Ghostscript recipe Yocto Build Error
1,234件の閲覧回数
mikie_mikie
I am doing Yocto Build for FRDM-IMX8MPLUS development board and I did bitbake with following commands.
bitbake -k imx-image-full
Result: bitbake failed and recipe name: ghostscript
bitbake -k ghostscript
then I received following error.
I think something wrong with gcc library. Please advise me.
| /usr/src/debug/gcc/13.3.0/gcc/range.cc:42:(.text+0x9c): undefined reference to `build_zero_cst(tree_node*)'
| /home/compulab/imx-yocto-bsp/frdm-imx8mp/tmp/work/armv8a-poky-linux/gcc/13.3.0/recipe-sysroot-native/usr/bin/aarch64-poky-linux/../../libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/13.3.0/ld: /usr/src/debug/gcc/13.3.0/gcc/range.cc:42:(.text+0xa8): undefined reference to `build_zero_cst(tree_node*)'
| /home/compulab/imx-yocto-bsp/frdm-imx8mp/tmp/work/armv8a-poky-linux/gcc/13.3.0/recipe-sysroot-native/usr/bin/aarch64-poky-linux/../../libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/13.3.0/ld: range.o: in function `int_range<1u, false>::int_range(tree_node*, tree_node*, value_range_kind)':
| /usr/src/debug/gcc/13.3.0/gcc/value-range.h:941:(.text+0xe4): undefined reference to `irange::set(tree_node*, tree_node*, value_range_kind)'
| /home/compulab/imx-yocto-bsp/frdm-imx8mp/tmp/work/armv8a-poky-linux/gcc/13.3.0/recipe-sysroot-native/usr/bin/aarch64-poky-linux/../../libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/13.3.0/ld: range.o: in function `int_range<1u, false>::operator=(int_range<1u, false> const&)':
| /usr/src/debug/gcc/13.3.0/gcc/value-range.h:972:(.text+0x264): undefined reference to `irange::operator=(irange const&)'
| collect2: error: ld returned 1 exit status
| make[1]: *** [../../../../../../../work-shared/gcc-13.3.0-r0/gcc-13.3.0/gcc/lto/Make-lang.in:102: lto-dump] Error 1
| make[1]: Leaving directory '/home/compulab/imx-yocto-bsp/frdm-imx8mp/tmp/work/armv8a-poky-linux/gcc/13.3.0/gcc-13.3.0/build.aarch64-poky-linux.aarch64-poky-linux/gcc'
| make: *** [Makefile:4627: all-gcc] Error 2
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
ERROR: Task (/home/compulab/imx-yocto-bsp/sources/poky/meta/recipes-devtools/gcc/gcc_13.3.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 4587 tasks of which 3788 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages, returning a non-zero exit code.
1,184件の閲覧回数
mikie_mikie
Hello NXP Tech Support,
Thank you for your reply.
After I deleted tmp folder then I was able to do bitbake -k successfully.
Kind regards,
mikie
1,185件の閲覧回数
mikie_mikie
Kind regards,
mikie
1,190件の閲覧回数
AldoG
I would like to confirm if you have set all packages needed?
By this I do not mean that the host have the packages, but if yocto has fetch and configured all pakcages, since you are running using -k option.
I will try on my side to double check but I would recommend to try to bitbake again without the -k option and see if the same error is shown.
Best regards/Saludos,
Aldo.
%3CLINGO-SUB%20id%3D%22lingo-sub-2189251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGhostscript%E3%83%AC%E3%82%B7%E3%83%94Yocto%E3%83%93%E3%83%AB%E3%83%89%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AF%20FRDM-IMX8MPLUS%20%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AE%20Yocto%20Build%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%20Bitbake%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3Ebitbake%20-k%20imx-image-full%3C%2FP%3E%3CP%3E%E7%B5%90%E6%9E%9C%3A%20bitbake%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%80%81%E3%83%AC%E3%82%B7%E3%83%94%E5%90%8D%3A%20ghostscript%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%83%E3%83%88%E3%83%99%E3%82%A4%E3%82%AF%20-k%20%E3%82%B4%E3%83%BC%E3%82%B9%E3%83%88%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Egcc%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AB%E4%BD%95%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%7C%20%2Fusr%2Fsrc%2Fdebug%2Fgcc%2F13.3.0%2Fgcc%2Frange.cc%3A42%3A(.text%2B0x9c)%3A%60build_zero_cst(tree_node*)'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3E%7C%20%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fcompulab%2Fimx-Yocto-bsp%2Ffrdm-imx8mp%2Ftmp%2Fwork%2Farmv8a-poky-Linux%2Fgcc%2F13.3.0%2Frecipe-sysroot-native%2Fusr%2Fbin%2Faarch64-poky-Linux%2F..%2F..%2Flibexec%2Faarch64-poky-Linux%2Fgcc%2Faarch64-poky-Linux%2F13.3.0%2Fld%3A%2Fusr%2Fsrc%2Fdebug%2Fgcc%2F13.3.0%2Fgcc%2Frange.cc%3A42%3A(.text%2B0xa8)%3A%60build_zero_cst(tree_node*)'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3E%7C%20%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fcompulab%2Fimx-Yocto-bsp%2Ffrdm-imx8mp%2Ftmp%2Fwork%2Farmv8a-poky-Linux%2Fgcc%2F13.3.0%2Frecipe-sysroot-native%2Fusr%2Fbin%2Faarch64-poky-Linux%2F..