GUI Guider custom code editing
已解决
跳至解决方案
1,683 次查看
acosara
I'm creating an HMI using GUI Guider (used both version 1.80 and 1.90 with the same results). I'm using a FRDM-RW612 board and I started from the "Screen Transitions" Widget, to which I made some changes. The problem I'm having is that I can't get rid of some custom code that keeps getting generated no matter what I do.
Specifically, in custom.c, ALL of this code I didn't want, and no longer have any widgets that use it, they were all removed:
* Copyright 2024 NXP
* NXP Proprietary. This software is owned or controlled by NXP and may only be used strictly in
* accordance with the applicable license terms. By expressly accepting such terms or by downloading, installing,
* activating and/or otherwise using the software, you are agreeing that you have read, and that you agree to
* comply with and are bound by, such license terms.  If you do not agree to be bound by the applicable license
* terms, then you may not retain, install, activate or otherwise use the software.
 *      INCLUDES
#include <stdio.h>
#include <stdlib.h>
#include "lvgl.h"
#include "custom.h"
 *      DEFINES
#define CHART1_POINTS 100
 *      TYPEDEFS
 *  STATIC PROTOTYPES
 *  STATIC VARIABLES
static int32_t speed = 0;
static bool is_increase = true;
static int16_t spd_chart[CHART1_POINTS] = {0};
static bool is_up = true;
 * Create a demo application
void custom_init(lv_ui *ui)
    /* Add your codes here */
 *  STATIC FUNCTIONS
void speed_meter_timer_cb(lv_timer_t * t)
    lv_ui * gui = t->user_data;
    if(speed >= 110) is_increase = false;
    if(speed <= 70) is_increase = true;
    lv_meter_set_indicator_value(gui->speed_meter_board, gui->speed_meter_board_scale_0_ndline_0, speed);
    lv_label_set_text_fmt(gui->speed_label_digit, "%"LV_PRId32, speed);
    if(is_increase)
        speed ++;
    }else
        speed --;
void record_chart_timer_cb(lv_timer_t * t)
    lv_obj_t * obj = t->user_data;
    lv_chart_series_t * ser = lv_chart_get_series_next(obj, NULL);
    lv_coord_t * ser_array = lv_chart_get_y_array(obj, ser);
    for(int i = 0; i < CHART1_POINTS - 1; i++)
        spd_chart[i] = spd_chart[i+1];
        ser_array[i] = spd_chart[i];
    if(spd_chart[CHART1_POINTS - 1] > 110) is_up = false;
    if(spd_chart[CHART1_POINTS - 1] < 70) is_up = true;
    if(is_up)
        spd_chart[CHART1_POINTS - 1] += lv_rand(0, 5);
    }else
        spd_chart[CHART1_POINTS - 1] -= lv_rand(0, 5);
    ser_array[CHART1_POINTS - 1] = spd_chart[CHART1_POINTS - 1];
    lv_chart_refresh(obj);
Same problem for custom.h, I want all  this custom code gone:
#ifndef __CUSTOM_H_
#define __CUSTOM_H_
#ifdef __cplusplus
extern "C" {
#endif
#include "gui_guider.h"
void custom_init(lv_ui *ui);
void speed_meter_timer_cb(lv_timer_t * t);
void record_chart_timer_cb(lv_timer_t * t);
#ifdef __cplusplus
#endif
#endif /* EVENT_CB_H_ */
All the original widgets on the graphing screen were deleted, see screenshot in the attachments. The widgets were first removed (didn't get rid of the code), then the screen name was changed, other widgets were added (still got the custom code). There are no events that contain this code in the event viewer. So, I don't know where the code is getting generated from.
I can't edit it directly in the code editor either. If I make any changes, they disappear as soon as I clock on another file, even if I go to File->Save or generate code. I also tried cleaning up the code and generating again, but still get the code. I checked the custom code for both screens under the custom code tab, but those are already empty (see screenshot).
W
1 解答
1,628 次查看
DanielRuvalcaba
A colleague helped me to test this. This is his response. Could you please try it on your side?
I have replicated the behaviors you mentioned in GUI Guider 1.8 & 1.9, however it seems to be an interface issue, therefore, after any change done in the Code Editor, you must press the key binding to save: "ctrl+s" while editing a certain file, so the changes can be reflected in the code.
