%AF%95%E5%99%A8%200.12.0%20(2025-07-10)%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fsysprogs%2Fopenocd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%5Bhttps%3A%2F%2Fgithub.com%2Fsysprogs%2Fopenocd%5D%3C%2FA%3E%3CBR%20%2F%3E%E9%87%87%E7%94%A8%20GNU%20GPL%20v2%20%E8%AE%B8%E5%8F%AF%3CBR%20%2F%3Elibusb1%20d52e355daa09f17ce64819122cb067b8a2ee0d4b%3CBR%20%2F%3E%E6%9C%89%E5%85%B3%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%EF%BC%8C%E8%AF%B7%E9%98%85%E8%AF%BB%3CBR%20%2F%3E%3CA%20href%3D%22http%3A%2F%2Fopenocd.org%2Fdoc%2Fdoxygen%2Fbugs.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fopenocd.org%2Fdoc%2Fdoxygen%2Fbugs.html%3C%2FA%3E%3CBR%20%2F%3E%E4%BF%A1%E6%81%AF%20%3A%20%5Bimx8mp.a53.0%5D%E5%B7%B2%E5%88%9B%E5%BB%BA%E7%A1%AC%E4%BB%B6%E7%BA%BF%E7%A8%8B%E6%84%9F%E7%9F%A5%3CBR%20%2F%3E%E4%BF%A1%E6%81%AF%EF%BC%9A%E5%9C%A8%E7%AB%AF%E5%8F%A3%206666%20%E4%B8%8A%E7%9B%91%E5%90%AC%20tcl%20%E8%BF%9E%E6%8E%A5%3CBR%20%2F%3E%E4%BF%A1%E6%81%AF%EF%BC%9A%E5%9C%A8%E7%AB%AF%E5%8F%A3%204444%20%E4%B8%8A%E7%9B%91%E5%90%AC%20telnet%20%E8%BF%9E%E6%8E%A5%E4%BF%A1%E6%81%AF%EF%BC%9AJ-Link%20V10%20%E7%BC%96%E8%AF%91%E4%BA%8E%202023%20%E5%B9%B4%201%20%E6%9C%88%2030%20%E6%97%A5%2011%3A28%3A07%20%3CBR%20%2F%3E%20%E4%BF%A1%E6%81%AF%EF%BC%9AvTarget%20%3D%203.425%20V%20%E4%BF%A1%E6%81%AF%EF%BC%9A%E6%97%B6%E9%92%9F%E9%80%9F%E5%BA%A6%20400%20kHz%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%E4%BF%A1%E6%81%AF%EF%BC%9AJTAG%EF%BC%9Aimx8mp.%20%3CBR%20%2F%3E%20cpu%20%E7%82%B9%E5%87%BB%2F%E6%89%BE%E5%88%B0%E7%9A%84%E8%AE%BE%E5%A4%87%EF%BC%9A0x088e601d%20(m%20%3CBR%20%2F%3E%20fg%3A%200x00e%20(%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%EF%BC%88%E6%91%A9%E6%89%98%E7%BD%97%E6%8B%89%EF%BC%89%EF%BC%89%EF%BC%8C%E9%83%A8%E5%88%86%EF%BC%9A0x88e6%EF%BC%8C%E7%89%88%E6%9C%AC%EF%BC%9A0x0%EF%BC%89%E8%AD%A6%E5%91%8A%EF%BC%9AJTAG%20%E7%82%B9%E5%87%BB%EF%BC%9Aimx8mp.cpu%20%E6%84%8F%E5%A4%96%EF%BC%9A0x088e601d%EF%BC%88%E5%88%B6%E9%80%A0%E5%8E%82%EF%BC%9A0x00e%EF%BC%88%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%EF%BC%88%E6%91%A9%E6%89%98%E7%BD%97%E6%8B%89%EF%BC%89%EF%BC%89%EF%BC%8C%E9%83%A8%E5%88%86%EF%BC%9A0x88e6%EF%BC%8C%E7%89%88%E6%9C%AC%EF%BC%9A0x0%EF%BC%89%E9%94%99%E8%AF%AF%EF%BC%9AJTAG%20tap%EF%BC%9Aimx8mp.cpu%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E9%A2%84%E8%AE%A1%E6%98%AF%201%20%E4%B8%AD%E7%9A%84%201%EF%BC%9A0x5ba00477%EF%BC%88mfg%EF%BC%9A0x23b%EF%BC%88ARM%20Ltd%EF%BC%89%EF%BC%8C%E9%83%A8%E5%88%86%EF%BC%9A0xba00%EF%BC%8C%E7%89%88%E6%9C%AC%EF%BC%9A0x5%EF%BC%89%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%E9%83%BD%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E9%85%8D%E7%BD%AE%E7%9A%84%E6%89%AB%E6%8F%8F%E9%93%BE...%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BD%8D%204%20%E5%A4%84%E5%87%BA%E7%8E%B0%E7%BA%A2%E5%A4%96%E6%8D%95%E8%8E%B7%E9%94%99%E8%AF%AF%EF%BC%8C%E7%9C%8B%E5%88%B0%E7%9A%84%E6%98%AF%200x21%20%E8%80%8C%E4%B8%8D%E6%98%AF%200x...%203%20%3CBR%20%2F%3E%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E7%94%B1%E4%BA%8E%E9%94%99%E8%AF%AF%E8%80%8C%E7%BB%95%E8%BF%87%20JTAG%20%E8%AE%BE%E7%BD%AE%E4%BA%8B%E4%BB%B6%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9ADAP%20%E5%93%8D%E5%BA%94%E4%B8%AD%E7%9A%84%20ACK%20(0)%20%E6%97%A0%E6%95%88%3C%2FP%3E%3C%2FLINGO-BODY%3E