%2F..%2Flibexec%2Faarch64-poky-Linux%2Fgcc%2Faarch64-poky-Linux%2F13.3.0%2Fld%3Arange.o%3A%20%E9%96%A2%E6%95%B0%20%60int_range%26lt%3B1u%2C%20false%26gt%3B%3A%3Aint_range(tree_node*%2C%20tree_node*%2C%20value_range_kind)'%20%E5%86%85%3A%3CBR%20%2F%3E%20%7C%20%2Fusr%2Fsrc%2Fdebug%2Fgcc%2F13.3.0%2Fgcc%2F%E5%80%A4%E7%AF%84%E5%9B%B2.h%3A941%3A(.text%2B0xe4)%3A%60irange%3A%3Aset(tree_node*%2C%20tree_node*%2C%20value_range_kind)'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3E%7C%20%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fcompulab%2Fimx-yocto-bsp%2Ffrdm-imx8mp%2Ftmp%2Fwork%2Farmv8a-poky-Linux%2Fgcc%2F13.3.0%2Frecipe-sysroot-native%2Fusr%2Fbin%2Faarch64-poky-Linux%2F..%2F..%2Flibexec%2Faarch64-poky-Linux%2Fgcc%2Faarch64-poky-Linux%2F13.3.0%2Fld%3Arange.o%3A%20%E9%96%A2%E6%95%B0%20%60int_range%26lt%3B1u%2C%20false%26gt%3B%3A%3Aoperator%3D(int_range%26lt%3B1u%2C%20false%26gt%3B%20const%26amp%3B)'%20%E5%86%85%3A%3CBR%20%2F%3E%20%7C%20%2Fusr%2Fsrc%2Fdebug%2Fgcc%2F13.3.0%2Fgcc%2F%E5%80%A4%E7%AF%84%E5%9B%B2.h%3A972%3A(.text%2B0x264)%3A%60irange%3A%3Aoperator%3D(irange%20const%26amp%3B)'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3E%7C%20collect2%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20ld%20%E3%81%8C%201%20%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%7C%20make%5B1%5D%3A%20***%20%5B..%2F..%2F..%2F..%2F..%2F..%2F..%2Fwork-shared%2Fgcc-13.3.0-r0%2Fgcc-13.3.0%2Fgcc%2Flto%2FMake-lang.in%3A102%3A%20lto-dump%5D%20%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20%7C%20make%5B1%5D%3A%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fcompulab%2Fimx-Yocto-bsp%2Ffrdm-imx8mp%2Ftmp%2Fwork%2Farmv8a-poky-Linux%2Fgcc%2F13.3.0%2Fgcc-13.3.0%2Fbuild.aarch64-poky-Linux.aarch64-poky-Linux%2Fgcc'%20%E3%81%8B%E3%82%89%E5%87%BA%E3%81%BE%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%7C%20make%3A%20***%20%5BMakefile%3A4627%3A%20all-gcc%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%202%3CBR%20%2F%3E%20%7C%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20oe_runmake%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%7C%20%E8%AD%A6%E5%91%8A%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8B%E3%82%89%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%201%20%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20(%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fcompulab%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fgcc%2Fgcc_13.3.bb%3Ado_compile)%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20'1'%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%204587%20%E4%BB%B6%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%203788%20%E4%BB%B6%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%20%E4%BB%B6%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%3A%201%20%E4%BB%B6%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%2Fhome%2Fcompulab%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fgcc%2Fgcc_13.3.bb%3Ado_compile%3CBR%20%2F%3E%E6%A6%82%E8%A6%81%3A%202%20%E3%81%A4%E3%81%AE%20ERROR%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%BC%E3%83%AD%E4%BB%A5%E5%A4%96%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Ghostscript%20recipe%20Yocto%20Build%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%83%86%E3%82%AF%E3%83%8B%E3%82%AB%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E6%A7%98%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3Etmp%3C%2FSTRONG%3E%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81bitbake%20-k%20%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3CP%3E%E3%83%9F%E3%82%AD%E3%82%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190307%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Ghostscript%20recipe%20Yocto%20Build%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190307%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E3%81%99%E3%81%B9%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AB%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81-k%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81yocto%20%E3%81%8C%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%A7%E3%82%82%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81-k%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AA%E3%81%97%E3%81%A7%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%20bitbake%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A2%E3%83%AB%E3%83%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