Daniel.
在原帖中查看解决方案
1 回复
1,629 次查看
DanielRuvalcaba
Daniel.
%3CLINGO-SUB%20id%3D%22lingo-sub-2083347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGUI%20Guider%20%E8%87%AA%E5%AE%9A%E4%B9%89%E4%BB%A3%E7%A0%81%E7%BC%96%E8%BE%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2083347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20GUI%20Guider%20%E5%88%9B%E5%BB%BA%20HMI%EF%BC%88%E4%BD%BF%E7%94%A8%201.80%20%E5%92%8C%201.90%20%E7%89%88%E6%9C%AC%EF%BC%8C%E7%BB%93%E6%9E%9C%E7%9B%B8%E5%90%8C%EF%BC%89%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20FRDM-RW612%20%E6%9D%BF%EF%BC%8C%E5%B9%B6%E4%BB%8E%E2%80%9C%E5%B1%8F%E5%B9%95%E8%BD%AC%E6%8D%A2%E2%80%9D%E5%B0%8F%E9%83%A8%E4%BB%B6%E5%BC%80%E5%A7%8B%EF%BC%8C%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E4%BA%86%E4%B8%80%E4%BA%9B%E6%9B%B4%E6%94%B9%E3%80%82%E6%88%91%E9%81%87%E5%88%B0%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E6%97%A0%E8%AE%BA%E6%88%91%E5%81%9A%E4%BB%80%E4%B9%88%EF%BC%8C%E6%88%91%E9%83%BD%E6%97%A0%E6%B3%95%E6%91%86%E8%84%B1%E4%B8%80%E4%BA%9B%E4%B8%8D%E6%96%AD%E7%94%9F%E6%88%90%E7%9A%84%E8%87%AA%E5%AE%9A%E4%B9%89%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%85%B7%E4%BD%93%E6%9D%A5%E8%AF%B4%EF%BC%8C%E5%9C%A8custom.c%E4%B8%AD%EF%BC%8C%E6%88%91%E4%B8%8D%E9%9C%80%E8%A6%81%E6%89%80%E6%9C%89%E8%BF%99%E4%BA%9B%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%B9%B6%E4%B8%94%E4%B8%8D%E5%86%8D%E6%9C%89%E4%BB%BB%E4%BD%95%E4%BD%BF%E7%94%A8%E5%AE%83%E7%9A%84%E5%B0%8F%E9%83%A8%E4%BB%B6%EF%BC%8C%E5%AE%83%E4%BB%AC%E9%83%BD%E8%A2%AB%E5%88%A0%E9%99%A4%E4%BA%86%EF%BC%9A%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%202024%20%E6%81%A9%E6%99%BA%E6%B5%A6%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20NXP%20%E4%B8%93%E6%9C%89%E3%80%82%E8%AF%A5%E8%BD%AF%E4%BB%B6%E7%94%B1%E6%81%A9%E6%99%BA%E6%B5%A6%E6%8B%A5%E6%9C%89%E6%88%96%E6%8E%A7%E5%88%B6%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%8F%AA%E8%83%BD%E5%9C%A8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E7%AC%A6%E5%90%88%E9%80%82%E7%94%A8%E7%9A%84%E8%AE%B8%E5%8F%AF%E6%9D%A1%E6%AC%BE%E3%80%82%E9%80%9A%E8%BF%87%E6%98%8E%E7%A1%AE%E6%8E%A5%E5%8F%97%E6%AD%A4%E7%B1%BB%E6%9D%A1%E6%AC%BE%E6%88%96%E9%80%9A%E8%BF%87%E4%B8%8B%E8%BD%BD%E3%80%81%E5%AE%89%E8%A3%85%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E6%BF%80%E6%B4%BB%E5%92%8C%2F%E6%88%96%E4%BB%A5%E5%85%B6%E4%BB%96%E6%96%B9%E5%BC%8F%E4%BD%BF%E7%94%A8%E8%AF%A5%E8%BD%AF%E4%BB%B6%EF%BC%8C%E5%8D%B3%E8%A1%A8%E7%A4%BA%E6%82%A8%E5%90%8C%E6%84%8F%E6%82%A8%E5%B7%B2%E9%98%85%E8%AF%BB%E5%B9%B6%E5%90%8C%E6%84%8F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E9%81%B5%E5%AE%88%E5%B9%B6%E5%8F%97%E6%AD%A4%E7%B1%BB%E8%AE%B8%E5%8F%AF%E6%9D%A1%E6%AC%BE%E7%9A%84%E7%BA%A6%E6%9D%9F%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E4%B8%8D%E5%90%8C%E6%84%8F%E5%8F%97%E9%80%82%E7%94%A8%E8%AE%B8%E5%8F%AF%E7%9A%84%E7%BA%A6%E6%9D%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E6%9D%A1%E6%AC%BE%EF%BC%8C%E5%88%99%E6%82%A8%E4%B8%8D%E5%BE%97%E4%BF%9D%E7%95%99%E3%80%81%E5%AE%89%E8%A3%85%E3%80%81%E6%BF%80%E6%B4%BB%E6%88%96%E4%BB%A5%E5%85%B6%E4%BB%96%E6%96%B9%E5%BC%8F%E4%BD%BF%E7%94%A8%E8%AF%A5%E8%BD%AF%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F*********************%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E5%8C%85%E6%8B%AC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B*********************%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23include%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Estdio.h%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23include%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Estdlib.h%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23include%3C%2FSPAN%3E%20%3CSPAN%3E%22%3C%2FSPAN%3E%20%3CSPAN%3Elvgl.h%3C%2FSPAN%3E%20%3CSPAN%3E%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23include%3C%2FSPAN%3E%20%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%E8%87