FreeRTOS helloworld crashes inside vPortStartFirstTask
839 次查看
Sayyad
I am trying out examples on the MIMXRT1189 devkit. I am trying the helloworld example with a jLink debugger. It crashes inside the vPortStartFirstTask and specifically in the assembly instruction "svc %0". Any suggestion where the problem might be? Much appreciated.
The SVC_Handler is correctly defined and correctly inserted in the vector table.
824 次查看
mayliu1
Hi @Sayyad ,
Thank you so much for your interest in our products and for using our community.
Hi Sayyad, I would like to know more details about your question.
1: which SDK demo do you import? whether you modify it?
 I import SDK demo "evkmimxrt1180_freertos_hello_cm7" , It runs okay.
2: what do you mean "The SVC_Handler is correctly defined and correctly inserted in the vector table"?
  Did you redefine it?
Wish you a nice day!
Best Regards
mayliu
