Finding a appropriate chip
1,186 次查看
gejx
I want to have a new chip which have the same bootloader and bottom-driven as the MC9S12XEP100MAG,do you have this chip?
1,103 次查看
dianabatrlova
Unfortunately, it is not possible to use the same bootloader of the S12(X) devices for the newer family.
The 16-bits MCUs MagniV is available as the newest high voltage MCUs family. These MCUs runs directly from the 12V power supply – you don’t need an external power supply regulator.
The bootloader for this family is available below:
Simple Serial Bootloader for S12Z - AN draft
More information about the MagniV family can be found on the NXP site:
S12 MagniV® Mixed-Signal MCUs for Automotive and Industrial | NXP
I hope it helps.
Diana