%AA%E5%AE%9A%E4%B9%89.h%3C%2FSPAN%3E%20%3CSPAN%3E%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F*********************%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E5%AE%9A%E4%B9%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B*********************%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23%E5%AE%9A%E4%B9%89%3C%2FSPAN%3E%3CSPAN%3ECHART1_POINTS%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F**********************%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E7%B1%BB%E5%9E%8B%E5%AE%9A%E4%B9%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B**********************%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F**********************%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E9%9D%99%E6%80%81%E5%8E%9F%E5%9E%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B**********************%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F**********************%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E9%9D%99%E6%80%81%E5%8F%98%E9%87%8F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B**********************%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%9D%99%E6%80%81%3C%2FSPAN%3E%3CSPAN%3Eint32_t%3C%2FSPAN%3E%3CSPAN%3E%E9%80%9F%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%9D%99%E6%80%81%3C%2FSPAN%3E%3CSPAN%3Ebool%3C%2FSPAN%3E%20%3CSPAN%3Eis_increase%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Etrue%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E9%9D%99%E6%80%81%3C%2FSPAN%3E%3CSPAN%3Eint16_t%3C%2FSPAN%3E%20%3CSPAN%3Espd_chart%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3ECHART1_POINTS%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%7D%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%9D%99%E6%80%81%3C%2FSPAN%3E%3CSPAN%3Ebool%3C%2FSPAN%3E%20%3CSPAN%3Eis_up%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Etrue%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F**%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%BC%94%E7%A4%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3Ecustom_init%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Elv_ui%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3Eui%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F*%20%E5%9C%A8%E8%BF%99%E9%87%8C%E6%B7%BB%E5%8A%A0%E6%82%A8%E7%9A%84%E4%BB%A3%E7%A0%81%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F**********************%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E9%9D%99%E6%80%81%E5%87%BD%E6%95%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B**********************%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3Espeed_meter_timer_cb%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Elv_timer_t%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3Et%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Elv_ui%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3Egui%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Et%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3Euser_data%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%E9%80%9F%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E110%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%3Eis_increase%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Efalse%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%E9%80%9F%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%3D%3C%2FSPAN%3E%20%3CSPAN%3E70%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%3Eis_increase%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Etrue%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Elv_meter_set_indicator_value%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Egui-%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E9%80%9F%E5%BA%A6%E8%AE%A1%E6%9D%BF%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%3Egui-%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E9%80%9F%E5%BA%A6%E8%AE%A1%E6%9D%BF%E5%B0%BA%