Hello -
For the first time I tried to build the Release configuration of our project. While the Debug configuration builds fine, some source files seem to be missing from the Release configuration.
I have looked in the IDE User Guide but don't see any information specific to doing this. I do see how to switch between different configurations.
Any pointers or advice?
Best,
John Sambrook
Common Sense Systems, Inc.
Hello @jsambrook
In Release builds, Optimizations are enabled for best performance or code density. About specific project configuration, you need check on Properties:
In release mode, it should be optimized some files or data, so there is error when build, you can check.
You can also refer Erich blog for this topic:
https://mcuoneclipse.com/2012/06/01/debug-vs-release/
Alice
