How to add virtual camera nodes in android 13/14?
1,364 次查看
vedantteksun
hello,
i have imx8mp kit with the android 13. I have added the v4l2loopback driver in v4l2 section and built it. Using the v4l2loopback i have created /dev/video8 node. i am also performing the ffmpeg command to get the rtsp stream and feed to /dev/video8.
My end goal is to use that rtsp stream as the secondary camera, but i am not getting the stream on the second camera as no switch camera option not coming on the screen.
Please if anyone has solution kindly provide
1) insmod v4l2loopback.ko video_nr=8
2) ffmpeg -v verbose -i rtsp://192.168.1.163:8554/mystream -pix_fmt yuyv422 -f v4l2 /dev/video8
标记 (1)
1,332 次查看
vedantteksun
Hello @Bio_TICFSL ,
I am not getting understand, Could you please brief?
1,342 次查看
Bio_TICFSL
If you has entered the camera module into kernel is going to be easy to integrate just search for the camera, use video*