E5%BA%A6%3C%2FSPAN%3E_0_ndline_0%20%3CSPAN%3E%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%3E%E9%80%9F%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Elv_label_set_text_fmt%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Egui-%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3Espeed_label_digit%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%3E%E2%80%9C%EF%BC%85%E2%80%9D%3C%2FSPAN%3E%20%3CSPAN%3ELV_PRId32%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%3E%E9%80%9F%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Eis_increase%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E9%80%9F%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%3E%2B%2B%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E9%80%9F%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%3E-%20%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E6%97%A0%E6%95%88%3C%2FSPAN%3E%3CSPAN%3E%E8%AE%B0%E5%BD%95%E5%9B%BE%E8%A1%A8%E8%AE%A1%E6%97%B6%E5%99%A8_cb%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Elv_timer_t%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3Et%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Elv_obj_t%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3Eobj%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Et%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3Euser_data%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Elv_chart_series_t%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3Eser%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Elv_chart_get_series_next%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Eobj%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%3ENULL%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Elv_coord_t%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3Eser_array%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Elv_chart_get_y_array%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Eobj%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3Eser%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E5%AF%B9%E4%BA%8E%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Eint%3C%2FSPAN%3E%20%3CSPAN%3Ei%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%3Ei%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECHART1_POINTS%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%3Ei%3C%2FSPAN%3E%20%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Espd_chart%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3Ei%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Espd_chart%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3Ei%3C%2FSPAN%3E%3CSPAN%3E%2B%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eser_array%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3Ei%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Espd_chart%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3Ei%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Espd_chart%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3ECHART1_POINTS%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E110%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%3Eis_up%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Efalse%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Espd_chart%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3ECHART1_POINTS%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E70%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%3Eis_up%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Etrue%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Eis_up%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Espd_chart%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3ECHART1_POINTS%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%2B%3D%3C%2FSPAN%3E%20%3CSPAN%3Elv_rand%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3E5%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Espd_chart%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3ECHART1_POINTS%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E-%20%3D%3C%2FSPAN%3E%20%3CSPAN%3Elv_rand%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3E5%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eser_array%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3ECHART1_POINTS%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Espd_chart%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3ECHART1_POINTS%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Elv_chart_refresh%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Eobj%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecustom.h%20%E4%B9%9F%E5%AD%98%E5%9C%A8%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E5%B8%8C%E6%9C%9B%E6%89%80%E6%9C%89%E8%BF%99%E4%BA%9B%E8%87%AA%E5%AE%9A%E4%B9%89%E4%BB%A3%E7%A0%81%E9%83%BD%E6%B6%88%E5%A4%B1%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%202024%20%E6%81%A9%E6%99%BA%E6%B5%A6%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20NXP%20%E4%B8%93%E6%9C%89%E3%80%82%E8%AF%A5%E8%BD%AF%E4%BB%B6%E7%94%B1%E6%81%A9%E6%99%BA%E6%B5%A6%E6%8B%A5%E6%9C%89%E6%88%96%E6%8E%A7%E5%88%B6%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%8F%AA%E8%83%BD%E5%9C%A8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E7%AC%A6%E5%90%88%E9%80%82%E7%94%A8%E7%9A%84%E8%AE%B8%E5%8F%AF%E6%9D%A1%E6%AC%BE%E3%80%82%E9%80%9A%E8%BF%87%E6%98%8E%E7%A1%AE%E6%8E%A5%E5%8F%97%E6%AD%A4%E7%B1%BB%E6%9D%A1%E6%AC%BE%E6%88%96%E9%80%9A%E8%BF%87%E4%B8%8B%E8%BD%BD%E3%80%81%E5%AE%89%E8%A3%85%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E6%BF%80%E6%B4%BB%E5%92%8C%2F%E6%88%96%E4%BB%A5%E5%85%B6%E4%BB%96%E6%96%B9%E5%BC%8F%E4%BD%BF%E7%94%A8%E8%AF%A5%E8%BD%AF%E4%BB%B6%EF%BC%8C%E5%8D%B3%E8%A1%A8%E7%A4%BA%E6%82%A8%E5%90%8C%E6%84%8F%E6%82%A8%E5%B7%B2%E9%98%85%E8%AF%BB%E5%B9%B6%E5%90%8C%E6%84%8F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E9%81%B5%E5%AE%88%E5%B9%B6%E5%8F%97%E6%AD%A4%E7%B1%BB%E8%AE%B8%E5%8F%AF%E6%9D%A1%E6%AC%BE%E7%9A%84%E7%BA%A6%E6%9D%9F%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E4%B8%8D%E5%90%8C%E6%84%8F%E5%8F%97%E9%80%82%E7%94%A8%E8%AE%B8%E5%8F%AF%E7%9A%84%E7%BA%A6%E6%9D%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E6%9D%A1%E6%AC%BE%EF%BC%8C%E5%88%99%E6%82%A8%E4%B8%8D%E5%BE%97%E4%BF%9D%E7%95%99%E3%80%81%E5%AE%89%E8%A3%85%E3%80%81%E6%BF%80%E6%B4%BB%E6%88%96%E4%BB%A5%E5%85%B6%E4%BB%96%E6%96%B9%E5%BC%8F%E4%BD%BF%E7%94%A8%E8%AF%A5%E8%BD%AF%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23ifndef%3C%2FSPAN%3E%20%3CSPAN%3E__CUSTOM_H_%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23%E5%AE%9A%E4%B9%89%3C%2FSPAN%3E%3CSPAN%3E__CUSTOM_H_%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23ifdef%3C%2FSPAN%3E%20%3CSPAN%3E__cplusplus%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%A4%96%E9%83%A8%3C%2FSPAN%3E%3CSPAN%3E%E2%80%9CC%E2%80%9D%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23endif%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23include%3C%2FSPAN%3E%20%3CSPAN%3E%22%3C%2FSPAN%3E%20%3CSPAN%3Egui_guider.h%3C%2FSPAN%3E%20%3CSPAN%3E%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3Ecustom_init%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Elv_ui%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3Eui%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3Espeed_meter_timer_cb%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Elv_timer_t%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3Et%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%97%A0%E6%95%88%3C%2FSPAN%3E%3CSPAN%3E%E8%AE%B0%E5%BD%95%E5%9B%BE%E8%A1%A8%E8%AE%A1%E6%97%B6%E5%99%A8_cb%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Elv_timer_t%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3Et%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23ifdef%3C%2FSPAN%3E%20%3CSPAN%3E__cplusplus%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23endif%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23endif%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20EVENT_CB_H_%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9B%BE%E5%BD%A2%E5%B1%8F%E5%B9%95%E4%B8%8A%E7%9A%84%E6%89%80%E6%9C%89%E5%8E%9F%E5%A7%8B%E5%B0%8F%E9%83%A8%E4%BB%B6%E5%9D%87%E8%A2%AB%E5%88%A0%E9%99%A4%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E9%99%84%E4%BB%B6%E4%B8%AD%E7%9A%84%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%E3%80%82%E9%A6%96%E5%85%88%E5%88%A0%E9%99%A4%E4%BA%86%E5%B0%8F%E9%83%A8%E4%BB%B6%EF%BC%88%E6%B2%A1%E6%9C%89%E5%88%A0%E9%99%A4%E4%BB%A3%E7%A0%81%EF%BC%89%EF%BC%8C%E7%84%B6%E5%90%8E%E6%9B%B4%E6%94%B9%E4%BA%86%E5%B1%8F%E5%B9%95%E5%90%8D%E7%A7%B0%EF%BC%8C%E6%B7%BB%E5%8A%A0%E4%BA%86%E5%85%B6%E4%BB%96%E5%B0%8F%E9%83%A8%E4%BB%B6%EF%BC%88%E4%BB%8D%E7%84%B6%E8%8E%B7%E5%BE%97%E8%87%AA%E5%AE%9A%E4%B9%89%E4%BB%A3%E7%A0%81%EF%BC%89%E3%80%82%E4%BA%8B%E4%BB%B6%E6%9F%A5%E7%9C%8B%E5%99%A8%E4%B8%AD%E6%B2%A1%E6%9C%89%E5%8C%85%E5%90%AB%E6%AD%A4%E4%BB%A3%E7%A0%81%E7%9A%84%E4%BA%8B%E4%BB%B6%E3%80%82%E6%89%80%E4%BB%A5%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%BB%A3%E7%A0%81%E6%98%AF%E4%BB%8E%E5%93%AA%E9%87%8C%E7%94%9F%E6%88%90%E7%9A%84%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%B9%9F%E6%97%A0%E6%B3%95%E5%9C%A8%E4%BB%A3%E7%A0%81%E7%BC%96%E8%BE%91%E5%99%A8%E4%B8%AD%E7%9B%B4%E6%8E%A5%E7%BC%96%E8%BE%91%E5%AE%83%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E5%81%9A%E4%BA%86%E4%BB%BB%E4%BD%95%E6%9B%B4%E6%94%B9%EF%BC%8C%E5%BD%93%E6%88%91%E8%AE%BF%E9%97%AE%E5%8F%A6%E4%B8%80%E4%B8%AA%E6%96%87%E4%BB%B6%E6%97%B6%EF%BC%8C%E8%BF%99%E4%BA%9B%E6%9B%B4%E6%94%B9%E5%B0%B1%E4%BC%9A%E6%B6%88%E5%A4%B1%EF%BC%8C%E5%8D%B3%E4%BD%BF%E6%88%91%E8%BD%AC%E5%88%B0%E6%96%87%E4%BB%B6-%26gt%3B%E4%BF%9D%E5%AD%98%E6%88%96%E7%94%9F%E6%88%90%E4%BB%A3%E7%A0%81%E3%80%82%E6%88%91%E4%B9%9F%E5%B0%9D%E8%AF%95%E6%B8%85%E7%90%86%E4%BB%A3%E7%A0%81%E5%B9%B6%E5%86%8D%E6%AC%A1%E7%94%9F%E6%88%90%EF%BC%8C%E4%BD%86%E4%BB%8D%E7%84%B6%E5%BE%97%E5%88%B0%E4%BB%A3%E7%A0%81%E3%80%82%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%E8%87%AA%E5%AE%9A%E4%B9%89%E4%BB%A3%E7%A0%81%E9%80%89%E9%A1%B9%E5%8D%A1%E4%B8%8B%E4%B8%A4%E4%B8%AA%E5%B1%8F%E5%B9%95%E7%9A%84%E8%87%AA%E5%AE%9A%E4%B9%89%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%86%E5%AE%83%E4%BB%AC%E5%B7%B2%E7%BB%8F%E6%98%AF%E7%A9%BA%E7%9A%84%EF%BC%88%E8%A7%81%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EW%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2084915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AGUI%20Guider%20%E8%87%AA%E5%AE%9A%E4%B9%89%E4%BB%A3%E7%A0%81%E7%BC%96%E8%BE%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2084915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%B8%80%E4%BD%8D%E5%90%8C%E4%BA%8B%E5%B8%AE%E5%8A%A9%E6%88%91%E6%B5%8B%E8%AF%95%E4%BA%86%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%E8%BF%99%E6%98%AF%E4%BB%96%E7%9A%84%E5%9B%9E%E5%BA%94%E3%80%82%E4%BD%A0%E8%83%BD%E5%9C%A8%E4%BD%A0%E9%82%A3%E8%BE%B9%E5%B0%9D%E8%AF%95%E4%B8%80%E4%B8%8B%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8%20GUI%20Guider%201.8%20%E5%92%8C%201.9%20%E4%B8%AD%E5%A4%8D%E5%88%B6%E4%BA%86%E6%82%A8%E6%8F%90%E5%88%B0%E7%9A%84%E8%A1%8C%E4%B8%BA%EF%BC%8C%E4%BD%86%E8%BF%99%E4%BC%BC%E4%B9%8E%E6%98%AF%E4%B8%80%E4%B8%AA%E7%95%8C%E9%9D%A2%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%9C%A8%E4%BB%A3%E7%A0%81%E7%BC%96%E8%BE%91%E5%99%A8%E4%B8%AD%E5%AE%8C%E6%88%90%E4%BB%BB%E4%BD%95%E6%9B%B4%E6%94%B9%E5%90%8E%EF%BC%8C%E6%82%A8%E5%BF%85%E9%A1%BB%E5%9C%A8%E7%BC%96%E8%BE%91%E6%9F%90%E4%B8%AA%E6%96%87%E4%BB%B6%E6%97%B6%E6%8C%89%E4%B8%8B%E9%94%AE%E7%BB%91%E5%AE%9A%E6%9D%A5%E4%BF%9D%E5%AD%98%EF%BC%9A%E2%80%9Cctrl%2Bs%E2%80%9D%EF%BC%8C%E8%BF%99%E6%A0%B7%E6%9B%B4%E6%94%B9%E6%89%8D%E8%83%BD%E5%8F%8D%E6%98%A0%E5%9C%A8%E4%BB%A3%E7%A0%81%E4%B8%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3EDaniel.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
